Question about Toshiba TP50H95 50" Rear Projection Television
Same as the others
Toshiba 50" rear projector. The tv flickers a few times a day and the convergence is off by a mile. Now tv will go into "standby" with the power light flashing and the only way to get it back is to unplug it and wait then plug it back in after a few minutes. Anyone in the Abinton Mass area that can fix it or refer a repair man I will hire you. steviemcgowan@comcast.net.
  • 22 Answers
I recently had what sounds like the same problem. The problem was that the focus anode coming out of the flyback had broken loose enough to start arcing inside the flyback. You might want to verify that this connection is tight.
Posted on Jul 14, 2009
Toshiba TN50X81 50 TV
More likely is the set is in shutdown---most common issue on this type of set is the convergence---to know you would have to locate and unsolder both 18 pin convergence chips---with them out of the circuit if the set comes on (will not look good) one of the two chips is shorted--these sets have very good protection circuits to prevent many parts from being destroyed at one time..
These are the chips--STK number is right on the front.
May 25, 2012 | Toshiba TN50X81 50" Rear Projection...
Multi- color bands - twisting wave pattern cross the middle of screen and can not get image to lock -flickers both horizonal andf vertical. Would this be the same 2 IC chips- last time i had this problem...
Ur tv have convergence problems,it dead.U must have soldering tools,solders and know how to solders to fix convergence problems.U must replaced 2 STk convergence ICS,and some or all it resistors.Tries websites Tvrepairworld.com,Tvrepairkits.com to buy a convergence kit to repair it ur self.The shop will cost U $300-$350 for parts and labors.
May 11, 2010 | Toshiba 50H72 50" Rear Projection...
TV Flickering, Wave, and Warming Up Problem
The capicators in the hyperboard have failed. An esy fix if your patient. Otherwise I offer a repair service. Let me know.
Feb 03, 2010 | Toshiba 50H81 50" Rear Projection...
I just replaced the blue projector. How do I set
Coarse adjustment is done by adjusting the convergence coil on the neck of the tube, also the skew is adjusted there. The user menu should have a convergence adjustment option.
Jan 07, 2010 | Toshiba 50H72 50" Rear Projection...
Different Kind of Convergence Problem - RCA 52 inch
The FL231 fuse is dead.There 3 retangles squares the one in the midle is dead near the right side of the FBT high voltage transformer.the big plastic block with a red wire hook a cap to ur CRT.
Sep 07, 2009 | RCA D52W20 52" Rear Projection HDTV-Ready...
TV will not turn on
the convergence amps might need resoldered. thias is a common problem after the run for a few years
Jul 10, 2009 | Toshiba TP50H95 50" Rear Projection...
TP61H95 Toshiba Cinema Series 61" The Image rolls
defintly the convergance.if the con is on a small board ,maybe 130 big board 250&up.if u know how to solder 35$ each STK and u need 2. and check each internal fuse with a ohm meter with tv power unplugged
Mar 12, 2009 | Toshiba TP61H95 61" Rear Projection...
DOUBLE IMAGES
there is a problem with tthe convergence section this is something a tech can do
Sep 23, 2008 | Toshiba TZ50V51 50" Rear Projection...
"noisy" convergence
Convergence is a very common problem these days.The only solution is to replace the two STK Ic's on the board and your problem will be solved.
You can get the parts at www.ptscorp.com or www.partstore.com
Hope ur problem gets solve soon..
Goodluck,
Please don't forget to rate me as fixya..
Feb 05, 2008 | Toshiba TP61H60 61" Rear Projection...
Convergence problem
We need a better description of what you mean by shadowing. However I am assuming: 1. You mean it ''bleeds'' off to the right when you have something with a hard red/blue drive. 2. When you turn the contrast and color down a bit it gets better. unfortunatly I cannot tell you how to fix convergence, but I can think of some other possibilities. In this case the red/blue emmision of the crt is dying off and going into saturation when driven hard. To fix, replace with a new picture tube/crt. In some cases you can get a little more life out of that tube (with a watchable picture) by having the screen, focus, cathode bias, and drives slightly readjusted. It will take someone with experience in doing these adjustments on a weak tube to get it looking as good as possible. Given the construction of the cathodes (guns) in that crt, only a very low level crt reactivate should be tried on it. The hard rejuv most crt testers give is highly likley to completely destroy the cathode on that crt.
Mar 22, 2006 | Toshiba 55H70 55" Rear Projection...
Televison & Video Logo
155 people viewed this question
Top Toshiba Televison & Video Experts
Jaime Hernandez
Are you a Toshiba Televison and Video Expert? Answer questions, earn points and help others
