I have a Marantz tuner TR-2242 that is a matching set to an amplifier. The problem I'm having is the output from the tuner has dropped way off and now I've got to turn the amp power almost all the way up just to hear the tuner. The problem is not in the amp as other components playing through the tuner input sound just fine. The problem is in the output level of the tuner.
  • 1 more comment
  • kayleemae Jul 13, 2009
    micromatikal To miromatikal:
    Thank you for the suggestion on cleaning the outputs. This did not change anything and I am inclined to believe the other advice on the voltage not being enough for whatever reason is the answer. Can you give me any advice to check this out? I have some electrical knowledge and I have a multimeter. It is 1 pm here and I leave for work shortly and will reply this evening.
    Thank you,
    Dennis
  • kayleemae Jul 15, 2009
    I will contact Marantz. But in truth it looks like there is not much more you can do. This was not a good idea to ask you people and a waste of time and money. I am disappointed in this exchange and can see that your site is mostly for people who are not literate on operating electronics, and mostly simple stuff.
  • kayleemae Jul 17, 2009
    this is a start
    Top Expert:
  • Audio Player... Master
  • 76,673 Answers
U have a burned out output preamplifier circuit, that is the only explanation for this low volume.
Posted on Jul 15, 2009
    President:
  • 2,777 Answers
You are definitely correct that the issues is originating from the output of the tuner. There are a couple possibilities. The first, and easiest, is the clean the actual connection between the the two devices. A little rubbing alcohol on a q-tip would be best to start with, maybe a little something abrasive as well to really scrub off any other build-up on the input. Also you may want to re-strip the actual wire connector as well, most audio professionals recommend re-stripping your actual connectors at least every 2 years.
Other than that it could be a voltage / power issue, not getting enough power to the output. If this is the case it could be a variety of things internally on the unit. If the cleaning tips above don't work you will probably want to call Marantz for information on having it checked out. Their number is 201-762-6666 for technical assistance.
Posted on Jul 13, 2009
  • Tim Grayson
    Tim Grayson Jul 13, 2009
    I am not certain of what the actual output voltage should be, if you give Marantz a call they should know this information. I will continue to check around on my end, but I would think by calling them they will know the info off hand or at least can get it much faster than I can. They are usually very good at customer support and service, even on older models. Tell them you are a loyal Marantz customer! =)
    Go ahead with any replies as well, I will see what I can find.
    Thanks
    Tim
  • Tim Grayson
    Tim Grayson Jul 15, 2009
    Whatever you say
I have a Marantz turtntable, a Marantz CD player, an Eltax tape player and a Marantz amplifier with two Cambridge speakers, how do I wire them up please.
If you have a pure amplifier, there may only be one set of inputs, and one or two pairs of speaker outputs. The inputs are probably RCA plugs. Connect the CD or tape player to these. The speaker outputs are typically heavier binding posts or wire clamps. Each speaker should have one pair of wires. One for the 'Red' post, another for the 'Black' post.
If you have a 'Receiver' you will have several inputs to use and switches in front to select them. The CD and tape can be plugged into either tape, CD, or Aux inputs. (Not 'Phono') The speakers hookup is the same as for the amplifier.
You may also want to google the make-model of your amp to find a manual....
Mar 11, 2015 | Marantz Audio Players & Recorders
How can I connect an equalizer to my Marantz sr-66 ?
Does it have a loop through connection that is before the amplifier section of the tuner? If not I'm not sure you can. If so then you need to connect the equalizer in this section of the tuner.
The owners manual should be able to tell you more than I can find on Google
Oct 07, 2014 | Marantz Sr-66 Audio Video Surround...
How do I connect my marantz pm8200 to TV
You can connect TV RCA outputs to any line input e.g. tape, tuner, CD etc on the Marantz. If your TV doesn't have separate RCA outputs use a 'scart to RCA audio outputs' adaptor... TVs have a standard line output level compatible with most if not all hi-fi.
Aug 12, 2014 | Marantz Audio Players & Recorders
Marantz Legacy Series - no sound is getting to speakers from tuner or cassette.
It seams like the amplifer is not working and you are right but it certanly needs to be measured first.
Nov 28, 2013 | Marantz Tr 2242 Sb Legacy Series Pll...
Watt impedance (ohm) headphones is ideal for amplifier 4-8 ohm (what impedance output for headphones is for amplifier with 4-8 ohm impedance ? )
I do not get very clear picture of what are you trying to ask but if its about what impedance should match an amp with 4 or 8 Ohm?
Nov 01, 2013 | Marantz PM5004
I have a marantz av550 pre amp/tuner. One of the audio outputs is not working. It had been cutting in and out for a while and now no output. It is not the cable, the amp or the speaker. Is this so
It sounds like the output transistors went bad What I would do is check all output transistors in the unit they are usually the large transsistors on heat sink that an ohm meter and check each transistor while unit is off and no power go base to collector then emmiter to base if you get o or continuity on those legs on any one they are bad .
Dec 07, 2012 | Marantz Audio Players & Recorders
Marantz cd44-minimal sound when playing cd. Amplifier (rx163) works with tuner. I have tried cleaning head but with no sound improvement. Any suggestions?
I can't find any pictures or reference to a CD44 but if it's a CD player there would be no point in cleaning the laser lens if ity makes ANY sound at all. The bits don't get louder. Ones and zeros don't change. Look for an output control. Many players had fixed and variable outputs.
Jun 15, 2011 | Marantz Audio Players & Recorders
Marantz amp will not put out any sound
If it went out with no indications of trouble it's probably a fuse in the output circuit. It might be an out put amp but typically they let you know they're going bad with a little noise.
Feb 16, 2009 | Marantz Audio Players & Recorders
Can I remotely control speaker outputs on the Marantz PM 8003?
HI...
You need an 8 ohm stereo "L-pad"
Try partsexpress.com
or
mcmelectronics.com
Dec 21, 2008 | Marantz Audio Players & Recorders
Stereo connection
Hi spanky
Sorry for the delays in getting back to you. Been busy here this week.
OK. to connect the 2275 to the 1152,there are 2 ways of going about this.
You can plug the pre- out of the 2275 to the power amp-in of the 1152. In doing this you are using the power amp section of the 1152 and the preamp functions of the 2275. Your other gear like CD player, tape deck and so on also plug into the 2275.
the other(better) way is to plug the pre-out of the 2275 into the tuner inputs of the 1152, leaving the volume at about 40% on the 2275 and use the 1152 as an integrated amp. This means you are using the 2275 as a tuner only. When you do this, you will need to use an RCA lead to jumper the pre-out/poweramp-in connections on the back of the 1152, and the 2275 ... L to L and R to R respectively.
I am still wondering why you want to use 2 integrated amps (each having a preamp and a poweramp section) The only real benefit the 2275 brings to your system will be tuner functions. You could just get a tuner and run the 1152 to be an ideal rig.
Let me know what your ideal setup you are wishing to build would have. Speakers, other gear like CD, tape deck, etc.
regards
robotek
Jul 23, 2008 | Audio Players & Recorders
54 people viewed this question
 Grubhead
Grubhead
