Question about Kenmore 63942 Dryer
Whirlpool LE4440XWW0 really wants to overheat
Good morning. I'm new to this, and so am fumbling my way through it by reading manuals and learning to use a multimeter. Now I have a lot of facts, but am not sure what they all mean. I'd really appreciate your assistance.
About 10 days ago our dryer wouldn't turn on. I went at it with a voltmeter, and seemed to have conductivity on all the Thermostat Heaters but not the thermal fuse. I swapped the fuse, and all seemed good. But, the next day the fuse blew again.
I checked the air flow at the end of the venting, and it seemed to have decent airflow. Then, I removed the vent tube altogether and held a thermometer in the exhaust immediately as it leaves the dryer. Within 5 - 10 minutes, it rose above 200' (seemed to settle around 210'). Obviously, that's much too hot, and it explains why the fuse (which, according to the writing on the side, trips at 196') blew.
I removed the chute, and cleaned out a bunch of lint. Put everything back together and retested the air temp, but it still rose above 200'.
I tested the heater coil, and saw that it was shorted against metal can in which it is housed. I removed the coil, made sure it looked undamaged, and reseated it so it wasn't touching anything it shouldn't be touching. I reinserted it, verified that it was no longer shorted, and retested the air temperature. No change - it still rose above 200'.
Now I suspected the "Thermostat Heater" (part #61894) or the "adjustable dryer cycling Thermostat Heater" (I think that's what it is called, part #660039). They are #19 and #24 on the last diagram in the parts manual:
http://shared.whirlpoolcorp.com/assets/pdfs/literature/Repair%20Part%20List%20-%203390403.pdf
If I understand their jobs, they are supposed to tell the coil when to turn on and off to regulate the heat. I tested their resistance (Rx1k) both with the dryer off and then running hot. Here's what I found:
The dryer has three heat settings: "High", "Low" and "Air". The resistance between the posts of the Thermostat Heater read as follows:
On the "High" setting:
4 ohms when off (e.g. conductive, if I understand things correctly)
4 ohms when on
On the "Low" setting:
4 ohms when off
Max resistance (e.g. 1000) when powered on
On the "Air" setting:
4 ohms when off
4 ohms when on
Then, I tested the posts of the "adjustable dryer cycling Thermostat Heater". Here's what I found:
2.5 ohms when the power is off
Max (e.g. 1000) when the power is turned on; if you turn the power off, it sort of drops a little but does not return to 2.5. If you wiggle the clips a little bit or remove the wires from them, then it drops back to 0 - 2.5.
2.5 ohms on when the power is off
About 1/2 way to max when the power is turned on; if you turn the power off, it sort of drops a little but does not return to 2.5. If you wiggle the clips a little bit or remove the wires from them, then it drops back to 0 - 2.5.
I confess, I don't know if all of this is, or whether it is indicative of some problem. I tested the cutoffs on the can around the heater coil with the power off, and they were both conductive. I haven't tested the heat setting switch yet, mostly because I'm not sure how to do it and wonder if I need to. It need be, though, I guess I can dig in and figure that out.
I would like to avoid replacing parts that don't need replacing. Can anyone tell me whether these readings are normal, or suggest where the problem is?
Thanks,
David
huuum
  • 750 Answers
SOURCE: no heat
vpflueger,
I am not sure why.
But I will tell you that at only 5 years old you should repair it.
This is a fine machine!
Try our premium service and they will fix you up!
Posted on Sep 22, 2008
  • 254 Answers
SOURCE: kenmore dryer blows thermal fuse
http://www.applianceaid.com/whirlpool-dryers.html click the link
Posted on Mar 31, 2009
  • 1122 Answers
SOURCE: dryer fuse and thermistor continue to burn out
how about bypassing the thermistor,you really only need the heater box fuse and high temp. cut out thermostat-mike
Posted on Jul 17, 2009
  • 11 Answers
SOURCE: Kenmore Dryer 110.64632300 won't heat up!
vent pipe kinked not letting heat away from dryer, check vent , or the thermostt stuck and not cycling heating element cycle off
Posted on Aug 12, 2009
SOURCE: i have a kenmore model # 110.60622990 and i
i had the same problem, it was the recepticle blew one of the hots.The dryer was getting power to everything but the heater.buy a 5 dollar tester that is meant for 240 and check both legs on it
Posted on Sep 14, 2009
Whirlpool electric double wall oven error code E2F6
Good Morning!
