I TRIED TO SET UP MY OLD ADMIRAL TV TO A MAGNAVOX CONVERTER BOX. The instructions to go further never came up. My tv is on channel 3. A christian channel came up and that is as far as i could go. Thank you.
    Sniper:
  • 70 Answers
You need to set up the convertor box to scan for all channels that are available in your area. Go to the menu of the convertor box from the remote and scan all channels. Then you will see for channels. Make sure you have a good antenna attached to find the signals.
Good Luck
Posted on Jul 13, 2009
Magnavox converter box. How can I tell if the box is the problem or the TV? I have no picture, but it isn't the picture tube.
I assume that you are attempting to use the Magnavox converter box to convert digital TV signals received by your antenna system into analog signals for use on an older analog (non-digital) TV set. If that is the case then your first step at troubleshooting the problem should be to view the Magnavox installation instructions to ensure that the converter, antenna, and TV are all properly connected.
http://transition.fcc.gov/cgb/consumerfacts/setup-converterbox.pdf
Feb 23, 2015 | Audio Players & Recorders
Programming RCA converter box remote control with Phil/Mag TV---
Good day,
You should have the instruction guide. If not look below. It's there but look closely for the guide itself and how to increase it's size to readable.
Check on the back of the TV to see if there is a 3 and 4 setting, If so, set to 3.
With nothing connected to the tv, and using the tv's remote, scan for channels. It should come up with only channel 3.
Then using the remote with advanced options, set the the input to either antenna or auto.
Connect the antenna cable to input on the converter box. Using the supplied cable connect the output from the converter box to
the TV. Turn the TV on first, followed by the converter box.
Then follow the instructions.
Not really easy so you'll have to fight your way thru it.
Finding the right setting for the antenna will probably take the most time, requiring a station scan after each adjustment.
http://dtvconverterboxes.blogspot.com/2009/05/rca-dta800b1-owners-manual.html
Dec 28, 2009 | RCA Televison & Video
Radio Schack converter doesn't program Ch: 25 like Magnavox!
Returned product to dealer. That fixed my proble.
Thanks...
Aug 19, 2009 | Philips Magnavox 20MT133S 20" TV
Insignia tv, universal remote, and.....
Follows steps below to program your Insignia Converter Box:
1. Turn on your TV using your TV remote control and change its channel to 3 or 4.
2. Turn on the convert box; the blue light on the converter box is on. If you press the power button again, the red light on the converter box will be on, but do Not turn it to Red!!! Your insignia's other buttons will not response if it in red light mode!!!
3. Then press the Menu button on the Insignia remote control. A wizard will appear. The wizard does not appear if your TV is not in channel 3 or 4.
4. Follow the wizard instructions to scan channels.
Jun 13, 2009 | Insignia Digital-to-Analog Converter for...
DTV Cnverter Box
Your tv needs to be set on channel 3 or 4 depending on which the box uses, then when you turn the box on you will go through a semi sutomated setup, and thats it
Jan 25, 2009 | Philips Magnavox 50ML8105D 50" HDTV DLP TV
Magnavox 20MF500T/17 will not interact w/NHENS DTV Converter box
The tv just needs to be set to channel 3 or 4 to pick the signal up from the converter box.
Jan 10, 2009 | Philips Magnavox 27MS343S 27" TV
Insignia Digital to analog converter menu doesn't come up
When my Menu did not come up, I found it on the AUX channel (one below channel 3). I was able to go through the set up, but found only one digital channel available. Hope this helps!
Nov 10, 2008 | Televison & Video
How to connect my dvd & vcr with the converter box
Here is my setup.
1) Separate DVD player 2) Separate VCR 3) Digital to Analog Converter box 4) Analog TV 5) Rabbit ears (UHF/VHF) antenna
The antenna goes into the converter box.   The RF-output of the converter goes into the RF-Input of the VCR The DVD output goes into the front input jacks of the VCR The VCR RF-output goes into the TV RF-Input The VCR Line output goes into the front of the TV
To watch DVDs, we turn on the DVD player, turn on the VCR, and set the VCR channel to L2, and tune the TV to channel 3.  The converter is off.
To auto record on the VCR, the converter must be tuned to the station being recorded.  The converted must be turned on, the TV can be off.
To watch VCR tapes, turn the TV and VCR on.  The TV is set to channel 3.  Just press play on the VCR.
To Watch TV.   Turn the TV and converter on.  The TV is set to channel 3.   Change the stations using the converter.
May 06, 2008 | Insignia Digital-to-Analog Converter for...
Universal remote code for digital converter
The code for a Magnavox Converter *Analog to Digital* to a Philips Universal Remote is 0759
Mar 21, 2008 | Televison & Video
Televison & Video Logo
81 people viewed this question
Top Televison & Video Experts
Electro Med Services...
