Question about Garden
How to wire for elec. fuel pump
I just replaced my lawn tractor engine. The new engine has a wire coming off the carburater I'm assuming is for an elec fuel pump. How do I get this to work with my old system?
    Sergeant:
  • 353 Answers
That is not a fuel pump.
it is the fuel cut solenoid.
connect to a fused,12 volt source w/ key in run position only.
Posted on Jul 13, 2009
How do we fix our mower?
check the fuel tank for an obstruction then the carburater.
Jul 01, 2015 | Garden
I have the Craftsman GT5000 24 OHV tractor lawn mower. It's been in storage for a while, I have replaced the battery, spark plugs, fuel filter, and oil. I can't get it to start. Does the engine have a pump...
Sounds like the carburetor needs a good ultrasonic cleaning as old gas will leave behind varnish and gum deposits clogging the carburetor fuel passages up.
Mar 29, 2015 | Craftsman Garden
I need Carburater diagram pic.
what is the engine model,you need to get what is called ,model and spec number off the motor to get diagram not from the tractor/mower.
Sep 24, 2012 | Craftsman 17.5 hp 42 in. Deck Lawn Tractor...
How do I perform an electicrical systems test on a 1969 John Deere 110 lawn tractor?
hey a lot of these have an elecrical solenoid fuel shut off to the carburater, i,ve had the same problem look at the carb and follow the wire, when you find it connect it to power when the key is on. should work ok after that.
Jun 12, 2012 | John Deere 22HP VTwin 48" Riding Mower
My craftsman lt 1000 lawn tractor will not start. When I turn the key the starter motor spins but the gear will not raise up and engage the flywheel. Do I need a new starter? (18 hp b&s 42 Inch cut) If...
Starter motor spins, but does not engage
  1. Check the starter motor for a seized or binding pinion gear.
  2. Remove the flywheel inspection plate and check for a damaged ring gear.
  3. Engine stalls immediately when started
    1. Check the ignition switch condition and operation. The electrical contacts in the run position may be worn or damaged. Try restarting the engine with all electrical accessories in the off position. Sometimes turning the key on an off will help in emergency situations, however once the switch has shown signs of failure, it should be replaced as soon as possible.
    2. Check for loose, corroded, damaged or shorted wires for the ignition system and repair or replace.
    3. Check for manifold vacuum leaks or vacuum hose leakage and repair or replace parts as necessary.
    4. Measure the fuel pump delivery volume and pressure. Low fuel pump pressure can also be noticed as a lack of power when accelerating. Make sure the fuel pump lines are not restricted. The fuel pump output is not adjustable and requires fuel pump replacement to repair.
    5. Check the engine fuel and ignition management system. Inspect the sensor wiring and electrical connectors. A dirty, loose or damaged sensor or control module wire can simulate a failed component.
    6. Check the exhaust system for internal restrictions.
May 12, 2010 | Craftsman 17.5 hp 42 in. Deck Lawn Tractor...
John Deere 115 lawn tractor - won't start. Replaced fuel filter, fuel pump, spark plug, oil filter (changed oil), but still won't start. Engine cranks, but won't run.
I have a 115 john deere tractor that runs but the engine will not run smooth I've put a new fuel cap on it a new pump and clean out the carb.
Apr 16, 2010 | John Deere Muffler 1010 Diesel Tractors
I had a replacement engine installed. is it missing a fuel pump?
check inline fuel filter or hose to long between bottom of tank and carb
Feb 13, 2010 | Craftsman 17.5 hp 42 in. Deck Lawn Tractor...
Motor backfires
It sounds like your engine is firing out of time.
Here is a link to the manual for your engine. It does contain some good info and I hope it will help you to solve this problem.
http://www.gardenresources.co.uk/content/garden_machinery/manuals/husqwm227_hwen2002_0000000-01.pdf
Best of luck!
Aug 31, 2009 | Garden
I have a craftsman zts 7500 zero turning radius 26 hp with a pull knob over elec.To turn on the blades.It also has an elec.raised deck.When I pull the knob to turn on the blades the engine dies.And when I...
i going to assume that yr tractor does have the hydrolic p.t.o. that controls the drive and cutting mechanism's???... if so you might start with checking the hydrolic fluid in the resevior. or you might check into replacing the hydrolic p.t.o. pump , if you ran the tractor in heavy work without any hydrolic fluid in the p.t.o. pump the pump is probably burnt up. if so im sure you can beat the cost of a new pump by rebuilding it yrself with a kit.
Jun 24, 2009 | Craftsman 20 hp 42 in. Deck Yard Tractor
Garden Logo
52 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
roeb
john h
