Central air running all day and not cooling very well
I live in a second floor condo built in 2003. My ac compressor was replaced about 2 years ago because it was ''struck by lightning''. Basically my problem is my air is constantly running and there is alot of condensation run off on the outside compressor unit. There is cold air blowing but it takes a while to cool down. I had the coil cleaned and the refigerant checked and all is well. I just have no idea why this unit is always running and it takes so long to cool down the house. Do you have any suggestions?
  • shoreshotfl Jul 13, 2009
    I will look inot this, I am also going to go into the attic and look at the vent to see if they are crimped.I guess my biggest problem is that it takes hours for the unit to cool the place 1 degree. Thanks again for your help!! On a side note the compressor has condensation all over it and it saturates the concrete pad it is mounted on.
    i did just have the coils clean about 3 weeks ago..no difference. They also checked the refrigerant and said the level was fine. He did say something about a pipe where the gas reaches the handler and there is a Y split and sometimes something can get stuck in there but they want to drain the system and take it apart...is there anyway to deep clean the indoor coils? Thanks again for all of your help!!
    Scholar:
  • 91 Answers
Condensation by the compressor is okay, but if you see it icing up thats reason for concern. The indoor coils can freeze up if there is not enough air flow. Make sure most if not all the registers are open. Take tempature readings at the return and at a supply vent. There should be a 20-28 degree difference. If the difference is only in the teens you have a functional problem. Be sure to shade direct sunlight. And if it gets below 65 degrees at night be aware that if the A\C runs through the night it may block up with ice in the evaporative area. If outside temp reaches 100 degrees unit will run all day. Good luck
Posted on Jul 13, 2009
  • Lewis Luker
    Lewis Luker Jul 13, 2009
    Excessive moisture may mean that your compressor is pumping refrigerant while in a liquid state instead of gas, it may have too much refrigerant or the indoor coils may be chocked full of dirt. That differential test is a good indicator of proper function.
  • Lewis Luker
    When you had the compressor replaced, they should have installed a new filter drier to catch any contaminants from the inside of the tubing. As for the outside of the indoor coils, a good commercial cleaner foams out dirt by way of a mild acid, Most Techs don't even check the indoor coils because they are much harder to access and clean. One last thing is if the compressor installers didn't properly vacuum out the system before recharging then you system might rot from the inside due to a acid build up.
I got a 2003 f150 that just blow hot air when i turn the ac
First thing is to check and see if there is a belt in tact on your compressor and then see whether or not the compressor clutch engages (clutch is on front of compressor in front of belt.) If so and no cold air, u may need to charge it with 134a refrigerant or have a leak that you'll probably want a shop to repair. Good luck and hope you stay cool.
Jun 28, 2016 | AC Cars & Trucks
Whirlpool model WC260A-1A cannot find manual and central air conditioner will not turn on worked well 2 days ago.
Does the fan turn on when you have it set to cool? does the furnace still work? Does the fan auto, and on options still work?(for example when on its on, when auto, and neither the cool or heat functions should be running, the fan is off)? Basicly i'm asking your to test your thermostat right now.
Aug 04, 2013 | Whirlpool Central Ac Condenser-new...
M6X08F2A Air Conditioner problems not blowing cold, not cooling off apartment
Sounds like the heater is on as well. Even if ac is not working it shouldn't get hotter than outside air temp. Possible stuck relay.
Mar 01, 2017 | Maytag Heating & Cooling
We have a sub-zero refrig/freezer that came with our condo. Condo built in 1985. We purchased 12 years ago and were the 1st owners. This was originally the model and not lived in but very rarely by one of...
After 12 years you can expect that kind of repairs...I would not spend the 1200 for the compressor and would instaed replace the unit...it will just irritate you more from here on...
heatman101
Aug 30, 2010 | Kitchen Ranges
Noisy Amana Quiet Zone air conditioner
The compressor sounds like the springs inside are bad. You can live with this are get the compresor eplaced if it is over five years old buy a new unit. Compressor will cost more than a new unit. Russ
Jul 18, 2009 | Amana Quiet Zone 12M12TA Air Conditioner
Have new central h/a--installed last year. Problem--during the hottest part of the day (85+ degrees), it is about 80 inside with the air going. Windows are shut, blinds barely open in lr (closed in rest of...
somebody is full of you know what. If it can't satisfy the space the unit is not working properly or the new unit was not the some capacity. If the air handler is in the attic i would look for loose duct work pulling hot air from the attic. Do you know a neighber that has the same house/condo as you if so compare model#s ck024 the # 024 is the capacity the 024 would be a 2 ton 030 would be 2 1/2ton 12,000 btu's equals 1 ton
Jun 04, 2009 | Heating & Cooling
2000 GMC Sierra 4.8L V-6 - AC blows warm air
never seen a truck like this ,iam in spain but from the sound of it one belt drives a/c and another the power steering and altenator ,pos water pump as well but this could be driven by the timing belt .As i said i have never seen one of these trucks .If i had it in front of me i could soon tell you .
Jan 18, 2009 | 2000 GMC New Sierra 1500
LG LWHD1800R air conditioner problem
It sounds to me like the compressor is overheating and tripping on internal or external overloads. After the unit cools down again it will try to run for a little while. Then this cycle would start over. I would check the condenser coil for dirt and filth. This portion of the unit may be on the out and backside of the unit. You should at least be able to see light through the coil.
I believe the thermistor that you removed temporarily is used for a freeze situation. I do not believe that it is your problem. Good luck:)
May 17, 2008 | LG LWHD1800R Wall/Window Air Conditioner
Open Questions:
Heating & Cooling Logo
1,210 people viewed this question
Top Heating & Cooling Experts
paulcarew
Dan Webster
Dan Webster
Donni Steen
