FWZV475F
SOURCE: Sanyo DRW-1000 DVD Recorder / VCR Combo
if you have not plug out your set for a while then i recommend to do now leave it for about 2 days then plug it in back if it does the same problem,then have a tech look at your set.good luck
SOURCE: owners manual
Turn on power to TV, and DVD/VCR, set TV to channel 3 or 4
Insert video cassette
Select desired channel by using CH/TRK
Set the desired recoring speed (SP or EP)
Press REC once
Press STOP to stop recording.
Timer Recording,
Press Menu and the Main menu will appear.
Use up and down arrows to choose the Timer record menu
Press Select/Enter to go to the Timer Record menu.
Use arrows to choose the program no. (1-8)
Use down arrow to choose Month option
Use arrows to choose the desired month
Use down arrow to choose the Day option
Use arrows to choose the desired day
Use down arrow to choose Start Option
Use arrows to choose the desired start time
Use down arrow to choose the Stop option
Use arrows to choose the desired stop time.
Use down arrow to choose the Channel option
Use arrows to choose the desired channel (Channel, Line1 or Line2)
Cable users: If you have Cable TV and used Cable Box in Connecting Antenna/Cable TV to DVD/VCR using a cable box converter, you must set the channel in this step to match the cable box output channel (usually 3 or 4). Change channels on the cable box instead of the DVD/VCR
SOURCE: Sanyo DVD/VCR Recorder/Player
How do i conected via sky+ to watch programs and record by telli
SOURCE: Sanyo DRW-1000 DVD Recorder / VCR Combo remote control
I thank you for your interest in helping me. However, I just want to know where to get a replacement for the remote control for a DVD RECORDER VIDEO CASSETTE RECORDER COMBO, model DRW-1000. Then, I do not find necessary to pay for such information. Thanks, again, anyway for your help, sincerely,
Juan B. Pérez-Valverde
SOURCE: Owner's Manual for the Sanyo DWM-3000
I have the owner's manual and can make a copy of it for you. Please provide more information. [email protected]
