Question about Lexmark E232 Laser Printer
Hi, paper jam refuses to come off, any help? - Lexmark E232 Laser Printer
    Problem Solver:
  • 7 Answers
There is probably some foreign object (like torn paper) caught on a switch, the ones that tell the machine that paper is going through an area and exited. There should be one after the paper pickup, and one past the fuser.
Posted on Jul 16, 2009
I must have put too much paper in. I definitely jammed it.help
Unplug the shredder and remove as much paper as you can from the top, then remove the refuse bin and remove as much as you can from below. Then re install the refuse bin and attempt to reverse the shredder. When removing the paper from the top, try to pull straight out to prevent tearing and take as much of the semi shredded paper with it. After reversing it, I would vacuum as much of the remaining pieces of small paper as possible.
Sep 17, 2013 | Fellowes W10C Cross-Cut Paper Shredder
I have a HP Photosmart C4280 al--in-one printer. This morning it refused to copy a document. It also refuses to print. Always there is a message "carriage jam. Press OK". This does not cure the...
The Carriage Jam error message displays on the control panel display. The print carriage, which holds the ink cartridges, stalls against the left side of the printer. A paper jam might have occurred previously.
Sep 02, 2008 | HP Office Equipment & Supplies
Hello paper jam error appears with no paper jammed. Then printer refuses to print or doesn't print well
To resolve paper jam issue, follow the steps
1. Open the rear access door.
2. Remove any bits of paper stuck.
3. Clean the rollers using lint free cloth ( upward position )
4. Close the rear access door
5. Open the front panel door
6. Check for any paper stuck between the rollers.
After doing all these steps, to make sure if your printer is working fine, try to make a copy.
If the printer can make copy, Click on the link to resolve printing issue -> Link
Oct 12, 2010 | HP Photosmart 2575 All-In-One InkJet...
My Samsung CLP 315w refuses to print a whole A4 page. Stops half way then message comes up paper jam but when I open back / front, paper not jammed and when I close it document continues printing then...
most likly hood is your exit sensor is faulty. The printer work in this way. if it does not print out all the document. it will print again. that is why you kept getting this same issue after a jam open and close door it will print again.
replace the exit sensor it will help.
Apr 16, 2010 | Samsung CLP-315W Laser Color Printer
HP laserjet 4650 with 'phantom' paper jam
hi , I had similar problem,the printer memory is locked on that last transaction feed,
either. check all copy transactions are deleted.you may not reolise you have 3 or 4 still programmed for shedule.
un-install the printer from your pc
the re-install shuld clear it.
set - printer to default mode
you may find your printer works fine on a friends pc, try all or either of above good luck colin leeds
Jul 16, 2009 | HP Color LaserJet 4650DTN Printer
Paper jam won't clear
Check the far left side under the cover..Typically they have a photo sensor for cartridge positioning and if any pape gets jammed on the left side t will behave irratically.
May 07, 2009 | HP PhotoSmart C4480 All-in-One Printer ...
Paper jammed while printing
took printer back to Staples after HP refused to help. They fixed it and showed me how to do it in the future. Thank you Staples
Mar 22, 2009 | HP PhotoSmart C4280 Laser Printer
Printer paused-unable to read
HI there,
1. First, clean your printer. Get some spray-n-wipe cleaner and a clean cloth and clean the entire inside of the printer. Also ensure your paper isn't dirty. Now print a test page. Does the symptom persist?
2. Remove all jammed paper. Check the paper tray first. Look closely at the paper rollers nearest where the paper exits the printer; this is a common source of jams. If you’re trying to print labels, they will often jam just before exiting the printer.
3. Try to print a test page. Does the printer still jam? If you can find no source of the jamming, check the printer's message display window and refer to your user’s manual to look up the printer error code.
Oct 04, 2008 | Brother HL-2070N Laser Printer
Continual Paper jam HP Officejet 6310
There's a couple things that can cause recurring paper jams. Most often, all the pieces of the jammed paper aren't removed. This video shows you where to look to find all the jammed paper. It also offers some other solutions as well. If the solutions in this video don't work, the printer is likely broken.
Jul 07, 2008 | HP Officejet 6310 All-In-One InkJet...
Error light, can't find the problem
Hi, you should check the position of paper sensor flag, called "actuator" (part number 4139 3505 02). On the picture - part 15. The "paper jam" error message means also - "toner cartidge missing", "paper out" or "photoconductor missing" e8dd7eb.gif
Sep 12, 2007 | Minolta magicolor 2400W Laser Printer
Lexmark E232 Laser Printer Logo
144 people viewed this question
Top Lexmark Office Equipment & Supplies Experts
mukhtar21 shaikh
mukhtar21 shaikh
Are you a Lexmark Office Equipment and Supply Expert? Answer questions, earn points and help others
