Question about GE 24 in. GLD5560LSS Stainless Steel Built-in Dishwasher
Variable draining...sometimes there is water at bottom, sometimes dry..doesn't seem related to type of wash cycle.
  • 51 Answers
There is a drain hose for your dishwasher that often gets clogged. Remove the drain hose and clean it out. reinstall the hose and your dishwasher will drain. The dishwasher should have a panel to remove and then comes out easily, just be careful not to pull it out too far. If this does not fixya then you may need to throw some parts at it, but hopefully not. Good luck
Posted on Jul 13, 2009
Malber WD1000 wont condense the water that is fed through during the drying cycle
Since it drains properly during the wash cycle, we know the drain pump and its impeller (propeller) work, and the coin trap (you called it a filter) and hoses are not clogged. By the way, turning the rightmost knob to "4" will start the pump-out cycle, so you don't have to open that trap-door at the bottom. To condense, the machine needs COLD water (spritzing on an internal screen) during drying. Make sure your cold water hose is connected to the outside (outboard) connection on the back of the machine. As a long shot: If the gray drain hose is pushed too far down into your home's drain pipe (more than 8") there could be a "back-siphon" where dirty water siphons back into the washer. It's a long shot, but it does happen.
Lastly, the controller board (mounted at top of right side) could be bad, and not sending on-off commands to the pump during drying. During drying, the drain pump should cycle on and off constantly, every few minutes. Do you hear it running? If you remove back (about 12 Torx screws), at your lower left you will see the pump. There are only 2 wires (120 VAC) and they can be connected either way. Stick a meter on the terminals and see if power is cycling on and off. If not, the controller board is bad.
You can order one from Malber (in NYC) by calling Nancy at 516-323-5299. Tell her Mike, in Wash. D.C., says hi.
Mar 06, 2015 | Malber WD1000 Front Load Washer/Dryer
Knocking noise when running. Sometimes the drum has water left in the bottom after a cycle. And now it has begun to leak from the bottom.
It is possible that the machine does not start off the cycle because there are errors due to feedback from the inputs. For the program to start up the main program controller must initiate the INLET/MOTOR/DRAIN pump/ valve to open up and allow each function to be driven starting from the flow of water into the drum as also the drain valve to open to exit the water at the point of the program cycle. If this does not happen then the voltage at the valve/motor/pump must be checked or the fault relates to no voltage from the controller. This means the controller is a suspect.
If the water flows though the inlet then the flow pressure should be good, if not the inlet valve is bad or there is dirt in the filter. Also check the flow at the inlet of the water line. Once the water comes into the system the WATER LEVEL SENSOR - normally a pressure switch- must activate at the preset/chosen level to give the signal to the program controller to switch on the motor. What is most important for the motor to start functioning is that the door switch must be ON when the door is shut or this will be an error for starting the motor for rinse and wash.
Check this link to replace the inlet valve:
http://www.espares.co.uk/advice/washing-machines/a/7/1408/how-to-replace-the-inlet-valve-on-a-washer-dr.html
Finally after the wash the drain valve will be activated, the water is allowed to come in to rinse and then finally the dry spin with the drain valve/pump activated so as to drain off all the water from the clothes during the spin.
Make sure that a fault in any of the cycle will relate to the specified action, so check the command from the program module and then the executing device be it the valve or motor or pump.
Please check the link below:
http://www.repairclinic.com/Washing-Machine-Troubleshooting?red=Washing-Machine-Repair-Help
Dec 11, 2012 | Kenmore 49972 Front Load Washer
My washing machine doesn't start sometimes it starts after many trials by moving it. thanks in advance.
It is possible that the machine does not start off the cycle because there are errors or back feedback from the inputs. For the program to start up the main program controller must initiate the INLET valve to open up and allow water to flow into. If this does not happen then the voltage at the inlet valve must be checked or the fault relates to no voltage from the controller. This means the controller is a suspect.
If the water flows then the flow should be good, if not the inlet valve is bad or there is dirt in the filter. Also check the flow at the inlet of the water line. Once the water comes into the system the WATER LEVEL SENSOR - normally a pressure switch- must activate at the preset/chosen level to give the signal to the program controller to switch on the motor. What is most important for the motor to start functioning is that the door switch must be ON when the door is shut or this will be an error for starting the motor for rinse and wash.
