Question about TruTech T650-DR DVD Recorder
Pause Protected This is specifically for the TruTech T650-DR DVD Recorder: I have already recorded two VHS tapes onto DVD+Rs using this TruTech recorder.  This morning I have put in two different fresh DVD+R discs to record a movie from my VHS player.  I've gone through all the proper set-up procedures. However, when I hit Play on the VHS and Record on the DVD recorder, I get a box on the screen saying PAUSE PROTECTED, and I see that the recording has stopped at 0:01.   I have not touched anything that would activate a PAUSE PROTECTED mode, and I can't find anything in the Instruction Manual that tells me how to undo this problem.  Any advice is greatly appreciated.
  • Anonymous Feb 23, 2008
    I get pause protected and protected source errors.. I have triple checked and I can't get it to record after the 1 time it did work properly.
    I think I will that the advice to return to Target.
I believe your unit is objecting to the quality of input, but can't tell you if you can adjust the sensitivity for that unit. IOW your first two recordings worked because you were getting higher quality to the Recorder. Perhaps they were better quality tapes or perhaps you have since introduced a line problem (poor connection).
Posted on Feb 02, 2008
  • 934 Answers
Dbronx,
You might try unplugging the unit for several minutes in an attempt to reset the logics from ROM... TruTech is just one of those WallyWorld/Target specials that have very little support and breakdown frequently.. If I might suggest, it sounds as though you haven't had this unit long - take it back and get your money for it and go out and get a major player in the market. At least when it breaks you can more easily get some support...
A lot of these off-brands we get in here for repair just aren't worth the time and effort to repair and you would be surprised how many brands there are...
Bill
Posted on Nov 16, 2007
Magnavox ZV450MW8A DVD/VCR Recorder Dubbing.
I bought a ;magnavox dvd disc and cassette recorder combo.
I am having trouble with setup items? I get nothing on the screen to select from?
Oct 24, 2009 | Televison & Video
I have a JVC DR MV7SU DVD/Video recorder. How do
If your camcorder allows you to connect to a tv or vcr and allows you to record from it to the camcorder via the rca video input, then you should be able to record it that.  The camcorder must have the RCA audio/video inputs on it to be successful.
enov8
Mar 08, 2009 | JVC Televison & Video
Lost remote
Searching online I found a web site that you may order a replacement remote, however this web site no longer carries the T650-DR remote but they do carry a substitute.
http://remotes.com/remotes/servlet/rs?a=gmi&uuid=A12145901412461&smodel=T650DR&brand_pn=TRUTECH_T650DR
if the link does not work, go to http://remotes.com and in the top left search for T650-DR to find the replacement. Hope this helps, post back.
Jun 27, 2008 | TruTech T650-DR DVD Recorder
Dubbing from vcr to vcr
Connect with RCA cable to RCA jacks\plugs::
output [player] audio to INPUT [recorder]
OUTPUT [player] Video to INPUT [recorder]
Place blank tape in RECORDER, Tape that you want to record from into PLAYER.Press Record [recorder machine], wait one second, press PAUSE.( thats to give record tape "breathing" space.) Set up your player tape to start playing. When you know what you want to record, press PAUSE again to begining recording. Press PAUSE after the recorded section to install 2nd tape, etc. etc.
NOTE:: some VCRs use PAUSE 2nd time to release and continue recording, while some machines you must press RECORD button again to release PAUSE. you must expirement before begining your project.
May 24, 2008 | Zenith VCS442 VHS VCR
HELP
There should be no problem with copying home recorded VHS tapes to DVD via the Scart or Video (yellow) output. It may be obvious but have you tried recording directly from other sources such as TV etc. Apologies if this is a trivial suggestion!
Cheers
Apr 04, 2008 | TruTech T650-DR DVD Recorder
Trutech dvd-r
Set it for antenna and use the single channel it sends to your TV, which is the only signal coming out of your cable box
Feb 18, 2008 | TruTech T650-DR DVD Recorder
I need the 3-digit setup Code for Trutech T650-DR DVD
Note: In order for you to watch your TV your TruTech T650-DR must be on. Not shure what you mean by code? but setup go,s like this.
Out DISHNET to in on your Trutech T650-DR
Out TruTech T650-DR to in TV Note: the name of the input on your TV video 1 or video 2.
Just like your DISHNET you need to be on Ch 3 or 4 what ever is open.
turn on your DISHNET and your Trutech T650-DR Do you see a Trutech logo on your TV?
If yes, Keep pressing the source Button on your Trutech T650-DR remote Tell you have a TV Ch. then press the return button.
use your DISHNET remote to watch your tv.
thats it hope I could help.
Jan 31, 2008 | TruTech T650-DR DVD Recorder
How to burn a dvd from a JVC Hard disk drive recorder
Make sure you plug your camcorder into the in on the dvd recorder. Make sure the dvd recorder is set to that input. you may need to hook it up to a tv and make sure you see your camera on the tv going through the dvd recorded to make sure you have it on the right setting. Make sure you camera has playback out turned on.
Jan 21, 2008 | TruTech T650-DR DVD Recorder
Auto Tuning Problem
Wow sounds like you got a bad box,
Frist your Trutech needs to be set to Ch 3 or 4 what ever is open. if you dont see a Trutech Logo on your TV, then you need to go back to your TV and find the input Ch to your Trutech T650-DR.
If you do see the Trutech Logo then next on your Trutech T650-DR remote keep pressing the source button tell you see A Cable Ch. then press the return button.
Thats It hope I could help.
Dec 25, 2007 | TruTech T650-DR DVD Recorder
Audio static through DVD Recorder
I your TruTech T650-DR is geting real hot turn it off its over heating.
If thats the case then your not setup right. What ever is gonig on dont keep using it, its gonig to burn out. cheek to make shure you have every thing plug in right.
Oct 17, 2007 | TruTech T650-DR DVD Recorder
TruTech T650-DR DVD Recorder Logo
133 people viewed this question
Top TruTech Televison & Video Experts
Jason Morris
Are you a TruTech Televison and Video Expert? Answer questions, earn points and help others
