Question about Sub-Zero 690 Side by Side Refrigerator
Light bulb is out
HOw do i change the lightbulb in the refrigerator?
  • 76 Answers
Switch the fridge of, there is a white plastic cover over the bulb which may have one screw in it, take out the screw and unclip the cover, the bulb should then unscrew in an anti clockwise direction, take it along to your local B & Q or similar, I am sure they sell them there.
Posted on Nov 18, 2007
3 Suggested Answers
erpaalai
  • 999 Answers
SOURCE: my lightbulb in my fridge won't go on
Check the tab in the center of he bulb socket. Unplug the frig first and gently pull it up a little. You should be using a 40 watt appliance bulb not a 60. If the tab is not the problem you may need a new switch.
Eric
Posted on Apr 30, 2010
SOURCE: The lights do not turn on when opening the doors despite changing the bulbs.
It sounds like the door switch. Check to see if it is sticking -- it should come out when the door is open. If it's not sticking, the switch probably needs replacing.
Posted on May 02, 2009
How to change light bulb
on what would you like to change the lightbulb and what is the model number if it's a refrigerator I need the model number of the refrigerator found inside the fresh food compartment or on the back
Nov 19, 2015 | Refrigerators
Lightbulb not working in fridge freezer.How do I remove panel to get to bulb
Try pushing the sides of the plastic to remove it. Then you can access the bulb. Do not remove the bulb with your bare hand. Use a dry towel because if the bulb breaks in your hand, you have a problem. Unplug the fridge when you do this.
Feb 02, 2014 | Refrigerators
How do I locate and change the lightbulb in the lower part of the refrigerator side?
it s a little hard but remove the lower crispers and the is a light cover idem 259 remove it and the light is there . use a 40 w appl bulb only any larger will not fit and will melt the plastic cover .. mm hope this helps . feed back pls ..
Jan 20, 2011 | GE Profile CustomStyle PCF23NGT Side by...
Need a replacement for broken freezer lightbulb. Will a standard lightbulb work? What is wattage? Model 7957830 Thanks Ted
no,it will not last if it work.better to buy the same light bulb required. 30watts max.
Dec 23, 2010 | Refrigerators
My lightbulb in my fridge won't go on
Eric
Apr 29, 2010 | Refrigerators
Where the lightbulbs located in the refrigerator.
u can find on the sides or on opposite side or the door......or some will have only one bulb or light source as u know its in the top......
Jul 01, 2009 | Whirlpool 25.6 cu. ft. Side-by-Side...
May 02, 2009 | Refrigerators
Freezer broken lightbulb
you can usually take a potato and screw the broken bulb out and find a new one home depot lowes or walmart
Apr 24, 2009 | Magic Chef CTB1521 Top Freezer...
KSRS22FGWHO4 INTERIOR LIGHT LOCATION
As I mentioned previously, I had previously tried a new bulb behind the control panel and it didn't work. I tried again, but first I unplugged the refrigerator, and then installed the new bulb. And when I plugged the refrigerator back in, the light worked!
I am not sure why unplugging the refrigerator before installing the new bulb worked, but it did.
Darrell
Sep 11, 2008 | KitchenAid (KSRD22FKST) Side by Side...
Sub-Zero 690 Side by Side Refrigerator Logo
262 people viewed this question
Top Sub-Zero Refrigerators Experts
Charles T Nevin
Charles T Nevin
Sal De
John Tripp
John Tripp
Are you a Sub-Zero Refrigerator Expert? Answer questions, earn points and help others
