Question about Lowrance GPS
I have a Lowrance X55A that has a spotty LCD display.. vertical lines throughout the display. I was looking to disassemble it to see if the display has a loose connection or if a new one can be found.
  • wayne656 Jul 13, 2009
    Here is a picture of the Front... No screws seen at all.
    Here is a picture of the Rear.. I removed the screw found at the arrow...
    The case seems to be sealed...
  • wayne656 Jul 14, 2009
    There are no screws to take it apart. Has anyone ever disassembled one of these before?
    President:
  • 2,777 Answers
The case for this unit is sealed, to get into the case you will need to literally pry it open. If you are certain you are no longer under warranty then I suppose you could try this. However it's definitely not recommend.
I can tell you right now the connection for the screen is not loose, it's a digital connection so either you get something on the screen or you don't. It sounds like LCD failure for certain. Your best bet is to contact Lowrance for repairs / replacement. If you do get it apart, and you somehow order just an LCD for the unit, you will never really get it to go back together again the way it should. I definitely recommend you speak with Lawrance.
Thanks
Tim
Posted on Jul 14, 2009
  • 13,433 Answers
Hi
I've never seen any displays for these being sold outside of the dealers.
http://www.lowrance.com/en/Dealer-Locator/
Here is the dealer locator, they should have replacement parts.
As for instructions, just start by taking out all screws you find from the unit also look under soft objects and labels for screws, the cover will most likely be hold in place with plastic clips that will snap open with a small flat screwdriver.
I assume your outside of warranty, if your in warranty you don't want to take it apart.
Posted on Jul 13, 2009
  • Ekse Jul 13, 2009
  • Ekse Jul 13, 2009
    Contact a local dealer and see how much the screen replacement would cost.
    possibly glue is used to keep the cover together and so water doesn't get inside.
Why are there vertical colored lines all over screen?
Thin vertical lines cover screen on Samsung LCD - AVS Forum ' Home ...
www.avsforum.com/...lcd-flat-panel.../1127410-thin-vertical-lines-cover...
Mar 7, 2009 - 30 posts - ‎25 authors
I have read there could be ribbon cable connection issues so I plan to .... I have a VizioVW22LHD TV,I hooked it up using a HDMI cable to my Toshiba satellite laptop. ... If you have thin multi-colored vertical lines on your tv panel, that do ... my TV on the thin vertical lines come all over the screen and the TV ... my VIZIO E470i-A0 LED has vertical colored lines on ...
Nov 18, 2013
Vizio SV370XVT lines throughout entire display. Not ...
Aug 3, 2012
Thin vertical line on LCD tv
Dec 29, 2007
More results from www.avsforum.com
Vizio P50HDTV Display Problems - Colored Vertical Lines .
Dec 30, 2015 | Vizio Televison & Video
There is a red tint displayed throughout the picture
Main baord or even power supply are possible with main being most likely.
Jun 02, 2012 | Samsung LN40A630 40 in. LCD TV
Lcd screen has lines in the middle area (3" wide
Laptop screen display problems occur for many different reasons. Some issues need professional attention, but others can be repaired by the owner. A screen that displays vertical lines often means that there is a problem with the video cable connection to the LCD screen, or the cable itself. In order to repair this problem, the display screen must be disassembled. If you feel confident that this task is within your realm of expertise, follow the steps below to remove your laptop's LCD panel and fix the vertical line problem on your laptop screen.
1. Remove the rubber seals covering the screws on your screen's outer frame using a flat-head screwdriver. Remove the screws, then carefully pry the frame from the screen using your fingers. Release the plastic latches holding the framing in place, then remove.
2. Remove the screws holding the screen to the support brackets. You will see the video cable, which is attached to the back of the LCD screen. Try unplugging and reconnecting this cable, making sure that it is seated properly. If the problem was the connection, this may solve the vertical line issue.
3. Turn on the laptop. Move the video cable around a bit, without moving or touching the screen. Check the screen to see if the display image changes at all. If it does, the problem may be with the cable itself.
4. Move the laptop screen around to see if this affects the display. If so, the problem is most likely with the LCD screen itself, not the video cable. Replacing the screen will be necessary.
I hope you find it very helpful. Best regards.
Aug 17, 2011 | Acer Computers & Internet
Win 7, Samsung LCD, initial BIOS display. Then vertical lines. If choose BIOS setup also scrolling vertical lines (looks like barcode) Thank you!
If the lines appear in the BIOS (Basic Input Output System) setup, you are having problem with the LCD.
Here are some parts to check. Either you need to reinsert or replace.
- LCD cable
- LCD inverter
- LCD itself
Note: The LCD inverter fails often than other LCD assemblies.
Hope this helps.
Jun 27, 2011 | Computers & Internet
Screen has multi color vertical lines, no discernable image...dead? Does same thing on muliple computers.
Vertical lines from top to bottom is the indication of bad LCD panel. It will get worst.
Jan 07, 2010 | Computers & Internet
No image in my screen
When you ask for help, give make and model number. In this case, if display is a CRT type (cathode ray tube, not LCD), then a horizontal single line in the center of the screen indicates a lack of vertical deflection. If it is a vertical line in the center of the screen, it is a lack of horizontal deflection. Both problems can be caused by any number of components, all internal, and requires a technican to repair. Lowrance has a fixed fee system for their factory repairs. See their online info for support: http://www.lowrance.com/en/Support/Service-Information/Service-Rates/
Sep 30, 2009 | Lowrance Boating
Inspiron 1150 lines on screeN problem.
Connect an external monitor to the laptop and see if it also has the vertical lines. If the external monitor looks fine, then your laptop’s LCD display panel is bad. If the monitor has the vertical lines displayed on it, then your graphics card or motherboard is bad.
Your responses are intended to improve the level of service provided. Please show your appreciation by rating your experience.
Thank You.
Nov 10, 2008 | Dell Inspiron 1150 Latitude D600 14.1 LCD...
GPS Logo
771 people viewed this question
Top Lowrance GPS Experts
Andrew Taylor
Andrew Taylor
Are you a Lowrance GPS Expert? Answer questions, earn points and help others
