Question about Brother MFC-5840CN All-In-One InkJet Printer
Main board where can I get it
Where can I get a main board for this unit?
  • 832 Answers
Re: main board where can I get it
Search brother homepage for a service dealer near your home.
You will find out that the spare part will cost nearly the same as a complete new mfc!
Tip: Search eBay for a 2nd hand mfc 5840 with rotten printhead.
Posted on Nov 16, 2007
0 characters
3 Points
When i switch on ma toshiba e studio 212 its showing me error c26. how can i fix it
it is cis unit error check connection between cis unit and main board otherwise replace cis unit ribbon OR cis unit OR main board
Feb 06, 2014 | Compatible Toshiba T1810 For E Studio 181,...
My ricoh 2022 is giving me error code sc650 on my ricoh 2022 machine.
Communication timeout error between
SBCU and duplex unit
650 B
The SBCU cannot receive a response
within 1 second from the duplex unit.
• Serial line connecting SBCU and
duplex unit unstable
• External noise
• SBCU board and duplex main board
connection defective or loose
• Duplex main board defective
• SBCU board defective
Jul 22, 2011 | Printers & Copiers
Error no :-6006
6006 High voltage circuit problem
Any of the following conditions is handled as a high voltage circuit problem:
  • The charging monitor voltage (HVC_MON) signal was detected to be out of the predetermined limits after passage of the predetermined period of time from power on.
  • The transfer voltage monitor signal (T_MON_V) or the transfer current monitor signal (T_MON_I) was detected to be out of the predetermined limits.
1 Fuser unit. Replace the fuser unit.
♦Has the error been cleared?
(Yes) Replace the fuser unit.
(No) Go to Step 2
2 Main Board Assy. Replace the Main Board Assy.
(Yes) Replace the Main Board Assy.
(No) Go to "3.4.2 Electrical Noise"
Jul 13, 2011 | Epson laser Printer EPL-6200L Laser
Error call service 4000:00433933
The codes on this model are the same as on the Kyocera Mita copiers.
ie: 4-digit codes
Call service 0150 engine pcb EEPROM error
Call service 0420 option paper feeder communication error
Call service 1010 lift motor lock error
Call service 1140 lift motor going up error
Call service 1150 lift motor going down error
Call service 2000 main motor error
Call service 2200 drum motor error
Call service 4000 laser scanner unit (polygon motor) error
Call service 4200 laser scanner unit (pin photo sensor) error
Call service 5100 short-circuited main charger output
Call service 6000 broken fuser heater lamp M wire
Call service 6020 abnormally high fuser thermistor M temperature
Call service 6030 broken fuser thermistor M wire
Call service 6400 zero-crossing signal problem
Call service 7000 toner motor lock error
Call service 7410 drum unit non-installing error
Call service F000 communication error between the main controller board and operation panel board
Call service F010 main board (system DIMM board) checksum error
Call service F020 main or expanded memory error
Call service F030 general failure
Call service F040 communication problem between main board and engine board
Call service F226 main pcb video data control error
May 18, 2011 | Kyocera FS-3900DN Laser Printer
My mp160 appear error e2 and e16 pls solve it.tq
Carriage unit (main unit)
Timing **** strip film
Logic board ***'y
Carriage motor (main unit)&
Internal temperature rise error [5400] - Logic board ***'y problem
Oct 09, 2009 | Canon PIXMA MP150 All-In-One InkJet...
SC No. Item Definition Possible Cause Related
SCs Troubleshooting Procedure Type
SC 221 Synch.
detection signal
error 2
221-001: Y
221-002: M
221-003: C
221-004: K
Main scan length detection is
not properly completed ten
consecutive times.
The front (for C&M) or rear (for
K&Y) laser synchronizing
detector boards are used for
the main scan length
detection, which automatically
corrects the main-scan
• Damaged or
disconnected cable
between front (C&M)
or rear (K&Y) laser
detector board and
the LD unit
• Incorrect installation
of front (C&M) or rear
(K&Y) synchronizing
detector board (the
beam does not target
the photo detector.)
• Defective front (C&M)
or rear (K&Y)
detector board
• Defective LD unit
After doing any of the following, print ten
jobs or more to see if the same SC code
is displayed:
1. Turn the main switch off and on.
2. Check or replace the cable
connecting front (for C&M) or rear (for
K&Y) synchronizing detector board
and the LD unit.
3. Check or reinstall the front (for C&M)
or rear (for K&Y) synchronizing
detector board.
4. Replace the front (for C&M) or rear
(for K&Y) synchronizing detector
5. Replace the laser optics housing unit.
6. Replace the BCU.
If a synch. detector board cannot be
replaced, do the following as a
temporary measure:
• Disable main scan length detection
Sep 15, 2009 | Ricoh Aficio CL7000 Laser Printer
Imagerunner 1600 trobleshooting code e0000
Check the main motor,main suplly board.Remove the fuser unit,the developer unit and the transfer or duplex unit for to verify the main motor is rotate easly manual.
Aug 28, 2009 | Canon ImageRunner 1600 Copier
I need solution to aficio 200 error code sc322
sc322 is a Laser synchronization error:
Means that the laser synchronization signal cannot be detected by the main scan detector board.
Possible causes:
Poor connection of the interface harness which connects the laser synchronization detector board and the BiCU board.
Laser synchronization detector board out of position or is defective.
BiCU board is defective.
Unfortunately,unit needs service.
If I could be of further assistance, let me know. If this helps or solves the issue, please rate it.
Thanks, Joe
Apr 19, 2009 | Ricoh Aficio 180 Laser Printer
Main control board unit has been modified to prevent abnormal code.
[How to identify the style]
Current and new styles can be distinguished by the part number printed
on the main control board unit.
(Current) 40LA-9025 => (New) 40LA-9026
Serial Number Cut-in: 40LE02201
to reseat all the board connections first..
hope that help
Nov 11, 2008 | Printers & Copiers
Error code on kyocera fs-3800 printer
E1: xxxxxxxx = Main motor error
Either the motor aint turning or it is being stopped from turning...Usally drum or developer units cant turn, or main motor or control board stuffed...
below is stuff from service manual and comments
Suggested causes
The main motor is overloaded. Overcurrent in the main motor circuitry due to an excessive torque....... Check Drum, developer unit, toner cartridge and process units ensuring free movement
• Connector insertion error........check developer plug is secure (left top near toner cart little plug)
• Defective gate array U204 on the engine
board (KP-864). .......replace board
• Defective harness between engine board and
engine relay board (KP-760). replace cable
• Defective harness between engine relay board
(KP-760) and main motor.
Nov 26, 2007 | Kyocera Mita FS 3800 Laser Printer
Brother MFC-5840CN All-In-One InkJet Printer Logo
128 people viewed this question
Top Brother Printers & Copiers Experts
Jim Yeh
Level 1 Expert
Jesus  Colon
Jesus Colon
Level 1 Expert
Rick Johnson
Rick Johnson
Are you a Brother Printer and Copier Expert? Answer questions, earn points and help others
