To original question and the first answer, that is not normal. There is something going on related to the refrigeration. If it should take 10 minutes to freeze down, and a machine runs 15, and everything else remains the same the product in the barrel should be frozen solid. If it's air cooled you could have dirty condensers, restricted air flow or it just may be too hot. You probably need a refrigeration tech to look at that machine. If it runs twice as long as it should, how much do you think that's hurting your power bill?
If you need a part to fix your machine you can find it here. Soft Serve Parts C713
This is normal if you just started the machine up from room temperature to freeze a batch, just reset it and it should not reappear , if you didn't and it's been running for days then your refrigerant is low or your cooling tubes are blocked with goo
