Question about E Sky Flight Simulator Training Kit
Acquiring Hobby Zone Cub for simulator
I want to fly a high wing monoplane lide the Hobby Zone Piper Cub that I own. There are no such planes on teh ESky 4 channel flight simulator.
  • 68 Answers
The FMS SuperCup.par that comes with FMS is the closest to what you want.
Posted on Aug 31, 2009
2 Suggested Answers
  • 68 Answers
SOURCE: Esky simulator won't load on vista.
To download the FMS flight sim go to this site http://n.ethz.ch/student/mmoeller/fms/index_e.html although it works fine with windowsXP Vista doesn't have a file it needs to run. "d3drm.dll" can be downloaded from the microsoft site or go to http://www.driverskit.net/dll/get/494.html to download the file. Then put it in your C:\Windows\System32 folder on your computer. It wont work until you do this. Good luck.
Elevator on tail will not move after accident
EITHER YOUR ELEVATOR CONTROL CABLE IS BENT OR MISSING, OR THE ELEVATOR ACTUATOR SERVO IS NOT FUNCTIONING
NOTE:**** CHECK ALL OPERATIONS BEFORE TAKING TO THE AIR AGAIN...IT GETS COSTLY!!!
Jul 20, 2013 | Hobby Zone Hobbyzone Super Cub Propeller...
How do I replace the motor for the hobbyzone cub trainer? do I need to braze/solder the connections? How do I break the current connections?
there are some motor mounts offered for super cub which will fit exactly the holes on the nose of the plane just google it. There is a kit offered on ebay with esc and receiver. I believe 1000 kv would be enough for the plane especially with the floats it might need more power although the bigger propeller that comes with the floats would be sufficient. Personally I would change the motor only if necessary, although my receiver broke and I think i will change everything on the inside. hope to have answered your questions partly
Oct 23, 2011 | Hobby Zone Hobbyzone Super Cub Propeller...
I assembled my new Super Cub RC plane and when I put the battery in the plane the elevstor snd rudder would move, but when I pushed the throttle up it didnt work. I am new to this and troubleshot it many...
G o back to your manual. I had this problem also. The procedure must be followed properly. First, make certain your throttle is in the off/down position. Second, turn on transmitter. Third connect battery. Once you place the battery in the enclosure and lock the cover you should be working properly. Last but not least, when finished flying, remove the battery BEFORE powering off your transmitter. You must follow these steps. You can NOT leave the battery in the plane when not in use.
Jul 21, 2011 | Hobby Zone Hobbyzone Super Cub Propeller...
Have hobbyzone firebird commander 2, new to flying. Could not get it off the ground, kept veering to right - and my friend's new, same plane, also did the same, yet veered to the left. Help
Some RTF aircraft are not quite RTF as they sometimes need trim adjustments. Also, a wing could be heavier on one side than the other as RTF models are mass produced with cheap and cheaply assembled components.
For a quick balance check, remove the prop and obtain an electrical terminal block (aka Chocolate block). You will need just the brass terminal insert with both screws.
Remove the prop and put the terminal onto the prop spindle. On the other open end of this, you need to insert a small curtain hook (ones that are used to hold up net curtain wires). Insert this into the other end. To the hook, tie a short length of nylon or cotton. Suspend the cotton from a platform such as a shelf. You need to be able to hang the aircraft without it touching the wall but it needs to be close to the wall. Once done, obtain a tape rule and measure the leading edge END of the wing. Move the tape to the other wing and make sure that the same position aligns with the same mark on the rule. If it doesn't, you need to add a minute amount of weight. About a gram, to the higher wing.
If it is fine, then remove the cotton and then tie a loop into it. Make another cotton string loop identical and hang it one plane length away. Using a small piece of sticky tape, tape the cotton to the tape and then to the extreme top of the tail fin. Loop the other cotton loop over the prop spindle, making in effect a cradle system. Again, use a tape rule to ensure that the both wings sit at exactly the same height. Add a piece of tape to the lighter wing to level it. A better way is to use nail varnish as it levels itself and prevents wing surface issues.
If both wings are okay, then it may be the tail fin rudder. It could be stuck on the right side rather than in the middle. This makes the aircraft fly to the right the faster the speed is, even taking off. Try trimming the rudder with the trim control on the transmitter or servo link.
If all else fails....buy a model boat as it could be the operator....
Feb 13, 2011 | Hobby Zone Firebird Commander 2 RTF...
My fuselage broke in two at the fire wall. can it be glued and if so, how?
you can use an epoxy that is just for foam purposes. But mine broke at the center under the wing. I used colored duct tape to match and it flys just fine.
Jan 16, 2011 | Hobby Zone Hobbyzone Super Cub Propeller...
Cutting cost on wing production, resulting in a nasty crash!
i normaly only repair large aircraft, but it seems your old good wing was fatigued from regular use and broke, and the new ones are of poor asian quality, thats why they are snaping. i assume the wings are folding up, so on the bottom attach a very thin wire (stainless lockwire if you can get) to the ends of the wing to fuse, at least 30 deg. from wing (like bottom of wing to bottom of fuse)
Jul 24, 2009 | Hobby Zone Aerobird 3
How do we replace propeller on super cub?
The spinner is simply pressed on. Pull the spinner directly forward while firmly holding the plane at the firewall. Once removed hold the prop by hand and use a wrench to loosen the prop nut. The propeller should slid off but may need to be unscrewed.
To re-install, just reverse procedure. The prop needs to be firm or snug only. Do not over tighten. Be sure to press the spinner back on lined up with the prop blades. Then go fly
Jun 14, 2009 | Hobby Zone Hobbyzone Super Cub Propeller...
E Sky Flight Simulator Training Kit Logo
234 people viewed this question
Top E Sky Toys Experts
ray gallant
Are you an E Sky Toy Expert? Answer questions, earn points and help others