Jul 07, 2011 | Haier Washing Machines
Spins but laundry is still dripping wet
This happens to me sometimes. My washing machine doesn't drain right into the drain, I have a pipe coming out of the back of the machine that I have to hook into the kitchen sink myself to let the water drain out. My washing machine was still full and I realized that it was because my sink was a little blocked and so it was draining too slowly and leaving water in the machine. If there was too much water, it would sometimes help to put the machine on again or put it on a drain cycle. My machine doesn't have a spin cycle so it will just give your clothes an extra spin so I couldn't do that and my clothes would still come out dripping wet. I advise that you give them another spin before you take them out if possible! xxThe fact that the washing machine is spinning but not drying clothes shows that there is some problem with the outlet of water. The water outlet is blocked. You can check for the blockage yourself. Normally threads or other waste accumulate in the water outlet, and if possible you can remove it yourself. Otherwise call your washing machine's customer services center and ask them to send a repair man
May 01, 2011 | Smeg Washing Machines
When the dishwasher finishes runing complete cycle there is water in the bottom that will not drain out
if the amt of water exceeds 2-3 cups,you may have a drain restriction,usually plumbing related. if the water left over is no more than a cup or so this is normal to keep motor sump area saturized to prevent dry rotting of seals
Nov 13, 2009 | Bosch Nexxt 500 WFMC3301 Front Load Washer
Kenmore 22062 will not cycle correctly
Problem fixed. I took apart the bottom of the washer to access the pump, and found that there was underwire from bras stuck in the discharge tube blocking the water from exiting the washer and that was causing the cycle problem. I guess that the washer knew that there was too much water in the tub and kept trying to expel it.
Nov 14, 2008 | Kenmore 22062 Top Load Washer
LG all in one washer dryer fills with water on the drying cycle
the unit is made to bring water in in the drying cycle ,,the water dont touch the clothes..the water is to take the lint away and to cool the drum,,you must remember that you can was 22 pounds but you can only dry 11 pound..so you must dry about half of what you wash..and drying the 11 pounds it will take 3 to 4 hours,,no exhaust...
Sep 21, 2008 | LG WD-3274RHD Front Load Washer / Dryer
Water will not drain out of the tub all the way and behind the front door bottom in the insulation seems to be wet. and the cycle seems to take a long time to run...thanks
My dishwasher, Bosch Model No. SHU9922UC/U12, Serial No. 10 0202 80447 01 0040 goes through its wash, rinse and dry cycles but sometimes there is some water remaining on the items in the upper tray and one inch or so of water remaining in the bottom of the tub. Once water leaked out onto my kitchen floor. I found some broken glass and some plastic in the circular trap at the bottom and have removed the detritus.
Jul 29, 2008 | Dishwashers
EZ 3612 CEE Water Not Draining Completely After Dry Cycle
ChicagoRandy,
You may be loading the washer with too many items. 8 pounds (wet) is the max for an Equator EZ3613 CEE. Mine would drain, but then wouldn't spin, leaving the clothes soaking wet. Here's what worked for me:
I turned it OFF, unplugged it for a while, emptied it of all items, plugged it back in, turned the dial to RESET, turned it ON and watched the Mode light flash quickly for a while, then watched it for over a minute, flashing about once a second, to ensure it really had reset itself. Then, I turned it OFF, turned dial to Cotton 1, turned it ON, and it performed the cycle properly when empty. When this strategy worked, it told me I had put too many items in it for it to spin.
April 5, 2008
Mar 19, 2008 | Equator EZ 3612 CEE Front Load...
WD63 Drain during wash but not dry cycle
the chances are you water valve has gone the drying cycle requires water to convert steam back to water, or poss your condenser is blocked this cant be cleaned easily better to change I dont know how competent you are if you have a muti meter you could test the soleniod which should have a resistence of around 3800 ohms. the valve is a triple one and the one that serves the condenser is the one facing downwards, disconnect power,take back off, turn water suppy off,take the 2 leads off the bottom solaniod only ,put your meter on contacts make sure you have selected crrect range on meter ie:10mohms if 0000 solanid faulty.Change valve if reading says 3800 valve ok change condenser
Aug 01, 2006 | Hotpoint Aquarius WD63 Front Load...
GE 24 in. GLD5560LSS Stainless Steel Built-in Dishwasher Logo
227 people viewed this question
Top GE Dishwashers Experts
Mike
Oloyede Monsuru
Are you a GE Dishwasher Expert? Answer questions, earn points and help others
