Hello, My PC suddenly stopped running. Thought it was the power supply, so just purchased a new one and connected it. LED on board in on, the CPU fan kicks and stops after a couple of seconds and PC does not boot. Seems even that HD drives don't spin. Thanks for your quick help.
  • 202 Answers
Could be a bad motherboard or bad processor. have had both in the shop several times. only way to troubleshoot is with a known good replacment for either.
Posted on Jul 13, 2009
I recently purchased a new Radeon 7970 graphics card and installed in into my computer which currently is... --AMD Phenom II X4 965 Black -BIOSTAR TA790XE -600 Watt OCZ mod x stream-pro power supply...
Hi David,
Try removing and resetting the CMOS battery on your motherboard. Also, make sure that all connectors from power supply are plugged into the motherboard. There should be power for sys fan, CPU fan, etc.
Thanks,
E.
Sep 20, 2013 | Computers & Internet
Power supply problem
Hello
Im using the intel dg33bu board with an intel core 2 ,3ghz.
When i built the pc i upgraded to a 450watt power supply.
Try a 450watt supply.Consult intel on the proper specs.
Apr 15, 2010 | Intel DG31PR Motherboard
How do I replace a power supply on a Compaq Presario SR5110NX Desktop PC
you can purchase a power supply from any computer store *********** board supports both standard IDE and Serial ATA connections, so you want a power supply that does SATA power as well. Unplug the power cord from the back of the computer. remove the cover from the case and verify that there is no green LED on the board that is lit up (if there is, there is still power on the board). unplug all connections from the current power supply, including all drive power and the large 24pin plug (actually a 4 pin plug that is combined with a 20 pin plug) on the board, then unplug the 4 pin plug near the processor. careful that the 24 pin plug and the additional 4 pin plug near the processor have latches on the side. Remove the 4 screws that hold the power supply in and remove the power supply, install new supply and reinstall the 4 screws. first plug in the 4 pin plug that connects with the 20 pin, the 4 pin plug has no latch, it is held in place by the 20 pin plug. then plug in the 20 pin plug and the 4 pin next to the processor. then plug in the drive power to all of the drives. Install the power plug at the back of the system and you should see a green LED on the board when you insert the power. replace the cover and power the system up.
Apr 03, 2010 | Compaq Hewlett Packard Presario SR5110NX ...
EMachine T2482 Computer won't power on or boot up.
Try removing the power cable from the power supply. Wait 10 seconds, and replace it again. Try powering up the computer. If it doesn't power up, check that the motherboard has power (there should be a LED on the board which is lit up. Of course, check the fuse also in the plug.
If the LED is on, you have a failed motherboard / Switch. If the LED is off, then you have a failed power supply. Beware though, if the PSU has blown, it could easily have taken the motherboard with it.
Mar 14, 2009 | E-Machines T2482 PC Desktop
Samsung Plasma PPM42S3 Dead
Hello karnevil925,
I would suspect a problem with the power supply board (the switching power supply) or the power connection to the ignition board. You will need a schematic and a multimeter to test the power levels on the board.
I would suggest that you take this TV to a qualified TV technician for repair, since there is a possible shock hazard involved.
I hope this helps,
Thank you,
Shuttle83
Sep 27, 2008 | Samsung PPM42S3 42 in. Plasma Television
No booting
plz try with new power supply
May 22, 2008 | Computers & Internet
Emachine with XP home edition doesn't start
Hi hearalso, down to the basic's. Replace power cord.
No help there than, remove the case's side panel to expose the motherboard. (Normally it is the left side panel while facing the front of the PC.)
Look closely for a small (green in color) led light. The power cord must be connected to the PC & connected to you're power strip but do not press the power on button on the PC.
The green led tell's you the board is receiving 5volts. Check all connections. Un-plug & reconnect every data & power connector in your PC. (Double check). There is a fuse inside your power supply that may have blown. Check you're manual page, Approva Statements B-1. Fuse Warning Instruction Caution.
Check fuse in power supply. (Unplug power cord before opening).
If you can not power up the PC after all of the above than if possible, swap out the power supply.
Replacing the power supply is the last step.
If you have more questions, feel free to ask.
Good Luck!
Mike
Apr 09, 2008 | E-Machines eMachines Desktop PC
Does not power up
I think you've done a good trouble shooting job, and proved that the board is dead.
Oct 20, 2007 | Asrock K7VT2 Motherboard
Won't turn on
Could be a power supply issue. Maybe it's not getting enough voltage from the power supply unit. Could also be some bad solder points on the circuit board, or maybe a burnt capaciter.
Oct 04, 2007 | ViewSonic VX924 19" LCD Monitor
Stopped working suddenly after 18 months daily use
It appears either the inverter supply board or the main video board have failed. First replace the inverter board, if not fixed, replace the video board. Mike
Aug 09, 2006 | Acer AL1715 (Black, Silver) 17" LCD...
Computers & Internet Logo
52 people viewed this question
David Payne
David Payne
