Question about Sony NW-E505 MP3 Player
Every thing i put in it i cann't found , just no data & no item !! what can i do ???
    Genius:
  • Sony Master
  • 1,550 Answers
Get it formatted
Posted on Jul 13, 2009
Why does the service engine soon light flash when nothing can be found when put on an analyzer?
If you have a MIL Lamp on your dash, you have
codes in the system or data there to use
When it flashes, you do not use the vehicle
You find & repair the problems or ruin your converters
or other items
Sep 30, 2014 | 1999 Dodge Avenger
1999 Crown Victoria running rough after trans rebuild?
Real simple
Put a professional scan tool into the under dash connector
Road test
Look at data & then properly diagnose ANY problems & resolve
Why a local shop or a dealer is stumped is beyond me
IF-you do a cylinder leak down test & have no mechanical
valve sealing issues
Then you use any evap smoke machine to check for vacuum leaks
on the entire vehicle
You then look at & test all electrical system items needed
Then you review all emission monitors,fuel trim,fuel pressure,
oxygen sensor voltage & much more
Cylinder misfires etc
You do two thing
You get all the data avail with & without a road test from the scan tool
Then you must component test using an oscilloscope until some
problem is found
I believe not much that should have been done was regardless
of order or sequence
So far no one tried to find a problem or had the knowledge to do so
You may simply have a worn out & blocked exhaust converter
They last a long time but not form 1999 to 2014
Aug 08, 2014 | 1999 Ford Crown Victoria
How can i reset 2007 Chevy Equinox service air bag light ?
Reset (clear) a dash light ---AFTER--- a problem has been
found & repaired ?
Best to use a code reader or professional scan tool,
so you do not loose data & items you my need
Clearing a dash light is NOT A FIX for ANYTHING
It will come back until you find & resolve the issues
As is--- you have-- NO Air Bag Protection--IT IS TURNED OFF
Jul 08, 2014 | 1999 Dodge Ram
Initial value contains and invalid value & the standard value is set (Entry = Double side) (Code S310011)
Hello Peggy,
This error message is Twain Driver error. The cause is that a value outside the range or an invalid character was found among the items in the initial value data file. (Item XXXXX indicated by Entry=XXXXX)
If the file was intentionally changed, the value set for that item may be incorrect. If the file was not intentionally changed, the file may be corrupt. The value has been set to the standard value. The file must be written again, for assistance, please see "Initial Value File" in the "Operator's Guide".
A hard disk check (chkdsk or scandisk) and virus check must be performed regularly.
Hope this helps.
Thanks & regards,
ScanCare
Jan 22, 2014 | Fujitsu Fi-6140 High Performance Color...
When start to set up my new computersaw windows 7 wasn't install and there was window 7 disc in box i intsalled it when it got to enter product key it froze and cann,t do any thing
Go here, and follow the section on "Recovery from the startup screen (during system boot)" and see if that helps. If there is a Factory Reset Partition, this procedure will put your machine back to how it was shipped. You will probably still have Windows 7 setup questions to answer the first time.
http://h10025.www1.hp.com/ewfrf/wc/document?cc=us&lc=en&dlc=en&docname=c01867418#N476
Dec 08, 2012 | HP Compaq dc7600 PC Desktop
I have electrical problems with my windows and cann't find the fuse
On most electrical problems like this The fuse is likely at fault. They put 2 or 3 items together on one circuit. For example ( windows mirrors locks) on one fuse usually 15 amp. This is why you could not find it. If you have owners manual look at fuse pannel. Good luck.
Aug 05, 2011 | 1996 Toyota Corolla
How many watts load in this amp
1300 W/ch @ 4 ohms
775 W/ch @ 8 ohms
2650 W bridged @ 8 ohms
I found a retailer that provided this data - found below:
http://www.zzounds.com/item--PEVPV3800
Sep 29, 2009 | Peavey PV-3800 2-Channel Amplifier
I cann not transfer video to my compüter
U need to install 3GP software in your PC inorder to transfer video to pc.
