Question about Dryers
GE Profile Harmony DPGT750EC Electric Dryer just shuts off randomly! HELP!
I have basically been through all the troubleshooting and diagnostic modes...the dryer comes on...the exhaust is working fine...it is heating...diagonostics all checked out ok...it is getting good voltage...I'm at a loss..
  • 1 more comment
  • Bimshire Nov 16, 2007
    The dryer works at random lengths and then shuts off...sometimes it runs for 4 minutes...sometimes 16 minutes..then just stops...clothes are still wet...and when it stops there is no sensing happening or cooling down function as if the clothes were dry...
    Everything works fine...but randomly it shuts off...sometimes it runs for 4 minutes...sometimes 16 mins..the clothes never fully dry though, so its not as if it's sensing the temp, then stopping and cooling down.
  • Anonymous Mar 24, 2009
    My dryer turns on fine, runs for 5 minutes or so, and then just turns off, in just a few minutes, it will turn on just fine and again the same problem.
  • 24 Answers
Too much stress on the motor might cause the dryer motor to stop for a minute and then start up again. Try turning the drum manually; if it's extremely hard to turn, that may be the source of your problem. I was able to fix this on my GE Profile by removing the front panel and putting more slack in the felt strip. This allowed the drum to turn more freely and I have had no "mid-cycle pauses" ever since.
Posted on Dec 25, 2009
  • 749 Answers
What's the problem?
Posted on Nov 16, 2007
Maytag dryer 2003 was working great I took one dried load out put another in and started the dryer. Working just fine then I found a wet garment that I dropped so I opened dryer door added this item...
When your dryer won't start, it could be a number of problems from a broken door latch or start switch to an exhaust duct blocked by lint. It could even be a tripped circuit breaker or blown fuse.
The first step in troubleshooting any electrical appliance is to ensure that it is plugged in and receiving power. While dryer plugs do not come loose easily, it can happen.
For more troubleshooting tips, read Dryer won't start for possible causes, signs to look for and things you can do. I hope this helps!
Aug 03, 2012 | Dryers
I have a Kenmore Dryer, Model 96292110. It runs, but it does not heat the air. I have checked the circuit breakers. They are fine.
If your Maytag dryer has mysteriously stopped producing heat, a blown thermal fuse may be the cause of your problem. In Whirlpool dryers,thermal fuses are safety switches that are designed to disrupt the flow of electricity to your dryer's heating mechanisms once the dryer reaches a predetermined maximum temperature, usually somewhere around 180 degrees F.
Thankfully, troubleshooting the thermal fuse in a Maytag dryer is easier than it sounds.
Instructions And Things You'll Needed.
  • Screwdriver,Towel,Electrical tape,Replacement thermal fuse, if necessary.
1 Clean out thelint screen in your Maytag clothes dryer. Lint buildup can cause your dryerto overheat, triggering the thermal fuse to disrupt power to your dryer'sheating mechanisms. Take the lint screen out of your Whirlpool dryer and washit in warm water. Dry the screen thoroughly before replacing it.
2 Look behindthe dryer to check its flexible exhaust hose for kinks or obstructions.Disconnect the exhaust hose from the back of your dryer and clean out any lintthat has built up.
3 Go outside andcheck your Maytag dryer's exhaust vent for obstructions. Lint buildup, birdnests or other obstructions in the outside exhaust vent can trigger yourdryer's thermal fuse.
4 Disconnectyour dryer from its power source before attempting to access its thermal fuse.
5 Access the thermal fuse in your Maytag dryer byremoving the back panel. Remove the screws that hold the back panel in placeand it should easily come free.
6 Look betweenthe dryer's blower housing and exhaust to locate its thermal fuse. The thermalfuse in a Whirlpool dryer looks like a white plastic strip that has two wiresconnected to it.
7 Bypass the thermal fuse in your Maytag dryer whileyou perform a quick diagnostic test. Use electrical tape to tape together thetwo wires connected to the thermal fuse. Reassemble your dryer and plug it backin. Set the dryer to a timed heated drying cycle and press "Start."If the dryer produces heat with its thermal fuse bypassed, it means the thermalfuse needs to be replaced.
8 Replace a blown thermal fuse in your Maytag dryer.Disconnect the power and remove the back panel. Remove the electrical tape thatyou used to perform the diagnostic test and disconnect the wires from thethermal fuse. Remove the screws that secure the thermal fuse to the dryer anddiscard the blown fuse. Attach the replacement thermal fuse by replacing andtightening the screws. Attach the wires to the new thermal fuse.
Thanks for using fixya.
Jul 31, 2011 | Kenmore Dryers
My dryer doesnt heat. I checked the voltage, and ran through all the diagnostic tests to try to get an error code. Everything works fine when in the test mode. Figuring that all was well i went back to...
