Question about Jabra BT350 Bluetooth Headset Headset
Will not charge
I have had the BT 350 for a few years and it worked OK. Now, I cannot get it to charge with either of the two chargers it came with.
    Problem Solver:
  • 13 Answers
My bt350 had similar issue. I looked "down" into the charge port (the "socket" at the fat end, where the cord plugs in), and saw that I had bent one of the "tines" (the little metal "wires") down.
I pried it up with a straightened out paperclip, being VERY careful not to touch two wires at the same time, just in case. Once I got it bent back straight, it charges like normal, though I admit I am very careful when plugging it in, now.
Hope that helps; best of luck! :-D
Posted on Jul 15, 2009
Does the BT-350 work with Windows 10. I can feel the drive spin up but no drive designation.
Windows 10 Drivers - HP Support Forum - 5207043
h30434.www3.hp.com > Laptop & Notebook > Notebook OS
Aug 17, 2015 - 8 posts
So.....is HP going to provide updated drivers for Windows 10? .... sensor andbluetooth (depending on the BT hardware installed). It is the ... I can get W10 to workin an old nc6400 from 2006, and not on a 350 G1 from 2014.
Bytecc BT-350 Drivers Download - Update Bytecc Software
www.solvusoft.com/en/update/drivers/hard-drive/.../bt-350/sub-models/
Manufacturer: Bytecc. Hardware Type: Hard Drive. Model: BT-350. Compatibility:Windows XP, Vista, 7, 8, 10. Downloads: 35,089,716. Download Size: 3.4 MB.
Dec 15, 2015 | Computers & Internet
Shut off
You should only see the computer icon when plugging the 350 into a USB port on the PC. If you see it when plugging in a car charger/adapter, then there may be a problem with the mini-USB port on the 350 or the charger is an after-market charger that is not electrically compatible with a Garmin charger. Please see this link for more info:
http://www.sharc.net/gps_charger_repair.htm
May 29, 2013 | Garmin Nuvi 350 Car GPS Receiver
1 of my trio BT 1500 keeps beeping I have fitted new batteries
Try it in another charger as it sounds like it's not charging, solutions, clean battery terminals in phone, clean terminals on charger, swap chargers
Mar 28, 2013 | BT Hudson Plus 1500 Trio Dect Cordless...
My Garmin Nuvi 300/350(2 years old) comes on and
I solved the problem by charging internal battery using the 120V. charger that came with the unit. I was not aware, that the cord in car was not charging my Nuvi and that it was running OK. until the battery was low and quit. I have to check this cord. Peter W.
Oct 01, 2009 | Garmin Nuvi 350 Car GPS Receiver
Battery or Charger bad?
If you persistently leave the batteries discharged, it is unlikely that they will be able to hold a full charge. You should re-charge your batteries at least once a month, even if unused. Put it on your calendar. BTW 2 years old is hardly 'brand new'.
May 26, 2017 | Sharp VL-E630U Camcorder
Cant use the garmin 350 while charging
The solution is really easy. Works in the car or usb charger or whatever.
Once you insert the car charger, wait till the pc connection picture comes.
Than unplug the car charger.
Re-insert it as soon as the picture goes off.
Voila. It is ready to use now!
Feb 08, 2009 | Garmin nuvi 350 GPS Receiver
Can't charge my e-scooter
ok you do not need a new charger. the problem is you let the battery get too low. the battery has to have a little bit of power left in it to send to the charger, if it dosent then the charger can't tell if there is rilly a battery hooked up or not. you shuld probubly get a new battery. or you can email me and i will tell you a few things you could try to jump it back to life.      wildnfuzzy@gmail.com
Jan 24, 2009 | Transport Schwinn Rechargeable Portable ...
Reset button won't work on dell axim x51v
to wlumbria... hey listenup... if ur connecting ur pocket pc to the cradle it is not only used for the flow of data bt it also charges ur pocket pc... bt the chargin is quite slow  it will keep on showing  the red lite as compare to an charger it will charge fast and the red lite will turn green... so wht i suggest charge it with a charger not with a cradel if stil it doesnt wrk try changing the battery...!!!
Aug 21, 2008 | Computers & Internet
This is what I did:
1. open the headset by following these steps:
http://www.instructables.com/id/Jabra-BT-350-Disassembly-and-Repair/
2. measure the voltage of the battery. If it is too low, the internal charger circuit may not like it. Mine was 2.6v.
3. Charge the battery "manually" by connecting to 3 serially connected rechargeable batteries (final voltage should be around 3.7v). Three NiMH AA batteries are fine.
4. Reassemble and hope your headset is back to business.
May 10, 2008 | Jabra BT350 Bluetooth Headset Headset
Jabra BT350 Bluetooth Headset Headset Logo
285 people viewed this question
Top Jabra Radio Communications Experts
TO Lady
Greg Cann
Greg Cann
Michael Vincent Cruz
Are you a Jabra Radio Communication Expert? Answer questions, earn points and help others
