I have a color TV, model # DW 19TT. Can not get it to come on. Seems like there is no power getting to the set. Suggestions???? Help????
  • 37 Answers
Internal fuse on pcb may have blown.
Posted on Jul 13, 2009
Color settings for an older panasonic tv
a model number would help to give an informed answer.
Dec 04, 2012 | Panasonic Televison & Video
Mitsubishi projector tv power won't come on
I owned one. Wish I could remember the Model, but when the Lightbulb starts going out, the unit will be extremely hard to turn on.
We had a Model with a part called a "Light Engine". Mitsubushi made a Court settlemment because of the defective part within this unit. Seems that the "Light Engine" had a color wheel, a power part and a Motherboard. But they did not make enough of the Motherboards to service the TV's, just enough to build new sets.
We replaced several Lightbulbs and often toggled the remote and held the ON button until the TV regained its' senses. We later had to leave the set on 24/7 or had to fight with it to turn it on.
Our TV's last gasp was a condition called "clouding" which is like a Halo effect around the main images and sometimes tinted with one dominate color or the other.
You can get the lightbulbs online witha Web search. You may want to Browser in your set to find out if it was one of the bad Models.
Jan 15, 2012 | Mitsubishi Televison & Video
We have a Phillips rear projection tv, about 9 years old. The color has been getting progressively worse over time. Dark scenes are almost impossible to see. It almost seems that only blue and red are...
Tv have halo pictures and dulls colors?Yes,the tv have bad Coolant chemicals on those colors guns R,G,B CRTS tv Tubes.Must replaced those CRTS Coolant chemicals on those CRTS tv tubes.Tries websites like Tvrepairworld.com,Tvrepairkits.com to buy a Coolant kit to replaced those CRTS tv Tubes coolant chemicals.
Nov 13, 2010 | Philips 55PW9363 55" Rear Projection...
I have problems it seems when the TV is on for an hour or less the picture starts to flash and then change colors. A normal football field starts out green then it after flashing turns brown and all the...
capacitor parts replacements must be done at power circuit,because not performing properly...worn out due to age...a normal situation for appliances..
Dec 31, 2009 | Televison & Video
I have a Samsung rear projection TV (model number HL-R4667W) that just started making a loud humming noise. The picture seems to dim in and out, along with the color. The fan seems to be working. Any...
I can feel your power supply is going to get short!!!1 check it .. and check it on another device a dvd or satellite maybe your tv is not guilty!!
Aug 09, 2008 | Televison & Video
Suddenly, the screen shows double images on letters and numbers plus red/greenish like shadows on characters.
Youre convergence Ics need to be replaced. post the model number of your set and I will post the STK number that you need and a link where you can get new replacement ICs
May 25, 2008 | JVC AV-48WP30 48" Rear Projection...
My HDTV wont turn on, two weeks ago the colors blend together I wasen't able to adjuste the colors. then I turn it off and leave for two weeks. when I try to turn it on it wont turn on, the control panel...
It seems that you have an issue with the power board. You could also have faulty convergence modules causing the blending of colors.
I wouldn't advise you to open the set yourself, because of the complicated circuitry and high voltage. It is safest and best to get TV repairman to look at this issue and provide a fix/repair.
May 31, 2008 | RCA Televison & Video
Toshiba Plasma TV Green and Pink (Diffusion?) Problem
I could be wrong but sounds like your plasma display is going bad. What is your model number?
Dec 28, 2007 | Toshiba 42HP66 42 in. LCD Television
PT5499HD Covergence Akai
Yes, you have a size problem you have horizontal and vertical size. Either its' in the service mode or somewhere on the set, with this set it's probably in menu. Must be set too high. I will look for menu codes! Is this an Akai or Panasonic set?
Oct 04, 2007 | Panasonic PT-47WX49 47" Rear Projection...
Color on projection tv 9P6040-C104
The cooling fluid in the CRT's need to be replaced. This is a common issue with NAP projection TV's. The old fluid needs to be drained then the CRT faces cleaned then refill with new fluid.
Jan 25, 2007 | Philips Magnavox 9P6034C 60" Rear...
Televison & Video Logo
27 people viewed this question
Top Televison & Video Experts
Electro Med Services...
