Question about Kenmore 24032\24036 Top Load Washer
Kenmore 90 Series Washer - banging during spin cycle
We just moved a few weeks ago, and the washer acts like the basket is "off" a bit. I'm thinking it got jarred during the move. It bangs against the side of the washer during spin cycle. I tried to take the top off to see if it's sitting correctly, but can't figure out how to remove the top.
Suggestions?
catriver
  • 878 Answers
SOURCE: Washing Machine Suspension Problem?
smirkin, the question here is if the basket is listing against the tub or the whole tub and basket is listing. If the basket is listing and banging around it could be the drive block has worn or broken. I will attach a photo of one. If the whole tub is listing it could be a spring that broke. You can remove the front panel of the washer by pressing in on the two clips on each side of the washer top, The front panel should drop and pull out. You can see if any of the suspension sprins broke. The drive block is located under the basket. The agitator and basket have to be removed to change it out. Take a look at the attachments...Catriver..post back
Posted on Sep 07, 2006
  • 46 Answers
SOURCE: Banging while spinning
slid the machine out away from the wall and tilt back enough to see underneath. just below the door there is a large concrete weight. chances are it is loose and needs to be tightened. if this problem has been going on for a while the bolts holding the weight on will have snaped and the drum/weight or both will need replacing . ( ex hoover engineer)
Posted on Feb 08, 2008
  • 106 Answers
SOURCE: Kenmore front laoder washer with loose wash basket
Highly likely that either your bearings or spider arm has gone out, this is no easy fix. You can 'search' above or click on 'troubleshooting' in blue to browse
RepairClinic.com (which is good)
espares.co.uk
AppliancePartsPros.com
Try these sites for spares.
Posted on Feb 28, 2009
MalKontent68
  • 748 Answers
SOURCE: My Maytag goes out of balance and bangs loudly
This is usually due to the floor not being perfectly level, and as a consequence the washing machine not standing firmly on all 4 supports.
There should be at least 2 adjustable feet under the machine, try to make it stand as level as possible, with uniform load on all four.
If you have a bubble level it may help you establish, if there's an obvious slope on your floor and adjust the machine so that it's well levelled.
Posted on Oct 30, 2009
heatman101
  • 43501 Answers
SOURCE: banging noise on spin cycle
Believe it or not I have a washer just like yours and when that happened to me I found that the shocks that hold the drum were broken. I ordered new shocks online and replaced them and everything was fine and dandy again!
The shocks are a bit of a pain to install but not all that difiicult.
Do a search for "appliance parts" online and then enter your model number and you can easily find and order the shocks you need.
Check out different sites as the prices can vary for the same part and it seems that there is not any one site that always has the lowest price.
The new shocks also seemed to be built differently then the old ones. (heavier)
I hope that this will help you to solve your problem!
Thanks for using Fixya!!
Heatman101
Posted on Nov 24, 2009
Kenmore 90 tub spins excessively clockwise during wash cycle.
there should be 2 or 3 springs that hold it, they mite have broke, take off back panel an check.
Jan 04, 2010 | Kenmore 24032\24036 Top Load Washer
Kenmore series 80 washer off balance
Go to www.applienceparts.com and ask them for assistance, it is a free service.
Mar 13, 2017 | Kenmore Washing Machines
Kenmore 90 Series Heavy Duty Washer - Agitator doesnt spin
THIS IS A TYPICLE PROBLEM . BETWEEN THE MOTOR & THE TRANSMISSION THERE IS A COLLECTOR ASSEMBY (THREE PIECE
SET) REAL EASY TO GET TOO EASY TO FIX . ALSO COST EFFICENT
Sep 21, 2009 | Kenmore 24032\24036 Top Load Washer
Kenmore 90 series noise after spin
You need to replace the drive block and basket drive. You can download a tutorial to get you started at www.shop.washermd.com. The gearcase replacement tutorial will put you in the right direction. Dave
Mar 01, 2009 | Kenmore 3.2 cu. ft. Plus Top Load Washer
Kenmore series 80 washer makes loud knocking noise during spin cy
Unless your front loader is set firmly on concrete and leveled to perfection, the force of a heavy wash load spinning in excess of 1000rpm will create a bit of vibration and noise.A firm footing is your best defense against to much movement.
Also due to the earlier movements during the spin cycle, the shocks that are used to dampen the spin cycle might have been broken or damaged.
If the problem persists inspite of proper levelling, please do check for the shocks or might have them replaced them for good.
Dec 14, 2008 | Kenmore 24032\24036 Top Load Washer
Kenmore washer series 70 shakes wildly during spin during cycle
I have the same kenmore and have experience this before. It is unbalanced. Get a spirit level to check for balance. To rebalance, empty the washer (so it's not heavy), lean over the washer and grab the back, tilt it forward and the auto balancing legs should reposition themselves. Re-check for balance using the spirit level. If still out, adjust the front feet of the washer by screwing the legs up or down (using a wrench). This will cure the problem (unless you have a very unbalanced load of towels for instance). Good luck
Mar 30, 2008 | Washing Machines
Thumping and banging
make sure all shipping pins are out the tub should move all around from side to side if it level still bangs its eather the balance ring top basket are there 3 slides on a plate above the motor just put some silacone oil on tham move around
Feb 09, 2008 | Kenmore 24032\24036 Top Load Washer
Intermittent spin cycle on Kenmore 90 Series washer
You may try the speed selection switch.....Ive had problems with these.
Jan 23, 2008 | Washing Machines
Kenmore washer 90 series wont spin
If your trans and coupler are good then I would suspect the drive block or spin tube. You will have to remove the trans to change out the spin tube. Take out the basket, there should be 2 ears from the spin tube that nest in the drive block. Attached is a photo to help you understand. Before all this make sure nothing is caught between the basket and the tub. Catriverd8086fb.jpg
Nov 26, 2007 | Washing Machines
Yes the brakes are grabbing too hard....I will sometimes lubricate them....Or replace the basket drive assy. You do know how to take the cabinet off i take it??
Oct 02, 2007 | Washing Machines
Kenmore 24032\24036 Top Load Washer Logo
273 people viewed this question
Sal De
fordexpert
Whirlpool
Whirlpool
