Question about Black & Decker Garden
B & D Firestorm 14.4 v battery virtually flat goes onto charger - LED flashes red then goes green - battery does not charge. Is it the battery or the charger??
hawk127311
  • 350 Answers
SOURCE: dc1804f charger
If you have tried discharging the batteries prior to charging them already with no result and from what you describe in your post, then I would have to say the charger has issues. Go to HD or Lowes (not sure if Lowes carry Makita) but another charger and test your battery again. If you get the same fault, there is an issue other than the charger, if not you need a new charger anyway. If you get the same fault with the new charger, you can always return the new one. Short of opening up the charger and using a volt meter, this is the easiest way to test to pinpoint the real problem. I hope this helps and good luck!
Posted on Nov 06, 2009
SOURCE: when the battery is in the charger it flashes red
I called casio and they told me that when you have a red flashing light on the charger it means the lithium battery is no longer any good. They offered to send me one free of charge. It's been several weeks and I have yet to receive it.
Posted on Jan 25, 2010
SOURCE: My paslode batteries will not charge. The charger
You can buy a new battery from Batteryprice.com for $22.68 plus shipping or you can buy a rebuild guide booklet for about 10-15 bucks on line, good luck, Jim
Posted on Jan 20, 2011
rowdy45176
  • 2176 Answers
SOURCE: hi i have a makita charger that flashes red and
there is a problem with the charger and given the age I would take it to an authorized dealer and get a replacement. If you give me your general area I will try and locate one close to you. Please before voting if you need more assistance let me know. Thank you
Posted on Feb 02, 2011
kjnwertgvwr
SOURCE: why when I put my paslode battery on to charge
The battery is gone for sure... You must get new one... take a look on amazon (my recommendation): Amazon com nailers paslode battery
Posted on Nov 29, 2014
WORX BATTERY CHARGER. when i PUT THE CHARGER ON THE GREEN LIGHT COMES ON.
Mike, The red LED is suppose to be on when you insert battery, the LED will go green when battery is charged. Look in your manual, Pg. 11 charging instructions. Check the attached links,manual,instruction and guides, Good luck
"I hope this helped you out, if so let me know by pressing the helpful button. Check out some of my other posts if you need more tips and info."
http://pdfstream.manualsonline.com/7/72bd8a7a-cf98-43d4-92b7-a15bc78eb6bb.pdf
Battery Driven String Trimmers
How to Check Li ion Battery
Jul 15, 2016 | Worx Gt Wg151.5 18v Cordless Electric...
My charger flashes red/green and does not charge my scooter. Any suggestions?
hi the red led should not flash the green led should only come on when batteries r charged while charging the green led turns orange or yellow....can u borrow another charger just to check to c if its not the scooters charging circuit that is the problem..or the batteries ..good luck
Sep 19, 2015 | Health & Beauty
M28 battery is flashing green and red when put on v28 milwaukee charger
Is the battery hot or cold??? either temp. extreme will do that...
otherwise the battery is shorted internally and so the charger will not charge it...the battery will need to be replaced.
heatman101
May 21, 2011 | Milwaukee Tool Milwaukee V28 1/2" Hammer -...
Pheonix plus batery flat,charged up,now it is mobile but all i have on dial is single red flashing led.
John the red flashing light indicates a low battery When you charge the battery your charger should be showing a red light for power and a yellow light. When the batteries are fully charged you should show a red and green light on the charger. Now if you have a voltmeter plug the leads into the two outter holes of the charger port located under the front of the joystick.Without the charger plugged in you will be reading the battery voltage. Fully charged it should read 27-30 volts if you are only reading 20-24 volts then the batteries are low. If you have an onboard charger plug it in and you should read the charger voltage of 29-32 + volts If you aren't getting that voltage then you have a bad charger if you are getting the charger voltage then you have bad batteries and they need to be replaced Hope this helps you
Apr 18, 2011 | Health & Beauty
My charger is flashing red when i place the battery in it
Ridgid charger lights read as follows: Solid red; charger has power. Flashing red; charger is evaluating the battery, checking if it's cool enough to charge and if it is in chargeable condition. If the battery is hot, i.e. just came off the tool after extended use, it won't charge the battery until it cools down. Flashing red & green; the battery is defective and the charger will not charge it. Solid red & flashing green; battery is charging. Solid green; battery is full.
Dec 07, 2010 | Ridgid Drills
My DMC-TZ3 battery charger green light is flashing, why ?.
I have the same problem. When I try to charge a battery the green LED onthe charger flashes green and the battery does not charge. Any ideas?
Jul 08, 2010 | Panasonic Lumix DMC-TZ3 Digital Camera
Green and red light comes on when i put battery in charger what does that mean?
Here is the manual:
http://toolboyworld.com/eBay/Ryobi_P120/P120_566_eng.pdf
Red = quick charge
yellow = evaluating
green = charged
CHARGING A COOL BATTERY PACK
If battery pack is within normal temperature range, the red LED on charger will come on.
Red LED should remain on for approximately 1 hour then the green LED will come on. Green LED on indicates battery pack is fully charged and charger is in maintenance charge mode.
Feb 14, 2010 | Ryobi Multi-Volt Battery Charger
Describe your Black & Decker Black
If it is not 2 years old, it is covered under warranty: http://www.blackanddecker.com/CustomerCenter/Warranty.aspx
Sep 12, 2009 | Black & Decker Black And Decker FS24C...
Garden Logo
123 people viewed this question
Top Black & Decker Garden Experts
Nick Olsen
Roland W VanLue
Roland W VanLue
Tim Whalen
Are you a Black & Decker Garden Expert? Answer questions, earn points and help others
