Question about ASUS P5S800-VM Motherboard
PC Restarts Hi All, I have an ASUS P5S800-VM mobo with Pentium 4 processor and 512 MB RAM.My problem is while starting the PC,it just shows the ASUS boot scren and then  restarts.I am not even able to eter into the BIOS.I tried changing the RAM,but no use.Please suggest me some solution to solve this problem....
  • Smile heart Nov 16, 2007
    i tried changing the battery with a new one.But still the same problem....
  • plshelpme Dec 24, 2007
    When it boots up it looks for sata hard drive then shuts down. I cannot get into Bios to change the setting. Mobo is Brand new. It seems like the mobo is set up to look for Sata HD by default and I cannot get into Bios to change it. Any Solution ?
  • 749 Answers
Check for the BIOS battery voltage! it should be 3 volts. if not, replace it!
Posted on Nov 16, 2007
  • Rommel Balcita Nov 19, 2007
    check the voltage of the power supply it should be:
    red = 5V + -
    yellow = 12V +-
    black = negative
    if 12V has gone down to 10.X V and 5V has gone down too, then you should try replacing it also. You should also remove some PCI-cards like SND card just to detect which causes the problem. Try also a NEW memory and don't forget to clean the memory slot and the contact point of the memory.
Is the ms 6540 motherboard compatible with the asus p5s800-vm
what u mean compatible? if u mean u want to change your ms 6540 to Asus P5S800-VM, then i tell u it cannot be done.
first thing that u look when to change mainboard is SOCKET type... ms 6540 have socket type 478 and asus p5s800-vm have socket type LGA775. thats mean your old processor cannot be use in asus. socket 478 is older than LGA775.
So if u want to change your mainboard for ASUS P5S800-vm, then u need to change your processor to... about RAM socket and VGA socket, ms 6540 have same type with ASUS P5S800 (DDR400) so u dont need to change your RAM and VGA (if u use external VGA)
hope this useful, regards.
Aug 18, 2011 | ASUS P5S800-VM Motherboard
Can I fit a dual core processor in the mobo, if so what
With this mobo this are the only processor that is compatible with it
Intel Pentium 4, Intel Celeron D
Sep 30, 2010 | ASUS P5S800-VM Motherboard
What mobo can replace ASUS P5PE-VM
the socket of you processor is lga775, the graphics port is agp and it support DDR I , so you need to buy a motherboard that has the exact specifications.
my advice is to continue with asus. you could buy an Asus P5P800/ P5S800 that is compatible with your previous motherboard. there are also some good models from asrock and they may be cheaper than asus.
the problem with this type of motherboard is that they are expensive because that are not in use.
Dec 20, 2009 | ASUS P5PE-VM Motherboard
I have an ASUS P5S800-VM Motherboard socket LGA775
To answer your question, yes it's possible.
I'm sure you wouldn't like it if I left it at that, so I'll explain a bit more.
It's about as simple as this: The processor you want to install into the motherboard is for an LGA 775 mobo such as yourself. Therefore, it should have no problems when you put it in.
Hope I was of assistance.
Nov 28, 2009 | ASUS P5S800-VM Motherboard
Is it compatible a intel dual core processor to a
Hi..
If you want to upgrade you unit be sure that the motherboard socket are totally fix with the processor. The compatibility is important because if it is not compatible the motherboard can not support the processor,
Good luck !!!
