Question about HP LaserJet P3005n Printer
HP P3005N printing from Tray 1 and not Tray 2. Paper is in TRAY 2 but still gives message to use Tray 1. Only way to use the printer is to use Tray 1 at this time.
    Problem Solver:
  • 9 Answers
Do a cold reset and the paper trays will reset themselves, it's the easiest way. Turn printer off, turn the printer back on and as soon as you see the memory starting to count push the check mark button and HOLD IT until you see all the lights stay on. When they stay on, and you see "select language", push the arrow button until you see "cold reset", and push the check mark button again. You will be all set.
Posted on Jan 20, 2010
Hp3005 had a paper jam tray two, pulled out paper, now tray 1 keeps running pulling paper but doesnt print.
You have a pick up roller that needs replaced. If you pull the tray out, take a flashlight and look up into the printer. You will see a black roller. It probably is covered with white paper dust and slick looking. This needs replaced. That is all that is wrong.
Jan 03, 2014 | HP LaserJet P3005n Printer
Hp laserjet p2055dn tray1 manual feed problem
Go to menu, in tray tray behaving tray1 select as unless paper load,in tray2 page size as any size.. while giving print command select printer properties, goto paper/quality select paper source automatic or tray2 & shoot print command & check...
# if you are not selected tray 1 as unless paper load, it will ask paper to load after command reached to it.
# if you are not selected tray2 as any paper size, defined paper size only it will allow to print..any paper size it will print with out questing you..
Aug 01, 2012 | HP LaserJet P3005n Printer
How to make default tray 2 in HP Laserjet p3005n printer
HP printers will default to the highest numbered tray that contains plain letter paper. So on a standard 3005 Tray 2 is the default unless you have the paper type set for something other than plain letter. If you have an additional tray, then Tray 3 would become the default tray if it is set to plain paper. In this case, you would set tray 3 to either bond or letterhead so that the printer would only grab from that tray if you request either tray 3 be used or create a job that calls for that type of paper.
If this does not sort it out, post back again with a complete description of the printer including number of trays, what is loaded in the trays and how they are set for both paper size and paper type. This information can be found by printing a configuration page. This is done by pressing the arrow key on the control panel until display reads information, press checkmark (green button) then use down arrow until Configuration page is displayed and then press checkmark again. Page will print that shows all the settings for the printer.
May 08, 2011 | HP LaserJet P3005n Printer
Is this a duplex machine please?
Yes it is.
HP LaserJet P3005n Printer (Q7814A)
Specs:
Duplex printing (printing on both sides of paper)
Yes: Automatic (standard)
Please give me a big thumbs up for my answer, when you rate it. Thanks.
Jan 28, 2010 | HP LaserJet P3005n Printer
Can not print to Tray 2 on HP 3800 printer. Says Tray is empty
check the paper type and the paper size from the printer menu, if it is ok then you will try to check the paper sensor on tray 2
Jan 08, 2010 | HP LaserJet 3800n Printer
HP laserjet P3005n. Cannot get jobs to print from bypass tray (1)
It could be a flag issue or sensor issue but, you should always try the easy stuff first. Check to see if the manual feed is on. To do this:
Press the check mark and arrow down to configuration menu
Press the check mark and arrow down to printing menu
Press the check mark and arrow down to manual feed, highligt the on and press the check mark.
In this setting the paper (if present) should pull from tray 1 first.
Let me know if this resolved the issue, if not, we can try another test.
Dec 14, 2009 | HP LaserJet P3005n Printer
Having problems with tray 1 picking up paper first. I need it to pickup from tray two first?
Print off the menu map from the control panel. This will give you an idea of the menu structure. Check if Manual Feed is switched off within the Printing menu.
Oct 06, 2009 | HP LaserJet P3005n Printer
Printer only sends paper to tray 1 when printing from procomm...
Sounds like a Procomm issue. Since I am not familiar with Procomm I can help you any further. But here is my analysis: All other application except for Procomm prints to tray 2. That is because all those applications use the setting as configured in your printer properties in Windows. What Procomm seems to be doing is trying to load a special paper from the manual feed tray, that is tray 1. You will have to check with in this Procomm application where you can change the printer properties so you can specify it to use tray 2 as the default. This is all within Procomm and has nothing to do with Windows nor your printer.
Apr 09, 2009 | HP LaserJet P3005n Printer
HP P3005 Will not pull from Tray 1
Click File > Print > Properties to check your settings.
To verify that tray 1 is working, put paper in tray 1. Press green check until you see Information Menu. Scroll using arrows until you see Print Menu Map then press green check. If it prints from tray 1, your problem is not with the printer, but with the PC settings.
i has follow this step, but need to press green check button to resume print menu map.
tray 1 manual feed set to A4 paper plain size
manual feed is on.
there is paper on tray 1
ps setting tray1 manual feed is A4 plain size paper.
send print to tray1 manual feed even there is paper at tray 1
i still need go to the printer and press green check button to resume print
Sep 23, 2008 | HP LaserJet P3005n Printer
P3005n
tray 2 has a little piece of cardboard that can easily be overlooked. you'll probably have to pull it out by sticking your hand in the back of the printer, tray 2. can't be done from the front because the cardboard piece keeps tray 2 stuck, and gives paper jam errors.
Sep 08, 2008 | HP LaserJet P3005n Printer
HP LaserJet P3005n Printer Logo
726 people viewed this question
Seeker5211
Seeker5211