An E6-F2 is a very common control board failure. The control board in your appliance will need to be repaired or replaced.
Read more below about common Whirlpool oven Fault codes and what they mean. FixYourboard.com can repair this issue quickly and economically. We also back our workmanship with an industry leading two year warranty.
GBD RBD Whirlpool Oven Problems Causes and Solutions
Mar 22, 2017 | Whirlpool Ovens
1997 Honda Accord factory alarm does not go off, remote does not work, and I can't find override valet switch.
try a new FOB battery? and then do learn mode?
did you loose the operators guide, sure the PO did.
but its not really lost. its here, RTM , read the manual.
http://justgivemethedamnmanual.com/honda/
more here, called an FSM , factory service manuals.
http://hondatech.info/downloads/Auto/Manuals/Accord/
get a copy ,put it on CD, and put that in the glove box.
or better on a USB flash stick, so you wont be stranded.
i carry a spare fob at all times, (blanked out , ready for learn mode)
Oct 14, 2013 | Honda Accord Cars & Trucks
2000 Lincoln LS V8 overheats frequently. I can start it up on a cold morning drive around the block and it overheats. I believe this to be a false reading, as I can turn the heater on high and it...
radiator is probably stopped up and when you allow coolant into the heater core which is a small radiator itself. it get sufficient releive to run normal. or your sender for the temp guage is bad and the car never is really overheating.
Oct 04, 2013 | 2001 Lincoln LS
Re ignite pilot light
Must be a bad sensor. These new fangled models use electronics to sense the heat. In the place of a control klixon, they use a thermistor. The thermistor changes in resistance with changes in air temps. The fancy shocktronics upstairs monitors the thermistor for resistance. if it cannot read any resistance it shuts down. Measure the thermistor for resistance if ya cannot get a reading or it is out of spec then replace it. Another thing is the small belt on some of these falls off and the blower stops working. The dryer quickly overheats and shuts down. c89c5b39-d34b-41c4-be20-63c931f4d786.jpgYou can access a service manual by going to appliancejunkgoogledrive and accessing dryer service manual section.
Sep 18, 2013 | Whirlpool Dryers
So I wanna play black ops online I have just bought a ps3 and my boyfriend wants me to learn to play and I'm really good at a lot of things and I want to learn the game but I really would Like to know ...
That's really cute that you're willing to play with your boyfriend. Theres lots of things to learn with Black Ops. First you need to learn the controls and if you play normal or inverted. Most gametypes revolve around killing the enemy team or taking control of an objective which you will learn with time. You'll get accustomed to guns that you are good at with the various starting classes. After a while you will unlock the ability to create your own class. Then you can work towards buying stronger weapons. It is really difficult to teach a new comer everything you'll need to know about Black Ops over text but my best advice is to just play alot with random people by yourself until you feel comfortable, THEN you can play with you bf. Always keep moving, aim before you shoot, and keep shooting if they get down but they're still alive.
Good Luck, Its super addicting -Joe
Jun 06, 2011 | Video Game Consoles & Games
Need to change language
From the manufacturer's web-site: http://support.hp.com
enter '5280' and do a search.
Select your 'C5280' and select 'Downloads' or 'Documents'.
Download the User Guide, as a PDF file.
Jul 18, 2010 | HP Photosmart C5280 Printer
Car turns slowly but just wont start
Starter turning slowly sounds like:
- bad starter, or
- bad connection to starter, or
- bad connection(s) on starter relay, or
- low charge on battery, and
- and maybe some others... but these are most likely
Apr 28, 2009 | 1995 Mitsubishi Eclipse
Canon AE-1 Dark Pictures
You my friend, need a user guide. Try this link:
http://www.lensinc.net/manuals/CanonAE-1user.pdf
Pages 23-26 will cover basic shooting. There is much to learn in the world of photography, so read the manual well and practice.
Dec 30, 2008 | Canon EOS-AE-1 35mm SLR Camera
Manual
http://www.liftmaster.com/consumerweb/service/manuals
Dec 30, 2007 | Chamberlain Powerdrive PD422D 1/2 HP...
Kenmore 63942 Dryer Logo
462 people viewed this question
Top Kenmore Dryers Experts
Dan Webster
Dan Webster
Sal DeAngelo
Tim Whalen
Are you a Kenmore Dryer Expert? Answer questions, earn points and help others
