Question about Kenmore 24 in. 17052 / 17054 / 17059 Built-in Dishwasher
Kenmore elite mod 665/17059 diswasher. unit was runing last night sometime during this time unit shut off. now it has no power at all. checked breakers and unit has power to it. could this be control unit?
  • 15,935 Answers
It appears your timer/main controller/CCU has failed in this instance.
For replacement parts - head on over to PartSelect.com or RepairClinic.com and enter in your full model number for a full parts listing.
I recommend both sites because ...
FixYa has no affiliation with either site - I have been using and recommending them for years - trouble free.
PartSelect has a great schematic database for locating the part on your unit and great "testimonials" for each part that often times includes HOW-TO information.
RepairClinic has pictures of each part they sell and also a great how-to and troubleshooting for basic repairs.
If your unit has never been serviced - there should still be an original service manual enclosed in plastic taped to the inside of the shell.
In the service manual are Error codes, maintenance procedures, and troubleshooting steps you can follow.
Anything too complicated or beyond your scope should be handled by a professional.
If you think you want to tackle the repair - and have gotten stuck on a step - reply to your question and I will be glad to help you out.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question
Posted on Sep 30, 2010
Kenmore elite microwave 721.80833 stops cooking intermittently
Check the door switches if one is bad it may think the door is being opened and stop the unit from running. If it is from a bad connection it will get worse as it gets hotter while running.
Oct 04, 2017 | Kenmore 80809 Microwave Oven
Kenmore Elite upright Mod. # 253.28099802 15 months old. Unit shut down completely and will not restart. Never heard any alarm, but there was a small "knocking" sound when it cycled down the...
Ive done appliance repair 35+yrs. Your refrigarater is stuck in defrost, the popping was the defrost elements kicking on to get rid of frost in the coilsbehind the wall in freezer.
Sep 12, 2011 | Refrigerators
Kenmore diswasher was runing fine till i found leak in disposal
Took plug out of new garbage disosal.Reading installation pages afer installation can be costly?Thanx
Jan 10, 2009 | Kenmore 18 in. 14432 / 14439 Built-in...
Kenmore Elite F25?>
F25 = DRIVE MOTOR TACHOMETER ERROR
mostly likely need to replace speed control board
If the control is unable to properly detect motor speed, the machine shuts down.
If a failure occurs during high-speed spin, the door unlocks after 3 Minutes.
Possible Causes/Procedure
1. Verify the shipping system including shipping bolts, spacers and the power cord are removed.
2. Unplug washer or disconnect power.
3. Check drive motor tachometer resistance. It should be approx. 115 ohms.
4. Check wire harness connections between the drive motor and the Motor Control Unit (MCU), and between the MCU and the Central Control Unit (CCU).
5. Plug in washer or reconnect power.
6. Check the MCU by looking for operations of the drive motor.
7. Check the drive motor for powered rotations
Oct 19, 2008 | Kenmore Elite 45986 Front Load Washer
Kenmore Elite Dishwasher Problem
I had this same problem so I took the front panel off to access the thermal fuse.  What I found instead was that food had become lodged in the door latch which was keeping the door safety switch from operating properly.  I took a thin screwdriver and removed the food from the cavity.  Since you did not have the problem in your first five years the cavity just might be the problem since that is about the amount of time it took me to get too much food stuck in mine as well. This solution took five seconds and requires no disassembly.
Oct 09, 2008 | Dishwashers
Kenmore Elite Mod #76523
The problem is the fan unit that pushes cold air up to the fridg, usually located nere the back of the freezer.
Aug 19, 2008 | Kenmore Elite 22.4 cu. ft. Bottom Freezer...
Kenmore Elite Catalyst Mod. 22052
Oil is no problem. The door switch/interlock is faulty. Replace door interlock. Try closing the door firmly with an extra little shove on the door handle. Sometimes this works.
Oct 30, 2007 | Kenmore Elite 45986 Front Load Washer
Kenmore 24 in. 17052 / 17054 / 17059 Built-in Dishwasher Logo
165 people viewed this question
Top Kenmore Dishwashers Experts
Ken Johnston
Ken Johnston
Level 1 Expert
vince
D. E. Hev
Are you a Kenmore Dishwasher Expert? Answer questions, earn points and help others
