Question about Home
Tank not filling except when I push down on the top of the fill valve (or top of threaded rod), depressing the float. All lines clear and straight.
  • 308 Answers
If all you have to do is push down on the float to get water to flow, then it sounds like a new float mechanism would solve your problem. Maybe an adjustment would suffice.
Hope this helps
Posted on Jul 13, 2009
How can I adjust the waterflow to a lower setting to make it 1.2 gallon flush from a 1989 3.5 gallon flush??
Keep in mind that if you limit the amount of water too much, the 3.5 gallon toilet will not flush properly.
This looks like an old Kohler Rialto toilet. The proper way to adjust the water level is to tighten down on the adjustment screw located on the very top of the fill valve. The fill valve is the the piece that the float ball screws into on the left side of the tank.
Tighten the screw down and flush the toilet. Wait for it to refill, and check the level. If you need less water, tighten again, let fill and check level.
There are also two old school methods to save water in your toilet. One is to put one or two bricks into your toilet tank. This reduces the amount of water that fills the tank. The second method is if the fill valve has a float ball on a metal rod, you can bend this rod down into the water. This makes the fill valve shut sooner. Don't bend too far or too fast because the chlorine in the water weakens the brass rod that the float ball attaches to.
Nov 29, 2016 | Home
Water level is set too high and runs over the overflow. how can i adjust the water level in the tank?
Inside the tank, on a lever arm there should be a cylindrical float that rises and lowers with the water level. Attached to the float is a float rod with a clip that can slide up and down the rod. You can adjust the water level by sliding the clip down to reduce the amount of water entering the tank. As the water fills the tank, the float rises, pushing up the float rod, which in turn pushes up the level that controls the valve allowing water to enter the toilet.
Jul 29, 2011 | Kohler K-3515-0 Memoirs Comfort Height...
Just need to know how to adjust the 'arm' of the ballcock to lower the water level in the tank. Do I use the screw at the base of the arm?
Hello...
To adjust the water level, you need to set the height at which the float shuts off the water valve. There are several types of floats. In older toilets, the float hangs at the end of an armature, along a metal or plastic rod. Where that arm connects to the water valve there is usually a screw. Adjusting that screw will change the level at which the water valve shuts off. If there is no screw or it is already at its maximum, you may be able to bend the metal arm, but you should remove it from the valve or risk damaging the fill valve.
In newer toilets the float is often a collar around the fill valve and rides up and down vertically. The float typically has a spring clip connecting it to a metal rod which connects to the valve shut off control. Squeeze the spring clip to slide the float up or down the metal rod.
Manufacturers have several variations on the fill valve mechanism, but they all include a method for adjusting the water level. Close inspection should make it clear how to adjust your particular fill valve.
I hope this helps!
Jan 08, 2011 | Crane Plumbing 3755 Toilet-To-Go Metro...
When I flush thenwater fills to the fill line and slowly keeps on dripping over the top of the flush valve tube.
I would ckeck to see where water fill line is inside toilet tank and then adjust flush valve to try to get it to shut off at this point. Not knowing whether your toilet still has original flush valve it is hard to tell you how to fix it. If it has float mounted on rod to flush valve there is usually a set screw on the top of the flush valve in the center. Turn this screw clockwise to make valve shut off sooner. Try to set it so that water shuts off when it is at fill mark. If float is mounted on brass float rod you can support rod closest to flush valve with left hand and carefully bend rod down a little with your right. This will cause flush valve to shut off sooner. If the seat is worn to badly in flush valve you will need to replace it.
Nov 18, 2010 | American Standard 2004.014.178 Champion 4...
My toilet makes a high pitched whine after being flushed. Pressing down on the top of the tank mechanism makes it go away but the next time it flushes the whine returns.
I would suspect that the flush valve has a blokage in it that is causing a harmonic distortion to be transmitted thru your cold water piping.. One way you may be able to help this is to slow fill rate down on your flush valve. If your fush valve has a seperate float to shut off water supply to tank when it;s full there should be a adjustement screw onside of valve where float rod goes in. Adjust screw down to raise float and thus slow fill rate of tank, this should help with the noise. Ifyour toilet does not have adjustable float see if you have a valve on incoming water supply. If you do you can try slow down flow thru supply valve and see if that helps, Thanks
Nov 18, 2010 | Kohler K-11466-0 White Cimarron Comfort...
Just bought a new toilet and installed it in my bathroom and after everything was installed to the t i turned the water supply on and nothing filled the bowl or tank ???? what could be causing this ?
It is possible that there could be a packingbrace holding fill valve shut if so remove it.On som types of fill valves that have a float ball on a rod attached to fill valve.Usually on the top of the fill valve there will be a screw that adjusts height of float ball.If float is adjusted to high it will not let water in.Turn screw counter clocwise and see if it lowers rod and float ball.You should see water start running into bottom of tank.If this works you can adjust screw until you get a reasonable fill time about 45-60 secondswould be good.Hope this helps. Thanks.
Nov 08, 2010 | Home
How can I adjust the water level in the tank?
With a standard Fluidmaster fill valve, on the side of the float there is a rod that controls the depth of the float. On top of that rod is what looks like a phillips head on a screw. You can use your fingers usually, but if you would like you can use a screwdriver, simply move the float level up and down by screwing either clockwise or counter clockwise to change the level in the tank. Flush a little water after making the adjustments to guage the water level when the fill valve shuts off. Good luck
Aug 14, 2010 | Fluidmaster & Fits-All Faucet Connector
Hissing sound in tank (fill valve) . fills too level line & keeps then slowly fills too top, floats been adjusted .
Dear Sir,
It appears you need to adjust the float level so that it applys more pressure quickly to completely shut off the water going into the main filler tube. Does the hissing go away when you lift up on the float toward the ceiling? If it does, then you need to what I said above. Turn your float ball out farther, or carefully bend your rod down toward the base of the toilet so that it applies more pressure quickly. This should solve your issue.
Cro Dave
Oct 18, 2009 | Jacuzzi Bath Perfecta EZ33 959 White round...
Toilet won't stop running
I have a Kohler toilet and Ingenium fill valve 85297-AA. My toilet kept running, the fill valve black cylinder wouldn't pop up and when I added blue food coloring to the tank, the blue color seeped through to the toilet bowl. First I replaced the flapper and that allowed the fill valve piece on the cylinder to pop up correctly and blue dye no longer seeped through to the bowl. I still heard a hissing sound when the toilet tank had filled and no water was going into the overflow tube. I called the tech support number on the Kohler website 1-800-4KOHLER (1-800-456-4537) . Here's what solved the problem: Turn off the water to the toilet.Take off the white cap of the fill valve by pushing it down and turning it counterclockwise as you would open up a childproof pill container. Then unhook the metal hook. Hold a cup upside down (I used a strong plastic cup) over the part of the fill valve that is left in the tank and turn on the water. (You need the cup because otherwise the water will squirt up to the ceiling.) The water will flush out the fill valve. Replace the cap and the hook and flush.
Nov 28, 2008 | Home
Home Logo
227 people viewed this question
Top Home Experts
john h
Tom Chichester
Are you a Home Expert? Answer questions, earn points and help others
