Question about Compaq Presario 5BW284 (202493-003) PC Desktop
Computor very slow
Slow computor
  • 25 Answers
Re: computor very slow
There is software named registry cleaner.
or check out for RAM or clock speed of processor(using ctr+alt+del key).if using microsoft Os
Posted on Mar 20, 2009
  • 80 Answers
If the comp is still slow, delete all the unwanted programs from Add/Remove programs in Control Panel.
Also delete all the icons tht u use from ur desktop. U can access them from All Programs.
Click Start --> Run --> msconfig --> Enter.
On the system configuration utility screen, click on start up at the top and then on the start up screen, click on disable all.
Click apply and then close the window and restart the computer.
Also if you have more than one anti virus, keep one anti virus and remove all other softwares as tht will really slow down the comp.
If nothing works then u ll have to either upgrade the memory or reinstall OS.
Hope this solution helps!!!!!!!!!
Posted on Jan 30, 2008
  • 324 Answers
Good morning caterer,
Well, that's a pretty general question. It could be hardware, software or virus issues that we are dealing with.
If you can give a little more detail an answer a few questions, chances are that we can find a fix for you!
Is it slow all of the time, or only during the use of certain applications?
What are you using for an anti-virus program and how often do you run it?
Do you have a mal-ware program on your system?
Have you done any housecleaning on your fixed disk? (Removal of old files, defrag, cleaned the registry and such)
If you can please answer these questions and tell what you observe while it's running, that will give us a starting place. Will be waiting to hear back from you.
Posted on Nov 16, 2007
0 characters
3 Points
Computor is slow
Many of these only came with 4 gigabytes of RAM memory. You need more with Windows 8 and 8.1. You can get another 4 gig of DDR3 Memory and put it in the open memory socket next to the 4 gig you have.
Dec 15, 2013 | Gateway GT5220 PC Desktop
Remove your battery and then connect it with the charger to the power outlet,press the power button for 30 sec and it should turn on.
Let me know the result.
Aug 27, 2008 | HP PC Desktops
How to repair you computor from bugs
if you're computor is messed up and you have windows XP, then you're in the right place. My computor was messed up and hve to rebbot it. what i didi ,is i have two hard drives, imoved all my imporntant information in to the slave drive. all you need is you windows XP cd.
1. save all you r important data to a back up drive, i used my other hard drive
2.once you have your data insert your cd , then put install, or what ever it says.
3..foolow thw instructions and delete the infected drive's data
4.the computor will reboot and you will have then you will hve the factory settings5. retrive all your of data and the computor should be bug-free
on Jul 27, 2010 | PC Desktops
Someone suggested to me to increase the voltage. Higher voltage means more power. In your residence the only items with higher voltage are the stove and the water heater. Try powering your computer there.
May 12, 2012 | HP PC Desktops
I have a emachines computor what can i do to make run faster
To make your computer run faster please just follow simple steps
1.make your computer virus free , install a good antivirus and update it also.
2.scan your system to remove viruses,malvares,Trojans etc.
3.Clear registry entries with registry cleaner tools.
4.Install less soft wares on your computer to make it easy for computer
5.At last if your system is very slow then try to upgrade RAM.
this also matters for the speed.
Have a great day
Aug 29, 2010 | E-Machines eMachines Desktop PC
Can a sansa mp3 player give a computor a virius?my room mate took all my music files off our computor,because he said when I put them on the computor from my mp3 player,that it passed a virius to the...
From Answers WiKi:- The mp3 format does not allow you to execute code. The way a virus works is it executes code which either deletes, edits, adds, or takes files from your computer. This is next to impossible without the use of at least one exe, vbs, bat, or com file.
So if you only transferred mp3 files the virus did not come from you.
Nov 01, 2009 | Dell Dimension 4600 PC Desktop
When trying to watch movies computor slows and almost stops for a long time. Using Netflix for one example.
For watching movies using netflix you require to have an high speed broadband connection as your computer slows down go for upgrading ram this can solve the problem.
Aug 23, 2009 | PC Desktops
Computor is very slow
Remove heavy graphics wallpapers if you have and delete Recent documents and files in temporary folders in C: drive in document and setting. if you're using XP go to winnt and delete the prefech file. hop it helps. cheers.
Nov 25, 2008 | Dell PC Desktops
Asked to re-register my desk top computor
The serial number should be on the back of computer and with you just buying it Acer should be able to walk you thru it over the phone for free
Nov 15, 2008 | Acer PC Desktops
Compaq Presario 5BW284 (202493-003) PC Desktop Logo
204 people viewed this question
Top Compaq PC Desktops Experts
Michael Thomas
Michael Thomas
Brian Sullivan
Brian Sullivan
Are you a Compaq PC Desktop Expert? Answer questions, earn points and help others
