Phone wirine and unit set up - Computers & Internet
What do you need?
Posted on Jul 13, 2009
Error message F22
HI. This error occurs if the touch pad/LED assembly is not able to transmit/receive data to/from the central control unit (CCU).
Possible Causes / Procedure
1. Check the touch pad/LED assembly by selecting different cycles and changing the modifiers and options available to confirm the touch pad/LED is responding.
2. Unplug washer or disconnect power.
3. Check wire harness connections to the touch pad/LED assembly and Central Control Unit (CCU).
Replace failed component.(Which will be the actual CCU, if the wirineing harness is ok, and connected properly)
Feb 18, 2011 | Whirlpool Duet GHW9150P Front Load Washer
I ave install a new a/c and heating unit kit .all wiring seems okey but the unit still does not turn on. I THERE an electrical schematic not wirin only that i can refer to.
1- Check the thermostat wires for good contact---with a volt meter check that you are getting power to the transformer in the indoor unit/air handler 120v in an 24v out to the control board
2- In the T-stat R to G calls the indoor fan on, R to Y calls the outdoor contactor to start the compressor and fan
3- Next check for power to the outdoor unit from the disconnect to the contact relay---240v (be very aware this can electricute you causing death)
4- With the unit calling for AC on you could use a wooden dowl to push the conntact relay in to see if the unit starts.
Note: call an HVAC Technician if you are confident you can perform these task's or Death may result!
Aug 18, 2010 | Goodman CLQ36AR49 Air Conditioner
I have an Alpine IVA-D900 got from a garage sale
well first the screen itself is just that.. A screen. They should have sold you the brain that goes with it.. That is where everything plugs into such as the 2 screen outputs and the amp outputs it also has a A-i net plug.. From experience the brain is pricey.. That is if you can still get it from alpine. I suggest Ebay to see if someone wants to sell the brain to that screen. Hopefully you didnt pay much for it. My guess is $600 for the brain
Nov 24, 2009 | Alpine IVA-D900 Car DVD Player
New alt and new batt but wont charge
double chec the wirin for cuts/corrosion goin to n from the components-are the batt connec tite-the same for the alternator
Sep 18, 2009 | 2001 Ford F350 Super Duty SuperCab
Replacing drivers side door mirror (whole unit) having problems getting the wiring out.
if the door panel is off you can see the wirin it plugs in beside speaker
Jul 22, 2009 | Audi A4 Cars & Trucks
Have no spark and need an ignition diagram of wirin and wirin harnesses main wires used and wires i can remove makin a derby car and kinda cut some needed wires
your best bet is buy a subs cription on www.alldatadiy.com for $20.00 bucks and use what they have, it will show you the computer management system to fix your problem and allow you to take things out that are not needed.
Jun 18, 2009 | 1985 Mercury Marquis
Wiring a thermostat
Comm should be the common terminal/wire
Satisfied means that the unit is no longer calling for heat because the thermostats setting has been "satisfied" and has shut the unit off until the room is cooler and it is then "damanding" operation. This should bring the unit on. (when the thermostat is in "demand")
Dec 10, 2008 | Electrical Supplies
E65 LCD Replacement
ok u need to check ur wirin in the phone.......if the wirin is proper ....check ur battery condition.....and switch off ur cel phone for 5 mins and restart ....
Apr 10, 2008 | Nokia e65 Cellular Phone
Computers & Internet Logo
19 people viewed this question
David Payne
David Payne
