Question about Onkyo TX-DS696 Receiver
Buzzing sound thru speaker even with volume down to zero
I am getting a buzzing sound thru my speakers even with the volume set to zero.have mirage m3si speakers in front which are the ones that are affected. speaker problem or amp? would appreciate any solutions/suggestions. thanks
  • 749 Answers
Maybe some filter capacitors of the amplifier has been drying out! check for the main filter capacitors and output capacitors of your amplifier. replace them if necessary with a higher capacitance but the same voltage rating!
Posted on Nov 16, 2007
There is no sound in my pc
Some possiblities are:
* The sound is muted or turned down to zero. (This can often be controlled from the keyboard; for Windows 7, try the control panel > sound > adjust system volume).
* Speakers aren't connected, are turned off or are set to zero volume.
* Speakers are broken (least likely).
May 09, 2012 | Dell Latitude D610 Notebook
I own a A/Lansing FX 6021, My right satelite speaker is not working( no sound, no buzzing at cable plug-in), are there any solution for this problem??
if your computer came with a motherboard disc the sound drivers could be on it
click start control panel administrive tools computer management device manager scroll to sound,video and game controllers you might see a yellow question exclamation mark? ! or a red X Right click to reinstall drivers
click start control panel sounds and audio,volume,advanced,speakers make sure you have selected the
(((appropriate speakers))) also audio you will find 3 drop down lists make sure you have the correct settings there
click start control panel sounds and audio devices select advanced there might be a tick in the mute box untick it
if his does not fix the problem
click start control panel sounds and audio devices you can adjust the volume there also select speaker volume you can change your settings there you can also tick in the box place icon in taskbar for any further volume control settings you will need to right click on the volume icon system select adjust volume
click start control panel sounds and audio,volume,advanced,speakers select the appropriate speakers from the drop down list or navigate to the device manager scroll to system devices + to expand,system speaker right click properties then select use this device (enable) also you might check
the speaker plug/outlets is usually at the back of the computer or if it
Oct 05, 2011 | Altec Lansing FX6021 Computer Speakers
My Fender Supersonic 60w head is getting zero sound thru my speaker. Not even the usual ground level hiss. Checked/replaced all tubes. The fuses are good. Cables are good.
Next is to check if the speaker is open circuit. Check with ohmeter or plug in a radio/hifi at low volume to the speaker.
If speaker is OK, next suspect is power supply. This will be over 400 volts so not safe for the unwary. I assume filaments are lighting up.
May 01, 2011 | Fender SuperSonic 60 60W Tube Guitar Amp...
Got a humming/ buzzing sound from speakers. When muted no buzzing but when turned down to zero, buzzing. Can't shut off speakers. What to do?
LOL. This is a common, easily solveable problem. Remove your cellphone or anything that emits radiation of any sort from the general area. Don't believe me? send a text message while sitting net to your speakers. It does this even if you arent sending a message because your phone sends intermittent signals to the cell tower. the radiation being emitted from the phone does weird things with the magnets inside the speakers.
Dec 27, 2010 | Apex Digital LD4088 LCD TV
My logitech x-210 speakers make a buzzing sound
Sounds like the speakers are not plugged in to the computer, or are plugged in to the wrong socket.
The speaker socket on a PC is usually green, a 3.5mm stereo socket.
Apr 23, 2010 | Logitech X-540 Computer Speakers
have someone check speaker ground to the TV chassis. Your speakers are picking up reverb from the Video Signal.
Aug 19, 2009 | Vizio L37 Television
The subwoofer lites but no sound
Have you gone into the menu settings and adjusted the sub woofer volume, some factory settings are set @ zero.
Sep 09, 2008 | JVC TH-M55 System
Sound card broken? No normal sound and a constant buzz...
Sounds like you tried everything possible. Based on what you have stated that you tried already I would agree with your diagnosis of a bad sound card.
If this was my Laptop I would be looking for a nice set of USB speakers and Microphone or a headset.
You can either keep the speakers turned down or you may be able to disable the onboard sound through a BIOS setting.
Or even better. Here is a USB sound card with speaker and microphone jacks. Pretty Cheap too.
Jan 06, 2008 | HP Pavilion dv9000z Notebook
Onkyo TX-DS696 Receiver Logo
245 people viewed this question
Top Onkyo Audio Players & Recorders Experts
Are you an Onkyo Audio Player and Recorder Expert? Answer questions, earn points and help others