Hi, If you are having problems with your gas dryer not heatingthe most common problem is that the ignitor goes bad. Even though it glowssometimes it is still not working properly. if you dryer is gas check out this gas no heat tip.... If you have an electric dryer, you can have many differentthings that can go wrong causing the dryer not to heat. check outthis electric no heat tip...
heatman101;'
Jul 17, 2011 | Kenmore 84072 Electric Dryer
The whole panel works but the time display is dark (no time numbers) if I hit time adjust I can put time on but dryer will sitll not start. I think there was an F73 or F93 error message but we did not...
I wonder if you may have accidentally activated diagnostic mode.
To get out of diagnostic mode press pause /cancel twice or unplug the machine.
I am thinking maybe the you saw an F-23 error which is: exhaust thermistor is open or shorted.
Bravos Dryer Service manual
Was this helpful?
Please rate the answer or request further assistance.
Jun 28, 2011 | Maytag Bravos 7.0 Cu. Ft. Electric Dryer
Dryer will not come on and has a 00 symbol on the display
It sounds like the machine is in the diagnostic code mode. This mode is accessed by pressing 'AIR FLUFF' and 'TIME +' together (this also will exit the diagnostic mode).
'00' is a diagnostic code indicating that there are no stored error codes.
Alternatively, try unplugging the dryer, wait a moment, plug it back in and see if that clears the problem.
Apr 29, 2010 | Maytag Neptune MDE5500AY Electric Dryer
Whirlpool gas dryer drum turns, heats for 10 minutes, then nothin
there is thermostat in the unite look at owner manual that what sounds like. basically it is sensor that tell the unite to turn off.
Jun 24, 2009 | Kenmore 63942 Dryer
Dryer not heating everything else works fine had heating element tested and it is okay
Just a general troubleshooting guide for your washer! hope this helps!! PS don't forget to give me a rating if this helped!! Thank you!!
http://fixitnow.com/2005/09/washing-machine-diagnostic-and-repair.htm
May 07, 2009 | Kenmore 64992 Electric Dryer
Dryer exhaust not blowing out of vent tubing
open it up follow the vent,it is either blocked or came off.
Dec 08, 2008 | Splendide 2100 Vented Washer-Dryer
I NEED FAULT CODES FOR DRYERS
PF Power Failure
“PF”
flashes to indicate that a power failure occurred while the dryer was
running. Press START to continue the cycle, or press PAUSE/CANCEL to
clear the display.
F-01 Primary Control Failure “F-01” flashes when there is a primary control failure. Replace the machine
control electronics. See Accessing & Removing the Electronic Assemblies.
F-02 Keypad/User Interface
Failure
“F-02”
flashes when there is a stuck button or user interface mismatch. This
fault code will ONLY appear when in the diagnostic test mode. See TEST #5.
F-22 Exhaust Thermistor Open “F-22” flashes if the thermistor is open. See TEST #3a.
F-23 Exhaust Thermistor Shorted “F-23” flashes if the thermistor has shorted. See TEST #3a.
F-26 Motor Drive System Failure “F-26” flashes if there is a motor drive system failure. See TEST #2.
F-28 Moisture Sensor Open “F-28” flashes if the moisture sensor strip is open. This fault code will ONLY
appear when in the diagnostic test mode. See TEST #4.
F-29 Moisture Sensor Shorted “F-29” flashes if the moisture sensor strip has shorted. This fault code will
ONLY appear when in the diagnostic test mode. See TEST #4.
1M 2M 3M 5M 6M
= Contacts closed
Contacts
Function
Start
Run Red
Lt. Blue
Blue-White (Elec)
White (Gas)
Green-Yellow
Red
Black-White
BLACK
BLUE
WHITE BLUE
WHITE
WHITE
Pluggable Drive Motor Switch Gas Valve - Gas Dryer
Centrifugal Switch (Motor)
Gas Valve this is about close as i can come its matag electronic but not comercial should be about the same software though some where on or in the dryer should be a tech sheet with codes
May 21, 2008 | Maytag Neptune MDE5500AY Electric Dryer
Display reads F22, dryer shuts off after 1 minute
To enter the diagnostic mode, choose any selector button other than Pause/Cancel and do this little keyboard dance:
Press and hold for three seconds,
release for three seconds;
press and hold for three seconds,
press and hold for three seconds.
You’ll know you’ve entered diagnostic mode because all the indicators on the console will light up for five seconds and you’ll see the code “88” in the Estimated Time Remaining display.
the F22 Code you are getting is the exhaust block or overheat!!! DO NOT USE YOUR DRYER UNTIL YOU CLEAN THE EXHAUST OUT! this is a MAJOR fire hazard
it may also be as simple as a lose wire or something like a bad sensor but chances are that your dryer is doing what its supposed to so that you dont have a fire :)
~lee
admin @ WhyPayForHelp.org
Apr 29, 2008 | Dryers
Dryers Logo
466 people viewed this question
Top Dryers Experts