Regards,
Madhan
Sep 23, 2009 | Kodak EasyShare C743 Digital Camera
Unable to import text file to access table
Hey everyone, I was able to fix my problem using the following:
filnam = Me![Text2]
Set objFile = CreateObject("Scripting.FileSystemObject")
Set objText = objFile.OpenTextFile(filnam)
Set rs = CurrentDb.OpenRecordset("FlatFileImport")
once = False
If Not IsNull(Me.Text2) Then filnam = Me.Text2
Open filnam For Binary As #1
Do While Not objText.AtEndOfStream
strTextLine = objText.Readline
Data = Split(strTextLine, ",")
If once Then
rs.AddNew
rs.Fields(1) = Data(0) 'Site ID
rs.Fields(2) = Data(1) 'Client ID
rs.Fields(3) = Data(2) 'Client Name
rs.Fields(4) = Data(3) 'DDA Account
rs.Fields(5) = Data(4) 'Process Date
rs.Fields(6) = Data(5) 'Good Checks Singles
rs.Fields(7) = Data(6) 'Good Checks Stubs
rs.Fields(8) = Data(7) 'Good Checks Partial
rs.Fields(9) = Data(8) 'Good Stubs Partial
rs.Fields(10) = Data(9) 'Good Checks Multi
rs.Fields(11) = Data(10) 'Good Stubs Multi
rs.Fields(12) = Data(11) 'Check Only Checks
rs.Fields(13) = Data(12) 'Check Only Stubs
rs.Fields(14) = Data(13) 'Check And List Stubs
rs.Fields(15) = Data(14) 'Check And List Checks
rs.Fields(16) = Data(15) 'Suspense Checks
rs.Fields(17) = Data(16) 'Suspense Stubs
rs.Fields(18) = Data(17) 'Correspondence
rs.Fields(19) = Data(18) 'Envelopes
rs.Fields(20) = Data(19) 'Express Mail
rs.Fields(21) = Data(20) 'Lookup Stubs
rs.Fields(22) = Data(21) 'Online Lookups
rs.Fields(23) = Data(22) 'Stubs Only
rs.Fields(24) = Data(23) 'StopFile Hits
rs.Fields(25) = Data(24) 'SLC
rs.Fields(26) = Data(25) 'SL2
rs.Fields(27) = Data(26) 'MICR Scanline
rs.Fields(28) = Data(27) 'KeyStrokes Correspondence
rs.Fields(29) = Data(28) 'Keystrokes SLC
rs.Fields(30) = Data(29) 'Keystrokes SL2
rs.Fields(39) = Data(38) 'Exception Queue
rs.Fields(40) = Data(39) 'COA Queue
'IMAGE ARCHIVE ITEMS
rs.Fields(41) = Data(40) 'Image Archive Reports
rs.Fields(42) = Data(41) 'Image Archive Storage
'BATCHES PROCESSED
rs.Fields(43) = Data(42) 'Batches Processed
'ARC ITEMS
rs.Fields(44) = Data(43) 'Low Speed ARC Attempts
rs.Fields(45) = Data(44) 'High Speed ARC Attempts
rs.Fields(46) = Data(45) 'Low Speed ARC Converted
rs.Fields(47) = Data(46) 'High Speed ARC Converted
'ICL ITEMS
rs.Fields(48) = Data(47) 'ICL Attempts
rs.Fields(49) = Data(48) 'ICL Converted
rs.Fields(50) = Data(49) 'ICL Non-Conforming images
'RETURN ITEMS
rs.Fields(51) = Data(50) 'Auto Returns
rs.Fields(52) = Data(51) 'Returned Items
'POSITIVE POST (CDM) ITEMS
rs.Fields(53) = Data(52) 'Positive Post Checks
rs.Fields(54) = Data(53) 'Positive Post Stubs
'REMOTE PAYMENT CAPTURE ITEMS
rs.Fields(55) = Data(54) 'Remote Payment Single Checks
rs.Fields(56) = Data(55) 'Remote Payment Single Stubs
rs.Fields(57) = Data(56) 'Remote Payment Multi Checks
rs.Fields(58) = Data(57) 'Remote Payment Multi Stubs
rs.Fields(59) = Data(58) 'Remote Payment Check Only Checks
rs.Fields(60) = Data(59) 'Remote Payment Check Only Stubs
rs.Fields(61) = Data(60) 'Remote Payment Check & List Checks
rs.Fields(62) = Data(61) 'Remote Payment Check & List Stubs
'DOLLAR DEPOSTIED & PP CORRO REJECT ITEMS
rs.Fields(71) = Data(70) 'Dollars Deposited
rs.Fields(72) = Data(71) 'PP Corro Rejects
rs.Update
End If
once = True
MyLine = ""
MyLine = MyLine & ch
MyLocation = Loc(1)
Loop
MsgBox " File has been successfully imported! "
Close #1 ' Close file.
rs.Close
'close and erase the file from memory
objText.Close
Set objText = Nothing
Set rs = Nothing
Sep 08, 2009 | Microsoft Access 2003 for PC
I forgot my nokia n73 security code or lock code
Prodigal brother you have. Go to the nearest Nokia Care and have the firmware re-installed. A word of caution, remove the memory card. You will loose all the data on the phone. And in furute use a password only as an extreme. And it should be such which you can remember even under extreme conditions and need not write it down.
Jul 29, 2009 | Nokia N73 Cellular Phone
Sony NW-E505 MP3 Player Logo
137 people viewed this question
Top Sony Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a Sony Audio Player and Recorder Expert? Answer questions, earn points and help others
