Question about Whirlpool Dishwashers
Constant flashing clean light
I have a whirlpool quiet partner dishwasher. i pushed the start button, when i came back 10 minutes later the 'CLEAN' light was flashing. i knew it had'nt finished it's cycle. i pushed cancel and tried restarting it but it keeps going back to the flashing clean light. how do i troubleshoot to find the problem?
  • 64 Answers
Count the blinks shoud be 7 times it blinks then a pause if it does that its a heat circute problem need to check the heater and replace the controls
Posted on Jul 14, 2009
HOW TO RESET MY DISHWASHER
All you can do is turn the power off at the power point, leave it for a few minutes and then switch the power back on.
Jan 11, 2016 | Dishwashers
Whirlpool Quiet Partner V light flashing
most of the time this meens your heat element is burnt out.
Feb 25, 2010 | Whirlpool Gold 24 in. Built-In Dishwasher...
The "clean" button is flashing & none of the other cycles work.
heated dry and high temp wash
toggle till all the lights light up
then hit cancel
you should be able to turn dishwasher back on
you probably have a bad heater
is it flashing 7 times
take kick panel off and look to the rear of the dishwasher
is anything burned
if the clean light keeps blinking replace your heater
Feb 09, 2010 | Dishwashers
Whirlpool quiet partner III. Clean light keeps flashing clean.
Had the same problem. Press the sani-rinse and heated dry button back and forth and it should reset.
Aug 29, 2009 | KitchenAid 24 in. KUDI02IR Built-in...
Whirkpool quiet partner 3 dishwasher status stuck on clean. If I press cancel it goes into a 2 minute drain cycle, but there is no water in it. It will no reset or start....just blinks clean.
if you have a heated dry option and normal wash option push those buttons back and forth three times all the lights will come on reseting the board..
push cans. and your done
if this happens again that means you have a bad heater or bad board
Aug 21, 2009 | Whirlpool Dishwashers
Clean light flashing Quiet Partner V
do the heated dry and hi temp and then hitr cancel. you know what this means?! you have a bad heating element usually. call for service this should be a covered repair if it is only 6 months old
Mar 26, 2009 | Whirlpool GU2400XTP Built-in Dishwasher
Whirlpool Quiet Partner 980
Bad control board ,replace it.
May 26, 2008 | Dishwashers
clean light blinkin???? ry pushing the sanirinse-heated dry--sanirinse--heated dry. tha tshould put in diagnostic mode, there also should be a trouble shooter underthe lower acess panel
Apr 09, 2008 | Dishwashers
Whirlpool Quiet Partner II
press back and forth between hi-tempwash and sani rinse several times to get all lights to come on if not then press sani rinse and heated dry back and forth several times. one of though combos will start the test mode. the test mode will stop the light from blinking and you can use the dishwasher again
Nov 26, 2007 | Whirlpool GU2400XTP Built-in Dishwasher
Whirlpool gu2400xtpt3
I too had Flashing Clean light and only responded to Cancel light by trying to drain. Whirlpool Model DU1145. I too got problem to clear by pushing High temp,Heated dry, High temp and Heated dry. All lights on display lit up then it went through sequences of all cycles.
May 14, 2006 | Whirlpool GU2400XTP Built-in Dishwasher
Dishwashers Logo
667 people viewed this question
Top Whirlpool Dishwashers Experts
Mike
Owen Barnes
Are you a Whirlpool Dishwasher Expert? Answer questions, earn points and help others
