Question about Saeco Vienna SuperAutomatica Coffee Maker/Espresso Machine
Leaking Water shorts out machine
At first we noticed water on the counter and thoroughly cleaned the machine. But this did not fix the problem and the machine began shorting out. Would work for a few cups then wouldnt. I have replaced the gasket to the water tray (as we believed this to be the problem) but it has not fixed the issue. Help! We love this machine!
Re: Leaking Water shorts out machine
I had the same problem. What may be the problem is the tiny water drip hole that feeds the drip tray is blocked with coffee sludge. Open the machine and remove the dump bucket, drip tray, and the brew group. Behind the brew group is a flat plastic piece which has a small drip hole at the bottom of it. This may be blocked which causes the water that should go into the drip tray to build up and overflow inside the machine running onto the countertop. Clean out the area behind the little drip hole and the hole itself. This should cure it.
Posted on Dec 08, 2007
I had the same problem after 4 years of use. At first it leaked a little bit, but made good coffee. Eventually it leaked a lot more and would short out. I sent it for repair and they replaced the boiler, which was cracked, which solved teh big leak/shorting problem. But it continued to have the smaller leak. I suspect there is a tube or valve with a leak. Wish I could run it with the case off to observe where the leak is.
Posted on Dec 10, 2007
  • Saeco Expert
  • 223 Answers
You probably have an internal leak. You should have a service center look at it.
Buy Vienna Deluxe Reconditioned.
Service Center for New York
Posted on Nov 17, 2007
0 characters
3 Points
KitchenAid Pro Line espresso machine leaking water onto counter after repeated shots
I keep hearing how this machine makes great crema but I'm about ready to toss my machine in the dump. It seems like the water comes out way too fast no matter how I work the grinds or tamp it. Can someone contact me about what might be wrong?
Dec 26, 2012 | KitchenAid PRO LINE KPES100PM Espresso...
Leaking from the bottom
If it does it whenever the tank is put on the machine then the hose from the tank is disconnected.
If it does it when the machine is brewing coffee or after, then clean the chamber behind the brew unit, under the white plastic valve.
If it is leaking when making steam or hot water then the booster boilerhas a leak.
Mar 07, 2010 | Saeco Vienna De Luxe Espresso Machine
Water is leaking internally onto the countertop and none going into the cup on solis master 5000
You boiler is leaking and needs to be replaced. Check or ebay for replacements.
Dec 11, 2009 | Solis Master 5000 Espresso Machine
Why would there be internal leaking into the tray
Never use vinegar to clean your machine. It is possible that the orings are worn out on the brew unit.
Nov 30, 2009 | Starbucks Saeco Italia Digital Barista...
Bunn coffee maker leaks all over the counter. What
there's probably a 'silicon rubber' hose that feeds hot water to the 'grounds basket'- it may be loose, or damaged. is it leaking water, or coffee?? we have a bunn 8-cup, which has a pre-heated water tank that brews a pot in about 3 min. energy waster, but when you need coffee, you need coffee!!! is your filter holder properly centered? is the carafe lid hole clean and un-obstructed?
if it's leaking water, and not too costly to replace- you may consider replacing it with a new one!
good luck!
Oct 09, 2009 | Bunn GRX-B Original 10-Cup Home Coffee...
Saeco magic deluxe is leaking water
Either two faults, one is that the boiler is leaking ( fix this straight away as water can spray on main circuit board and short out ) very costly to repair if both needs replacing. Second the water runoff to the front tray is blocked with coffee grime . Instead of the water left over when the brewer dissengages running off to the front tray it overflows into the machine. Hope this helps
Aug 10, 2009 | Saeco Magic De Luxe Espresso Machine
The machine leaks water all over the counter when starting brew
My keurig did the same thing, the rubber grommet around the part that punctures the cup gets grounds on it and prevents a complete seal. Pop of the grommet and clean it and it will be good as new.
Mar 14, 2009 | Keurig B70 Coffee Maker
Machine stopped working
This machine is piece of s... I replaced two of them so far and experienced same problem.:
Machine works fine couple days
...than it start dispensing less water into the cup.
...than it stop dispensing water into cup completely and instead all water goes into the tray.
..The pump also starts occasionaly to make interrupted repetative sound.
Did anybody get it fixed?
Jan 05, 2008 | Krups XP2070 10 cup Coffee Maker/15 bar...
Saeco Vienna leaking
We had this problem and it was overflow from a clog -- check the hole where excess water drains into the drip tray to see if it is full of grounds. Cleaned it out with a twistie tie and flushed w/ water. That stopped the water on our counter!
Oct 16, 2007 | Saeco Vienna SuperAutomatica Coffee...
Saeco Vienna SuperAutomatica Coffee Maker/Espresso Machine Logo
562 people viewed this question
Top Saeco Coffee Makers & Espresso Machines Experts
Ernest R
Ernest R
Mike Cairns
Mike Cairns
Ray Murphy
Are you a Saeco Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
