Question about Lanzar Vibe 210 Car Audio Amplifier
Do you have a manual on the lanzar 210 how to bridge getting loud bumping sound when 2 rca jacks are plugged in?
  • Lacey Simmons May 11, 2010
    Are you trying to bridge the amp and you need info on how to ? or are you getting a vibration sound when the radio is off ?
  • 578 Answers
LOOK AT WHERE THE SPEAKER YOU WILL SEE BRIDGE DIAGRAM
Posted on Aug 07, 2009
How can i bridge all 4 channels together on my lanzar vibe 410 car audio amplifier
you cant , you can only bridge 2 channels together and what are you trying to run off the amp?
Jan 30, 2011 | Lanzar Vibe 410 Car Audio Amplifier
Can I hook up 2 lanzar opti1532d subs to a kicker kx 1200.1 or do I need a bigger amp, its 1ohm stable an the birth sheet says 1390 but with 14+ it does 1400rms...
Yes you Can. run them bridged parallel. meaning on the amp where the speaker wires attach there should be labeled with a "+" and "-" with a line drawn to show which terminals to hook the bridge wires up to. bridging takes power from both sides of the amp and puts it into one strong signal on half the wires. from there run your "+" wire to the first "+" on your first speaker. run your second wire from "+" on spk 1 to "+" on spk 2. repeat process from "-" on amp to "-" on first speaker and then to second speaker. __ ' a'"+"________"+"_______+ Good luck, may the force
/ ' 'm'"-" spk spk be with you!
bridged \ '__ ' '"-" ________"-"_______"-"
this will get you the most sound from the amp. if using 4 ohms speakere you will be running a 2 ohm load bridged.
Dec 23, 2010 | Lanzar OPTI1532D Car Subwoofer
Osprey 210 audio problem
The breakout cable has the RCA connectors needed. Yellow is Video, Red and White are the 2 audio inputs. Alternate inputs are the 1/8" stereo jack for sound and the S-Video plug. (not to be used all together).
viewcast.com is their website.
Also check the setup for recording, that the audio source is selected properly.
Mar 24, 2010 | ViewCast Osprey 210 Video Capture
I have 2 12" L7's
the kicker l7 will handle all that amp will put out .. bridge the amp and hold on
Feb 09, 2010 | Lanzar VIBE266 Car Audio Amplifier
I paid a store to hook up my lanzar vibe 241 amp and 2 lanzar 12" subs(all brand new). It sounds ok but i have a loud buzzing coming out of it constantly and when i use my power window buttons I hear a...
To get rid of the buzzing sound just go to walmart and in the car stereo section buy the $10 rca ground loop isolator, this is the best way to get rid of amp noise
Oct 11, 2009 | Lanzar VIBE241 Car Audio Amplifier
I am getting a loud bumping sound when 2 rca jacks are plugged in..
Hiya limited info but thats normal -as the rca goes in in makes a once off pop noise and also suggest the amp is fine. If the noise continues (which was not clear sorry) then the problem could be preamp, x over etc if there is a problem??
Its better to plug in RCA etc when the amp is off as well. Have known amps to go bang from this.
Best of luck
Jul 13, 2009 | Lanzar Vibe 210 Car Audio Amplifier
2 ohm speakers wont work on a lanzar max pro 4000 watt
The 2 ohm stable rating on the amp is PER channel meaning that you could effectively hook up a 2 ohm speaker or a 2 ohm load to each channel without the amp getting f"d up-butin bridged mode it will only be 4 ohm stable. to achieve a 4 ohm load with your sub the type x wire the coils in series that will get you at 4 ohms to run in bridged mono .But you will get the exact same amount of power if you wire each coil to one channel of the amp as bridged mono sees the sum of your 2 ohm channels combined-Hope that helps.
Jun 08, 2009 | Lanzar VIBE266 Car Audio Amplifier
I need repair help. no schematics
Blown Mosfets
A thumbs up would be greatly appreciated if this answer is helpful to you. need-repair-help-no-schematics-zb4bomd1rt4qms0dqd12kkt2-5-0.jpg
Nov 08, 2008 | Lanzar VIBE266 Car Audio Amplifier
Sub for lanzar mxa 282
2 X 18" Kicker CVR they will work really clean. 2000 watt max each and 1000 RMS just like your amp.
Nov 16, 2007 | Lanzar MXA282 Car Audio Amplifier
Lanzar Vibe 210 Car Audio Amplifier Logo
149 people viewed this question
Top Lanzar Car Audio & Video Experts
Radames Pagan
Radames Pagan
Joe Alexander
Joe Alexander
Chris Ward
Are you a Lanzar Car Audio and Video Expert? Answer questions, earn points and help others
