Question about OKI C5100n Laser Printer
Error Code #380
Hello my Oki C6100 keeps getting a error code #380, stateing that it has a jamed paper. I already checked for any jamed paper and there is none. Now I try to put everything back and it is still reading error code #380. What do I have to do to get it to start working properly?
I had the same problem and decided to try a long shot, I opened the front cover and saw there is a sensor there black plastic which tips as the paper passes. I added a very small blob of bluetack onto the counter balance, printer now working.
Posted on May 30, 2013
    President:
  • 1,383 Answers
Check in back side of printer there should be small paper jam check it.
Posted on Jul 13, 2009
I have no Oki, i have Intec CP2020 and I see that they are pretty much the same printer. So, I have problem service call:175 fatal error, it says. Any ideas? Thanx
i have intec cp2020 machine showing error code close the frond cover error code 330.already closing frond cover.what is the problem machne i will wait for replay.i will check the pwersupplay board & fuse
Nov 20, 2010 | OKI C9600n Led Printer
I keep getting error 391 but find no paper jamed
check possible paper stock on roller side also clean sensor free from dust. try to feed paper manually by turning roller and observe for any obstruction.
Apr 03, 2010 | OKI C5150n Led Printer
OKI C6100 has the following error when printer is turned on: Replace Image Drum 562:C Drum Life
Try this:
1.Press Menu = printer displays "Paper Menu"
2.Press Next 4x = printer displays "System Menu"
3.Press Select 1x = printer displays "Factory Defaults"
4.Press Next 7x = printer displays "Reset Toner Life"
5.Press Select 1x = printer displays "Resetting Toner Page Count"
6.Press Ready
Nov 11, 2009 | OKI C6100dtn Led Printer
How do i solve fatal error 980
i got that error on the first day i got my oki c5950 it was a result of a paper jam in the fuser unit, i removed the jamed paper but the error was still there, i contacted oki support and got a detailed explanation on how to fix this error with a patch file, so if u or anyone out there r still having that problem send me a mail on ecks80@hotmail.com and i will forward u the info.
good luck
Sep 14, 2009 | OKI C5500n Laser Printer
Okidata C6100 getting an error 391
It means paper jam in the 1st paper tray. Check above the pickup roller sometimes, paper will get jammed in there good.
Jul 08, 2009 | OKI C3200n Led Printer
Oki error 380
Ich denke es mus die Sensorplatine mit den drei Gabellichtschranken im manualtray ausgetauscht werden.
Nov 25, 2008 | OKI C9500dxn Led Printer
Error Code 155: Fatal Error
Looks like a fuser error-
re-seat fuser
check for paper scraps, etc in fuser and printer.
Service call
155: Error
Defective fuse
cutting of fuser
Is the fuser installed correctly?
Does the error recur?
Reinstall the fuser after its
connection connector is cleaned
if error still exists-
Turn on the power supply again
Replace M32 board after check
the cable connection.
Jul 29, 2008 | OKI KIT-C3530N MFP LASER CLR P/S/C/F USB...
Service call 980:Error
hola
quiem puede ayudarme a desifar el error 980 de ld oki c6100
gracias
Apr 09, 2008 | OKI Office Equipment & Supplies
Error Code:380
Try to force a sheet into the feeder in order to clean and possible remove any piece of sheet. I had the same problem error 380: paper jam in oki 5300, but this time it said to open the front cover...
Jun 22, 2006 | OKI C9500dxn Led Printer
OKI C5100n Laser Printer Logo
1,556 people viewed this question
Top OKI Office Equipment & Supplies Experts
WTF Chuck.....
WTF Chuck.....
Jimbras
Level 1 Expert
mukhtar21 shaikh
mukhtar21 shaikh
Are you an OKI Office Equipment and Supply Expert? Answer questions, earn points and help others
