Question about Refrigerators
Our refrigerator (Samsung) is only about 3-4 yrs. old. The refrigerator has been acting up and now the freezer isn't working. My husband has pulled the refrigerator out and defrosted behind the drawers where the ice is accumulating and it seems to work for a while. The freezer is now not cooling. He has unplugged it and then plugs it back in and it will work for a few hours, but then heats up to 40 or 50 degrees again.
  • 130 Answers
Maybe it's your motor that has worn away?
Posted on Jul 13, 2009
Kenmore coldspot, freezer frosted up then auto defrost and both freezer and fridge stopped cooling. unplugged and defrosted and now freezer works but not fridge. vacummed coils already. 3 yrs old.
Check the freezer fan motor.
Is it working>
If not,replace it.
Also you must replace the defective defrost parts.
Timer......heater.....thermostat.
May 08, 2011 | Refrigerators
Refrig. is 4 yrs old. Refigerator side just quit cooling. Freezer side seems to be working fine. Help!!! Samsung Model #RS267LBBP
Check out these tips...they can help you figure out what is going wrong with your refrigerator and why it is not cooling
Refrigerator not Cooling or Fridge not Cooling
How to Defrost Refrigerator
Defrost Timer Problem
Water Running in refrigerator from Freezer
Refrigerator or Freezer not Cooling or Getting Cold
heatman101
Apr 16, 2011 | Samsung 26.1 Cu. Ft. Side-by-Side...
Freezer not cold anymore...2 yrs old
Many times a freezer and/or refrigeratordo not work right because of a dirty condenser coil...there are also many otherthings that can go wrong. If you are hearing a clicking or buzzing then check out thelast two tips.
If your refrigerator is running but warm, then...
Check out these tips that I wrote about that... it is a great place to starttrouble shooting your unit...and something that you can do rather then callinga repair person to do a simple thing for you...
Refrigerator Condenser Coil Cleaning Refrigerator Repair
Refrigerator Troubleshooting Refrigerator Compressor
Refrigerator Compressor Start Capacitor and Start Relay
heatman101
Oct 20, 2010 | Samsung 25.8 Cu. Ft. Side-By-Side...
Samsung side by side not as cold as it should be all fans sound like they are working what to look for fridge only 4 years old pulled out back cleaned coil pack with compressor please help
We had a similar problem. SAMSUNG said to not set the freezer to the top range and the fridge to top range. If you set the freezer to the top range there is not enough cold air funneled to the fridge. We usually set the freezer to about 3 dots and the fridge to 4 or 5. Try that and see if it helps
Dec 04, 2009 | Samsung RS2630WW Side by Side Refrigerator
Fridge acts like compressor is not coming on - Maytag wide by side - seven yrs. old
Pull the refrig out and remove the back panel . You should see the compressor and the cooling fan ( condenser fan ) . If the fan isn't working , it needs to be replaced . If the compressor isn't running or starts then cuts off , then the box plugged onto the side of the compressor , with 3 wires going to it ( overload/relay ) needs to be replaced .
Oct 31, 2009 | Maytag 25.6 cu. ft. Wide-By-Side...
Kenmore elite refrigerator (no freezer) is not cooling. 3 yrs old maybe. fan working. ...just not cooling
you need to call out a repair man for the repairs on it it sounds like you may have a freon leak
Feb 28, 2009 | Kenmore 73502 / 73504 / 73509 Bottom...
Maytag MZD2766GEW side-by-side - one side is not cold
WE JUST HAD THAT SAME PROBLEM AND IT WAS THE DEFROST BOARD. $50.00 REPAIR...
Jun 15, 2008 | Maytag MSD2436GR Side by Side Refrigerator
Ge side by side not cold enough in fridge or freezer
if there is no frost build up in freezer section sounds like a refrigerant leak
Apr 14, 2008 | GE (PSS26MSRSS) Side by Side Refrigerator
Refrigerator not cold
It sounds to me like you have a defrost problem. Look on the back wall in the freezer about 3/4 of the way down. Do you have any frost build up? If so, for me to be able to help you futher I will need the model number of the refrigerator located on the inside of the refrigerator...
Dec 15, 2007 | Refrigerators
Refrigerators Logo
Top Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
