Question about Yamaha 12V Air Pump
2008 vx110 waverunner... friend ran into shallow water (sand) where he said he got stuck (sand bar) light came on (probably overheat) and engine stopped... engine will crank but wont start..what to check? what effect will running in shallow sand (or getting stuck like this "friend" did do to engine.. what should we check before going in for service)
    Scholar:
  • 101 Answers
The damage that can result from overheating an engine would be piston seizure. Without the cooling water circulating around the outsides of the cylinders to dissipate the heat from combustion, the piston temperature rises higher and higher. As the piston(s) get hotter, they expand. Being aluminum, they expand more than the liner of the cylinder does, and eventually expand to a size bigger than the cylinder. That is when the seizure happens.
At this point, you need to do a compression test on all 4 cylinders. You should have at least 150 psi on each cylinder. Anything lower than that is indicative of a problem.
Posted on Sep 23, 2009
2008 Yamaha VX110 Deluxe will not go past 35 MPH in the water it's like it's restricted
A f
Few things to check would be >>>make sure the intake grate for the pump is clean and then remove the hood and make sure you are getting full throttle response bye checking the throttle linkage.
Dec 11, 2016 | Yamaha 2006 WaveRunner VX110 Deluxe
Waverunner problems
check the thermostat in a cup of hot water and see if it opens !
Mar 05, 2014 | Boating
2006 yamaha waverunner FXHO will not accelerate above 15mph
vx110 , are all cylinders working ?? could be plugs, injecters, or worse the valves aresticking open ! pressure drop test by dealer !! compression test also ! clean fuel ??
Jul 07, 2013 | Yamaha 2006 WaveRunner VX110 Deluxe
1995 Yamaha Waverunner III dies won't run
Check cylinder compressions, this ski will overheat if one side is low. Thus is step one, if ok and within 10% of each other, verify the exhaust isn't clogged with sand from "beaching" third verify the crank seals are not leaning the Mix causing an overheat. Obviously check the impeller housing to exhaust line isnt clogged, disconnecting the thermal sensor is asking for a top end rebuild which is about 500.00 they are designed to reduce revs and alternate spark to the cylinders once 200 degrees is reached.
Jul 31, 2012 | Water Sport
I bought a 97 gp 1200 waverunner and the first few times i took it out it ran great, i changed the spark plugs because it wasn't opening completly up at wide open throttle. I put it the water and it...
THE BEST WAY TO CLEAN OUT YOUR INGINE AND HOSES IS TO HOOK UP THE FLUSH HOSE TO THE SIDE OF THE WATERCRAFT ,,,,IF YOU DONT HAVE THE ADAPTER CONECTION HOSE YOU WILL NEED TO GET ONE ITS A VERRY IMPORTENT PART OF MANTENACE ,,,,YOU NEED TO FLUSH IT OUT EVERY TIME YOU TAKE IT OUT OF THE WATER TO KEEP ALL THE SAND FROM BUILDING UP IN YOUR COOLING SYSTEM,, AND TO GET ALL SALTWATER OUT THE SALTWATER WILL EAT AWAY THE HEAD LITTLE BY LITTLE,,PLEASE NOTE SOME MODELS HAVE A HOOKUP IN THE VERRY BACK WHERE YOU CAN HOOK A REGALAR WATER HOSE TO,,,HOPE THIS HELPS.
Jul 19, 2011 | Yamaha Alp 40 Motorcycles
1994 Yamaha Waverunner 3 will idle but wont take throttle
1994 700 cc waverunner when it has run for 15 min engine bucks at full throttle at 3/4 ok i have changer plugs antreated fuel
Aug 01, 2009 | Yamaha 12V Air Pump
I have a 2008 Yamaha vx110 deluxe waverunner that idles high.
I dont know the answer but my vx deluxe is doing the same thing. Not as bad as yours but 4k rpm idle.....ANyone?
Jul 13, 2009 | 1997 Acura CL
Excessive smoke coming from waverunner exhaust
is their a trick to putting on exhaust 1998 waverunner xl 1200?
May 27, 2009 | Yamaha 12V Air Pump
Yamaha 12V Air Pump Logo
693 people viewed this question
Top Yamaha Water Sport Experts
Colin Stickland
Colin Stickland
Piyal Perera
Piyal Perera
Are you a Yamaha Water Sport Expert? Answer questions, earn points and help others
