Question about Stanley Factory Reconditioned Bostitch U/CPACK270 Finishing Nailer, Brad Nailer/Stapler & Compressor Combo Kit
Describe your Stanley Factory Reconditioned Bostitch U/CPACK270 Finishing Nailer, Brad Nailer/Stapler & Compressor Combo Kit ProblemCompressor builds to 80PSI and will not shut off or build more pressure
  • 142 Answers
Sounds like an air leak of some sort. when you get it up to as high as it will go, turn it off and listen for an air leak. Let me know where it is leaking and i will tell you what to fix
Posted on Jul 13, 2009
Where can I buy a o-ring kit for a bostitch nailer #sb1850bn ?
Stanley Bostitch makes very few o-ring (rebuild) kits for thier nailers. Your brad nailer never had a kit available. You have to go to a service center or website like www.ereplacementparts.com, find a breakdown of your model and order each o-ring seperately. Your nailer is an older tool that was sold as part of a combo kit and there are many parts that are no longer available or are shown on back order which usually means the same thing. If you have someone in your area that works on pneumatic nailers they may have o-rings from other manufacturers that will work.
Feb 22, 2013 | Stanley Bostitch SB1850BN 18Gauge Brad...
When I pull trigger air is escaping around the trigger and nailer will not engage
you need a new trigger valve assembly, there is an o ring that has split. Contact Bostitch for a replacement part.
Oct 08, 2010 | Stanley Bostitch Sb 2IN1 2 In 1 Narrow...
Can not drive nails. Loud air hiss at top on tool
you have an air leak and you have to fix your stapler nailer hope its not cracked but just a seal
Sep 24, 2010 | Stanley Bostitch Sb 2IN1 2 In 1 Narrow...
Will only charge to 40 psi, is supposed to charge to 150
You may have a problem still related to the original reason it was reconditioned.
However, you should have a regulator that you set to the tank pressure you want to maintain. Most have a tool regulator as well and 40 psi sounds like that is what it is set for.
If you do have a tank pressure regulator and it is still not charging above 40 psi, then either take it back or pick up a new regulator for under $20 at Home Depot and replace the gauge you have now.
Also, sometimes the gauge will have a needle tilted so that one end presses against the glass, and if you tap the glass hard with your finger it will move on around to the correct pressure.
Finally, if you are not experienced with small compressors, look under your gauge and see if there is not a black knob that pulls out and pushes in to turn and change the pressure.
Sirwriter
May 21, 2009 | Stanley Factory Reconditioned Bostitch...
Pressure will not build up in the tank and the silver tubing gets extremely hot.
There is a moisture release valve under the tank that may have been left open. If so, close it and the pressure will build. The reason the tubing heats up is because it is running so long.
Sirwriter
May 17, 2009 | Stanley Factory Reconditioned Bostitch...
BostitchCAP60-OF won't pressure up past 95lb and keeps running
This comperssor is oiless thus has a vinyl piston ring that wears quite fast depending on use and conditions at the work site. Slow pressure build or cycle never completes indicates a worn cylinder and piston ring. I would replace the cylinder, piston ring, valve plate, and intake valve. These parts are not expensive and available at www.bostitch.com. enjoy
Dec 01, 2008 | Stanley Factory Reconditioned Bostitch...
Replaced leaking trigger valve wit new valve kit.
I have seen many small bostitch guns all with different problems that did not shoot nails. Both of your guns have simillar triggers. You might try the trigger valve from the gun that works to see if that is the problem. Most no fire situations come from faulty trigger valve. The trigger valve used in your guns has a part that stays in the body of the gun; be sure to replace both parts. If still no fire check the following:
Remove the head and check if the piston/driver travels all the way down the cylinder with the tip of be blade showing at the nose. Some piston/drivers have a grove that must be aligned.
Check that the headvalve travels into the head and returns. Push the valve in with your thumb then cover the small vent hole at the base of the head where the gasket sits with your finger and release your thumb. The headvalve should be held in with vacuum then pop up when you remove your finger from the vent hole. If the headvalve does not stay pushed in with the vent covered, the orings are leaking and can cause the gun not to fire. Try lubing the headvalve with light grease such as silicone lube. Do not use bearing grease. Silicone lube is available in small amounts at plumbing supply/lumber outlets such as Lowes. It looks like wax feels like shortening.
Reassemble the gun and check your work. I test the gun with-out nails and without the trigger installed. Just place the nose of the gun on a piece of rubber, (I use a piece of heavy garden hose rolled up tightly into a coil) and press the trigger valve pin with your finger. The reason that I leave the trigger off is that sometimes the problem is caused by the safety mech not pushing the trigger pin correctly. enjoy
Nov 15, 2008 | Stanley Factory Reconditioned Bostitch...
Stanley Factory Reconditioned Bostitch U/CPACK270 Finishing Nailer, Brad Nailer/Stapler & Compressor Combo Kit Logo
183 people viewed this question
Top Stanley Air Tools & Compressors Experts
John Trevino
yoopertech
Joe Garcia
Joe Garcia
Are you a Stanley Air Tool and Compressor Expert? Answer questions, earn points and help others