Regards
PCmania
Jul 15, 2009 | ASUS P5PE-VM Motherboard
I have so fat
Here the Infos about your mainboard:
ASUS P5S800-VM Allgemein MPN: 90-MBL0K0-G0EAYZ, P5S800-VM
Produkttyp: Motherboard
Formfaktor: Mikro-ATX
Breite: 24.5 cm
Tiefe: 24.5 cm
Kompatible Prozessoren: Pentium 4, Celeron D
Prozessorsockel: LGA775 Socket
Chipsatz: SiS661FX / SiS964
Maximale Busgeschwindigkeit: 800 MHz
BIOS-Typ: AMI
Storage Controller: ATA-133, Serial ATA-150 (RAID)
Prozessor Installierte Anz. (max. unterstützte Geräte): 0 ( 1 )
Speicher Unterstützte RAM-Technologie: DDR SDRAM
Installierter RAM (Max.): 0 MB / 2 GB (Max)
Unterstützte RAM-Geschwindigkeit: PC2100, PC2700, PC3200
Video Grafik-Controller: SiS Mirage
Videospeicher: Shared Video Memory (UMA)
Audio Audioausgang: Soundkarte
Signalprozessor: SiS964
Audio Codec: Realtek ALC655
Soundmodus: 5.1 Channel Surround
Kompatibilität: AC '97
Telekommunikation / netzwerk Netzwerk: Netzwerkkarte - Ethernet, Fast Ethernet
Besonderheiten BIOS-Funktionen: Wiederherstellung nach Stromausfall (Wiederaufnahme bei Verlust der Wechselspannung), DMI 2.0-Unterstützung, WfM 2.0-Unterstützung, ASUS MyLogo2, SMBIOS 2.3-Unterstützung, ASUS EZ Flash, Hyper-Threading-Technologie, RAID-Unterstützung, DMI 2.0-Unterstützung, WfM 2.0-Unterstützung, ASUS MyLogo2, SMBIOS 2.3-Unterstützung, ASUS EZ Flash
Sleep / Wake up: Wake-On-LAN (WOL), Wake on Ring (WOR)
Hardwarefeatures: ASUS Instant Music Lite, Chassis Intrusion Detection, ASUS Q-Fan, C.P.R. (CPU Parameter Recall), CrashFree BIOS 2, Jack Retasking, ASUS Instant Music Lite, Chassis Intrusion Detection, ASUS Q-Fan, C.P.R. (CPU Parameter Recall), CrashFree BIOS 2
Produktbeschreibung des Herstellers Das P5S800-VM unterstützt die neuesten Intel Pentium 4 LGA775 Prozessoren. Mit 800Mhz FSB, 1MB L2 Cache, Hyper-Threading Technologie und Spitzenleistungen von 3.6GHz und mehr ist der LGA775 Pentium 4 einer der schnellsten Desktop Prozessoren, die es zur Zeit gibt.
Dec 31, 2008 | ASUS P5S800-VM Motherboard
Processor compatibility- ASUS P5S800-VM
Asus P5S800-VM do NOT support Core 2 Duo: http://support.asus.com/cpusupport/cpusupport.aspx?SLanguage=en-us&model=P5S800-VM
Oct 03, 2007 | ASUS P5S800-VM Motherboard
No any display in the monitor, no beep of the RAM while CPU fan is running
Check your power supply. It sounds like you have a bad power supply. Even though the computer powers up, it does not mean that it's good. I have had this problem before, and almost 9 out of 10 times the power supply had gone bad. Just try a different one and see. hope this helps you.
Oct 01, 2007 | ASUS P5S800-VM Motherboard
Motherboard won't post.
I looked up your P5S800-VM motherboard on the Asus site and it doesn?t list the Pentium D915 ?Presler? dual core processor on its list of supported CPSs. Here is the link to show to your sales rep: http://support.asus.com/cpusupport/cpusupport.aspx?SLanguage=en-us&model=P5S800-VM
Apr 15, 2007 | ASUS P5S800-VM Motherboard
CPu fan turns for 1 second and then stops.
If all was working fine before, then, you have either not connected the cpu power cable, as is sometimes required other than being powered by the processor socket, or your power supply unit is not pentium 4 compatable and is unable to power the processor.
Apr 07, 2007 | ASUS P4S533-VM (P4S533-VM/L) Motherboard
ASUS P5S800-VM Motherboard Logo
100 people viewed this question
Top ASUS Computers & Internet Experts
Alun Cox
Are you an ASUS Computer and Internet Expert? Answer questions, earn points and help others
