SOURCE: SIM Card
Verizon is a cdma network and does not use sim cards you will have to go into the store to get the phone switched (they might charge you $20) or call customer service (1-800-922-0204) or do it online yourself by logging on to the vzw my account website.
SOURCE: sim card rejected
this happen if there is some problem in the sim card holder port ....
there will be loose contact inside the sim card holder is not touching the circuit board inside due to this your sim card is getting rejected ...
as you have told that the phone is a brand new one so i am sure that you will be having the warranty so just make use of it by contact the dealer with whom you have purchased or contacting the company customer care number to get more information about how to make use of your warranty ......
if you dont have the warranty then you must open the handset
and just remove the circuit board & sim card holder and insert it again so that the sim card holder touches the circuit board correctly ...
after this refit the phone then surely your sim will be accepted ....
it is better to use of warranty if you have ......
this is a simple problem if you dont have the warranty also you can only fix it ..
if you just open the handset & set that sim card holder to touch the circuit board that s enough everything will be done and works fine ...
if you are afraid of opening then you must just contact the technician ...
it is just a matter of very little bucks if you contact him also ...
any doubts you can reply me
i am always here to assist you
thank you
bye
rate my solution
SOURCE: screen broken, can't see to transfer phone book to sim card
take the phone to ur phone service they should be about to transfer it to ur new phone
SOURCE: I broke the screen on my phone, so I have moved my sim card
Press options when you open up your contacts and choose "save to SIM' or "copy to SIM' and it should work that way
SOURCE: how to fix an invalid sim card
try a different sim card if that doesent work then it might be the phone
