Question about Konica Minolta DiMAGE Z3 Digital Camera
External Flash can't fix
Sir, I haave a Dimage Z5 camera that I bought 2 years before and its working fine and recently I have purchased an external flash called Program 2500D But this flash in my camera is not working at all, when I mount this flash in my camera, the flash status turns off automatically and if I unmount it flash status turns on byitslef. Camera's built in flash working fine. Please let me know what could be the problem...
  • 138 Answers
Its becoz that flash is not compitable with your camera. You should buy only flash that are compitable with your camera.
Posted on Dec 08, 2007
I have a Canon EOS 40D camera. We are having problems with using an external flash. The pictures always come out extremely dark with the external flash. The flash seems to work fine, it flashes...
I don't know if this will help and this post is two months old. The camera store may be right that the synchronization is the issue which tends me to point a finger at the external flash. There are at least three different flash units that will flash when the picture is made but only one type will sync with the camera. A digital flash unit is different from a film flash so a Canon EX type is required to sync with Canon TTL or TTL II digital cameras. An EZ will flash but it's off a bit, so I can only assume that your Promaster and Canon flash units are for film cameras. Okay and another thing that could be throwing things off a bit is the camera may have been programed in Custom Functions to use "Second Curtain" or "Rear Curtain". Just seams to me if the built in flash works then it's the external units at fault.
Oct 17, 2010 | Canon EOS 40D Digital Camera
I have almost identical issue with a Dimage Z5 (Konica/Minolta). I have had the...
Many digital cameras (eg Samsung D53, Nikon 2100) have extremely poor battery life with alkaline batteries (under 20 shots!). Sometimes they won't even take a single picture.
Try using rechargeable batteries or "oxyride" disposable batteries. They perform infinately better.
on Dec 01, 2007 | Samsung Digimax D53 Digital Camera
How can my c750 detect external flash?
Please read the manual about using manual mode. The external flash mounted on hot shoe fires only when the camera is in manual mode.
Please check and confirm if this solved yr problem.
Nov 04, 2008 | Olympus Camedia C-750 Ultra Zoom Digital...
Same SD card problem with Dimage Z5
Your Card may need to be formatted. to fix this problem:
[note- before you start, make sure that your SD Card is blank, or that the information is unimportant, because formatting your card will erase all of the information.]
1) Plug the card into your computer, if you can, in the SD slot, or use a USB - SD transformer to plug your card into a USB port.
2) After its plugged in, go to 'My Computer'.
3) Right Click on the drive its plugged it into
4) press format
5) Make sure all of the correct settings are on and start the format.
now your SD card is formatted and should work in your camera and you can continue taking pictures. YEA :^)
Apr 13, 2008 | Konica Minolta DiMAGE Z5 Digital Camera
Konica Minolta DiMage Z5
The odds are you have a broken spring in the anti-shake assembly which has allowed the lens unit to shift to one side. The smudge you are seeing is the edge of the lens housing and will have a slight rounded shape. As you zoom in, you are extending the lens past this area so it no longer shows.
Feb 28, 2008 | Konica Minolta DiMAGE Z5 Digital Camera
Minolta Dimage Z3
you cannot add external flash as far as i know!
Nov 14, 2007 | Konica Minolta DiMAGE Z3 Digital Camera
Does the DiMAGE A1 support any external flash including studio light?
Yes, it does. It is usable with any external flash using sync cord to sync terminal. (sync voltage: below 400V, correspond to antipolarity)
Sep 15, 2005 | Konica Minolta DiMAGE A1 Digital Camera
Can the conventional Maxxum/Dynax flash units be used with this camera?
Yes. The following Minolta dedicated external flash units are compatible with the DiMAGE A1 for automatic flash control: Program Flash 3600HS(D), Program Flash 5600HS(D), *Program Flash 2500(D), Macro Twin Flash 2400*, Macro Ring Flash 1200*. * Program Flash 2500(D) will be available around August, 2003. *Macro Flash Controller is necessary
How many images can the DiMAGE Z5 save in a 16MB SD Memory Card?
Still image Image Size: 2560x1920/2048x1536/1600x1200/640x480 Economy : 18 / 26 / 37 / 142 Standard : 9 / 15 / 22 / 101 Fine : 4 / 7 / 12 / 67 Movie 640x480 Fine: 30 fps: 9 sec. / 15fps: 18 sec. 640x480 Std.: 30 fps: 14 sec. / 15 fps: 28 sec. 320x240 Std.: 30 fps: 29 sec. / 15 fps: 57 sec. *The writing speed of the memory card may prematurely end the recording of a movie clip.
Sep 13, 2005 | Konica Minolta DiMAGE Z5 Digital Camera
Konica Minolta DiMAGE Z3 Digital Camera Logo
88 people viewed this question
Top Konica Minolta Cameras Experts
Greg Cann
Greg Cann
Are you a Konica Minolta Camera Expert? Answer questions, earn points and help others
