Question about Bernina Activa 130
There is a noise when I sew in the bobbin case area of my Bernina Activa 131. I think it is the hook race and cover hitting against something. Otherwise, it sews beautifully I have taken everything apart and cleaned it but when I loosened the hook race cover just a little bit, the sound disappears, but then the bobbin case and the hook race cover all falls out within a minute of sewing. I live overseas, and wanted to know if anyone can help?
  • Anonymous Mar 23, 2014
    I can't reinstall the black bobbin race hook
    Novelist:
  • Bernina Expert
  • 166 Answers
Sounds to me as though you're not pressing the hook retainer back into place properly, or that the spring retainer is not properly engaging with the metal 'pip' on the left-hand-side of the 'U'-shaped hook retainer. You should press the hook retainer back until there is a definite 'click' and you should see the spring clip on the left just move a little bit when it clicks. You definitely shouldn't be able to 'loosen the hook race cover' at all - if you can, the hook will be able to rattle-around in the hook race causing noise and (probably) inconsistent stitch formation. The other thing you mention is that you 'cleaned-out' the hook race, but you didn't mention oiling it. If your machine has got the lightweight hook/shuttle that is black plastic with a metal hook around the outside, Bernina claims these dont need oiling, however, I've found that a small drop of oil will improve the performance of these machines immensely (note a SMALL drop of oil !). If you have an all-metal hook, you most-definitely need to oil it after cleaning ... lack of oil is probably the biggest cause of noise in machines of this type.
Posted on Oct 27, 2011
  • 55 Answers
Sounds like thread or lint caught in the shuttle race - clean race with a pin or fine screwdriver.
scott
Posted on Jul 24, 2009
My bernina activa 130 wont sew
Fit a new needle, clean and oil the hook race, whether-or-not your manual says it doesn't need it and check that you have some tension on the thread coming out of the bobbin case and top tension unit. Are you threading the top thread with the foot up or down ? You should always thread the machine with the foot up to ensure the thread goes through the tension unit properly.
Mar 02, 2012 | Bernina Activa 140
Why won't my Bernina Activa 140 sew the blind hem stitch?
Are you absolutley sure you're not getting a problem with stitch formation on, for example, wide zig-zag. Check again, using a different colour top and bottom and make sure that the stitch is being formed properly with only the top colour on top and bottom colour on the bottom. It sounds as though the bottom loop is not being picked-up by the hook properly. Make sure you've thoroughly cleaned-out any fluff under the stitch-plate and remove the hook/shuttle and give the hook race a good clean and give it a single drop of oil, even if you've got the lightweight part-plastic hook/shuttle fitted.
Nov 19, 2011 | Bernina Activa 140
I have a Bernina Activa 230 and my bobbin case is stuck in the machine and it wont come out, Someone Please help me what do I do?
can you unlatch the ring cover device? there is a little release lever on the left just inside the bobbin area which secures a hinged silver square called hook race cover, if you unlatch this, flop the cover forward, then the bobbin case and shuttle should all come out as well.
Nov 02, 2011 | Bernina Activa 130
I am trying to put back together my Bernina Activa 130 after it arrived in the mail. The hook fell out in shipping, and now I think I am missing some pieces. I am trying to figure out what else is suppose...
The only parts that should be able to 'fall out' during shipping are the bobbin case and hook/shuttle, assuming the bobbin case was fitted in the first-place. If your machine arrived with the bobbin door open and the round black plastic hook retainer dropped down out of the hook race (on its hinge), the hook can be replaced quite simply and the hook retainer clicked back into position to retain it - you might find it easier to tip the machine back slightly when putting the hook back. If the hook retainer is still in position, just press the flat metal spring on the left of the 'U'-shaped metal retainer and the hook retainer will pop forward allowing you to put the hook in andclose back up. Make sure it clicks back into position. Does this help ???
Sep 20, 2011 | Bernina Activa 130
My Activa 130 makes a clacking sound when I sew. It is 10 years old. What do you think is wrong? Can I repair this or do I need to take it to be serviced?
I would take it to a Bernina repairman, nice machine and well worth getting it serviced by a qualified technician.
I presume that you've tried the obvious things like a new needle and checking the bobbin case is in correctly.
Sep 03, 2011 | Bernina Activa 130
Needle is getting caught in hook. i scarred the hook after sewing over a pin and breaking the pin below the plate. I removed the bobbin and race cover and the hook to discover the big scar on the hook. I...
If the plastic on the hook has been scarred / burred by a needle break, it is best to replace the hoo - they're not that expensive on this model and can certainly be purchased on-line. You can polish out some marks using very fine emery paper (>1200 grit), but if there are any deep grooves/holes in the plastic, the thread can get caught when its moving around the hook during sewing and it'll cause inconsistent stitch formation or broken threads. If the needle is still hitting the hook when rotating the handwheel, it could be that the hook driver has skipped a few teeth on the gear wheel when the pin got broken, in which case the machine's timing/synchronisation will have been affected and the only solution is to have it readjusted by a Bernina Service Agent - it's not something you can do yourself without the correct tools.
Aug 20, 2011 | Bernina Activa 140
How to oil? Where do you put oil?
The Activa range came with a lightweight plastic hook/shuttle that Bernina claims does not require oiling. Oiling/greasing of the main drive mechanism should only be done by a competent Bernina service engineer - it's not like the 'old' Berninas that had red paint spots next to all the oiling points ! I, however, always recommend that the hook/shuttle is removed every 3-5 bobbins-worth of thread and the hook race is thoroughly cleaned with a cotton-bud. Although Bernina says it doesn't need oil, I find that a small drop of oil on the hook race running surface is extremely beneficial to keeping the noise-level down and improving the consistency of the stitch formation.
Jul 18, 2011 | Bernina Activa 130
How do you oil a Bernina Activa 130? The manual doesn't say anything about it.
Remove needle, needleplate, presser foot and bobbin case. Now take a lint brush and clean under the feed dogs and hook area. take the bernina oiler(must be bernina oil only) now place a drop just below where the bobbin case clip on and one small drop under the feed dog area. replace items, sew out a test sample and away you go.
Apr 27, 2010 | Bernina Activa 130
Bobbin Carriage clanking noise, yet the machine sews fine??
If your bobbin area is making a noise, then do NOT sew with the machine until a reputable technician looks at it. You may have thrown something just a little off line - not enough to affect sewing NOW, but it could easily cause troubles down the line.
I suggest you call ahead and talk directly to the repair person - not to the sales person. Ask if you can bring in the machine while he/she is in the shop so they can listen while you run it.
You aren't trying to cheat the store out of the repair charge, just ensuring that the problem is diagnosed correctly.
You paid lots of money for this machine - it deserves good care.
Dec 30, 2007 | Bernina Activa 130
Sewing Machines Logo
691 people viewed this question
Top Bernina Sewing Machines Experts
Tally Girl
Tally Girl
jnissen
Level 1 Expert
Chris Wetmore
Are you a Bernina Sewing Machine Expert? Answer questions, earn points and help others
