Question about Kensington Staffords Kensington StafCar Mount fords K33412US
The engine warning light keeps coming on??? It has been to the garage 3 times now and it still keeps coming back on after driving it a couple of times. The coil packs and some of the leads have been changed but still no joy. What could be the problem???
  • 85 Answers
What kind of vehicle and what codes does it have?
Posted on Mar 31, 2010
58 plate 2.0 Mondeo . Engine warning light came on took to garage they put it on a diagnostic and thought was cured .
The warning light more times than not is coming on because of the emission system. There are several sensors that are hard to diagnose even for a professional with a computer. First place to start which is cheap and easy is to use a fuel treatment for a few tanks of gas. This has worked for me in the past by cleaning out the fuel injectors and fuel system. From there if this does not work you will have to check O2 sensors everywhere they are and replace.
Jan 09, 2016 | 2008 Ford Mondeo 2.0
Jazz Acceleration
Stop using any vehicle that has check lights on the dash
& is not working correctly & get it to a repair shop or dealer
to be properly diagnosed,so you don't do any damage to it
Spending tens of thousands of dollars for another vehicle that
will develop the same problems makes no sense
The Technology & Problems are here to stay
Dash light that go off have nothing to do with going to a shop
& them retrieving stored data
Jul 11, 2013 | 2006 Honda Jazz 1.4i
Engine warning light keeps coming on, very bad fuel consupumtion all of a sudden
what is the code coming up? when was the last tune up? how is the air filter? are all the tires set at the right psi? what is the make and model?
Dec 19, 2012 | Cars & Trucks
1995 mighty max dashboard warning lights
Maintenance required light could mean its time for an oil change. Do you have a check engine light too ?
The battery/brake light can mean the brake fluid is low or the battery is not being charged by the alternator.
Jul 01, 2012 | 1995 Mitsubishi Mighty Max
I have a 2000 Jetta TDI and the yellow "check" light stays on all the time. It has been on for several years. Garages can't tell me what is wrong. The car runs fine.
When Check Engine Light ( CEL ) turn on, you need to have the codes read. Some places will read them for FREE. There are some other threads in this Forum that recommend to go to Autozone (or another parts store) where they will provide you a code reading free of charge. Get the exact code (like P0XXX) not just their and post it back here.
In THIS LINK could find additional interesting information about TDI FAQ.
Regarding warning lights:
- if the coolant temp light comes on, shut off the engine ASAP
- if the oil warning light comes on, shut off the engine ASAP
- if a falshign MIL/CEL comes on, shut off the engine ASAP
ASAP means driving to the berm of the highway right now and not waiting for the next exit. But if the MIL/CEL is not flashing, then it's not an urgent indicator.
Its possible that one simple unplug or any bad signal sensor. Are you recently make any mechanical job there?
Keep us updated.
Dec 21, 2010 | 2000 Volkswagen Jetta TDI
Recurring emission warning light
Hi there, did they run an emissions check? If so what was the outcome?
It could be your catalytic converter has broken down inside and/or blown a hole through it. Does the exhaust note seem louder and brash?
It is not dangerous for driving, but it can be annoying having that light blink at you. Disconnect the negative battery lead for 20 minutes. This should reset the ECU and if the light pops back up then there could be a fault with the CAT sensor or the above fault with the CAT.
I don't think it is a reocurring problem, moreso the ECU is thinking that the emissions are out of sync. Does the car consume gas quickly? Does the car feel sluggish?
Reply back and I hope this might help a little (vote if you think it's helpful)
Jun 24, 2010 | 2005 Volvo V70
Engine warning light comes on, diagnostic says
if your car give you i code thats says mutlipul misfire on number 1,2,3,or four cyl. that means that that cyl is not firing when its suppost to so if the code says number 3 cyl misfire or multipul misfire replace number 3 spark plug and coil pack and 80% of the time that will solve the problem.
Oct 08, 2009 | 2006 Ford Focus
Intermittent electrical fault Saab 9-5
Check connectors,pins grimping force,bad contact between pins in main plug connector(abs unit)or connectors near pilar A left.
Sep 29, 2009 | 2000 Saab 9-3 Viggen
Kensington Staffords Kensington StafCar Mount fords K33412US  Logo
Top Kensington Staffords Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a Kensington Staffords Audio Player and Recorder Expert? Answer questions, earn points and help others
