Question about Cuisinart DGB-600 Coffee Maker
Coffee maker dgb600 -on switch will not activate all other switches are live. Is it the grinder motor?
  • 13,433 Answers
Have you checked that the switch itself is OK?
Posted on Jul 13, 2009
No steam pressure help
see this causess and proceed .God bless you
If the grinder does not run when turned on, make sure power is on to the outlet, then check the electrical cord.
If the grinder runs intermittently or doesn't stop, the switch may be clogged or damaged. Unplug the grinder and brush any grounds from the switch with a fine brush. Depress the switch several times with a toothpick. If the problem persists, disassemble the grinder to clean it and inspect the switch for breaks that you can fix.
If the grinder does not run, the motor shaft may be frozen. Disassemble the grinder, clean the shaft and lubricate each bearing point with one or two drops of lightweight machine oil. Rotate the shaft to evenly distribute the oil.
coffeegrinder1_1.jpgMost coffee grinders are accessed by removing fasteners on the base of the device.If the grinder still does not operate, the thermal limiter may be burned out. If you can't readily find a replacement thermal limiter, it may be more cost effective to replace the grinder.
If the grinder vibrates, the blade may be bent. Inspect the blade and replace if it is damaged or dull. Another cause of vibration could be a worn motor bearing. Unplug the grinder and remove the access plate. The bearing is bad if the motor shaft moves when pushed back and forth; replace the grinder.
Sep 25, 2012 | Lello 45920 Ariete Cafe Roma Deluxe...
Motor shorting out?
check ur switch better replace the switch
Jun 17, 2008 | Krups Burr Coffee Grinder
The chute to the brewing unit does not open. The coffeegrinder is ok. The coffee is piling up between grinder and chute.
HI There is a micro switch on the doser box that is faulty. You need to replace it. They are special micro switches. 6 gram activation instead of the 35 gram switches. Its under the solenoid and there is a lever you have to pull side ways to release it. Lifts straight up.
Jan 14, 2010 | Saeco Vienna SuperAutomatica Coffee...
Grinder won't stop
Hi
You have a micro switch on the doser that is in need of a replacement. It is a special micro switch that is just for the doser. It is very sensitive. If the micro switch is not activated the grinder will run until it times out, but the coffee will fill the brew unit and that could break the brew drive.
May 01, 2009 | Saeco Magic De Luxe Espresso Machine
Coffee maker
The beeping is typically caused by the grinder safety interlock. There is a small pin on the clear grinder cover that needs to be in place so that it is depressed into the safety switch when the cover is closed. The interlock switch prevents the grinder from working when the cover is open. Check to be sure that the pin in the grinder cover is not broken.
Dec 29, 2008 | Cuisinart DGB-500 Coffee Maker
My cuisninart won't stop beeping, but every part seems to be in place how can I fix the problem?
On the Grind and Brew coffee maker the beeping is typically caused by the grinder safety interlock. There is a small pin on the clear grinder cover that needs to be in place so that it is depressed into the safety switch when the cover is closed. The interlock switch prevents the grinder from working when the cover is open. Check to be sure that the pin in the grinder cover is not broken. If you open the cover after you have started the auto-brew, it will beep but you can stop the sound by using a pen to gently depress the switch inside the small plastic post.
Grinder not working
Hi
First off the grinder motors are 110V DC not AC. I would say that your problem is in the micro switch for the doser box under the solenoid. It sounds like it might be stuck closed and that would by pass the grinder saying the the doser box is full and don't run the grinder. You may just need a new micro switch which is specialized.
Nov 07, 2008 | Saeco Royal Digital Plus Coffee...
Beeps constantly
The machine will not run if the covers /for the coffee grinder, the filter basket and the machine itself) are not properly closed.
It will beep and stop running if it is turned on when one of the covers is open or if one is opened before the end of the cycle. The beeping will stop as soon as the cover is closed.
To start the machine again, press the ON button.
These instructions are to a DGB600 but i think it is the same to your model.
May 24, 2008 | Cuisinart DGB-500 Coffee Maker
Grinder
1) Rinse area with vinegar/water on a cloth to break up oils
2) Fill grind chamber with ice covered in a small plastic bag - try removing again after 10 mins
Fairly common with the DGB600's IMO
-Tha Mp3 Doctor
Apr 28, 2008 | Cuisinart Thermal DGB-600 Grinder
Grinder will not shut off
try passing air in the switch they sell air compress bottle to clean the computer pass that maybe water when on grinder switch dry hope it work cheers
Jan 29, 2008 | Cuisinart Grind and Brew 10 Cup Coffee...
Cuisinart DGB-600 Coffee Maker Logo
53 people viewed this question
Top Cuisinart Coffee Makers & Espresso Machines Experts
Greg Cann
Greg Cann
880runner
Level 1 Expert
Michael Galve
Michael Galve
Are you a Cuisinart Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
