Question about Samsung Televison & Video
'MODE NOT SUPPORTED' message appears on my TV screen
Every few minutes, my digital cable will cut out and the TV will display the message, 'Mode not supported'. I still have audio, but the screen is blank...other than that message.
I have samsung 22' lcd series 4 tv but i connected it with the dvd player via hdmi it shows mode not supported. but the same dvd works very well on another samsung lcd of same configuratition. please help me
Posted on Jun 21, 2012
  • 304 Answers
Chances are that you have the tv hooked up to a Cable or Sat box using aHDMI cable. The problem is with the source and the HDMI protocol. There is a known HDMI issue with some brands of Cable and Sat boxes using the HDMI cables. A work around is to hook up the source to the tv with Compoment Cables. This will usually eliminate the problem. The fault is not with your set.
Posted on Jul 16, 2009
Proscan tv will not receive or recognize cable or video signals when all plugs are in as prescribed. Have removed power supply waited to attempt to clear it. Restarted and still get no signal message. We...
Here are a few ideas:
  • The No Signal, No Source or No Input message will appear on your television screen when the television is not receiving a signal from your Digital Box. This is often a result of either the Digital Box being powered off, not being properly connected to the TV, or if the TV is set to the wrong input.
  • Press the "TV/VCR" button on your remote control if you are experiencing no picture. This button will allow you to toggle between TV and VCR screens and may solve your display problem.
  • Make sure your cable box is turned on.
Jan 21, 2018 | Shopnbc Proscan 32" 720p 60Hz LCD HDTV w/...
The words "Digital Noise Filter
The words "Digital Noise Filter Off" and "digital Noise Filter On" appear on the top left and right and side of the screen and the words " Auto Visulisation" appear on the bottom of the screen all the time when watching normal T.V.(series 5 lcd) and if we make changes regarding in setting in picture option in mode.then after 20-30 min againg it displays same message
Feb 01, 2011 | Samsung LE40R74BDX 40 in. LCD Television
My i-touch is chirping and only icon shows up on screen
take it to an apple store? or you can try pluging it in to ur computer.
Sep 04, 2009 | Apple iPod touch
Problem with lcd 22'' tv come monitor connection
firstafal youtell that detials you working to onborad vga are addan vga tell ok aftar you insttall that display drivers
Nov 25, 2008 | Samsung Computers & Internet
Polaroid flm-3232 locked or in sleep mode? Is that...
Try to read your product manual caferfully all information are cited in the manual in order to have a smooth operation of your unit.
Oct 19, 2008 | Polaroid FLM-3232 Television
Aspect ratio problems on Samsung LN-S2651D Flat Panel TV
The aspect ratio (zoom) button on the cable remote had been changed. On Brighthouse the # button toggles through the zoom settings. It's not a tv issue, it's a cable fix.
May 29, 2008 | Televison & Video
Trying to connect Inspiron 6000 to TV
If there is no display on your TV, HDTV, or Projector, please make sure that all of your connections are set up properly and that you have enabled the display in the Catalyst Control Center. The connectors that you will be using would be Svideo for TVOUT, DVI-to-HDTV (Component video), VGA-to-HDTV (Component video) for HDTV, and DVI, VGA, or Svideo for the projector.
737-22474-1.jpg Here are the steps to properly setup and enable TV, HDTV, or Projector:
  • Turn off your PC and your TV, HDTV, or Projector.
  • Ensure that your card was installed correctly, as per the Getting Started Guide.
  • Determine if your TV, HDTV, or Projector has a S-Video (for TV), YPbPr for (HDTV), or VGA/DVI for Projector.
  • Looking at the back of your PC, locate the needed connector or the supplied adapter cable; attach one end of the cable to your graphics card and the other to your second display.
  • Turn on your second display then your PC.
If you are connecting an HDTV to your video card, please Click here for detailed instructions on how to set it up correctly.
Starting Windows with TV or Projector Display Enabled The TV screen may become scrambled during the initial Windows® logo display. This is only a temporary effect and your screen will be restored within a few seconds. During start up, your RADEON will go through a sequence of mode settings, during which your TV display will remain blank. This process takes only a few seconds and helps program the TV display.
  • To enable the second Display
  • Right-click anywhere on your desktop
  • Click Catalyst Control center
  • View
  • Advanced view
  • Display manager
  • Detect Displays
  • You should have the second display picture under “Attached displays currently disabled
  • Drag it to the box on top of it
  • Apply
  • OK
If for any reason the second display does not get detected, please do the following:
  • Open the CATALYST CONTROL CENTER
  • Go to Display options
  • Check “Force TV detection” *
  • Apply
  • OK
* Force TV: Allows you to force TV detection if the ATI driver does not automatically detect TV-out connected to the graphics accelerator.
Possible issues:
In case the users display does not natively support HDTV display timings in the EDID, you can add standard HDTV modes so that the usual HDTV resolutions (720p, 1080i, 1080p) are listed in the Display Manager resolutions. You can also create custom HDTV timings to solve any kind of over-scan options (for cases when the windows desktop appears to not fit on the HDTV screen, and the outside boarder is cut off).
For more information on connecting your second display to your Video card, including supported output device combinations, please refer to your user’s manual.
Jan 23, 2008 | Dell Inspiron 6000 Notebook
Sound cuts out every so often when using Coax Digital In
DI cables have little end caps, make sure they are removed
Mar 04, 2017 | Audio Players & Recorders
solution to Both our problems is this, call Philips, "it just so happens that we have a rapid replacement program for this particular system"-"there seems to be an internal electrical problem", so I'm sending it back to them.......
Dec 12, 2007 | Philips HTS-3555 System
LCD screen black, no viewed image displayed.
Internal video out connection may be bad, try using the provided cable to connect to TV and disconnecting to see if it returns to normal.
Apr 30, 2007 | Ricoh Caplio GX Digital Camera
Televison & Video Logo
886 people viewed this question
Jerry Greenberg
Jerry Greenberg
