Question about Canon DC100 DVD Camcorder
DC 100 Canon
It wont start! The red charging light comes on when i charge it but when i switch it on nothing happens.
  • 64 Answers
Re: DC 100 Canon
Theres a problem with the mainboard i do fix this model at work if its under warranty then send it in to canon theres not much you can do i have run into this problem many times before and i would just change the main and lens, and thats what you would need in your case.
Posted on Nov 17, 2007
0 characters
3 Points
Canon Vixia HF M41 doesn't charge battery - red light flashing rapidly
If you don't use the battery for a long period of time even a new battery may become dead. You can try a new battery. If it still doesn't work then the problem is with the charging IC. u can also try a desktop charger instead of direct charger.
Mar 04, 2013 | Canon VIXIA HF M41 Camcorder
I have received as a gift a Canon FS300 Digital Video Camcorder . The first time I used it, I followed instruction on how to charge the battery with CA-570 Compact Power Adapter which was included. It wok...
Almost sure there is nothing wrong with your battery, charger and camcorder.
The battery loose power even when doing nothing, especially when it is a NiMH type.
Please charge the battery for a couple of hours and try again to start the camcorder.
Aug 09, 2011 | Canon VIXIA FS300 Flash Media Camcorder
ZR100 will not trun on
How long have let the camcorder sit still before using again? It seems that you were using it then the battery was out of charge, then you tried to charge it, but nothing happend. Is that your problem?
Jul 25, 2010 | Canon ZR100 Mini DV Digital Camcorder
My Canon MD205 won't charge up. All I had to do was plug in the charger and attach it to the front of the camera and the red light would start flashing, telling me it was charging. Now nothing happens.
Thank you for using FixYa for your problem
Always check the batteries first (check that the voltage is correct with a volt meter) but if is it still giving the same fault, your camera is faulty.
It should be taken to an authorized repair centre for a repair estimate. Very few digital cameras have any user-serviceable parts.
Anything is fixable but it is more "is it cost effective"
Please rate our solutions and if you still have problems please call back for more ideas to help you
Richard Scott
Technical Support
New Zealand
Nov 30, 2009 | Canon Video Cameras
Cant get my hitachi dz-acs3 ac adapter battery charger to work
the light will not come on when it is plugged in and the batery is set in the charger to charge, even with the dc out power supply the dvd cam will not work, could the charger go bad? does this happen often?
Sep 15, 2009 | Hitachi DZ-GX20A DVD Camcorder
My flip video camera wont turn on....
Have you tried resetting the camera? Hold down the power button and the red button simultaneously until the camera shuts off (takes about 10 seconds). Then, just press the power button again and the camera should turn back on. I had the same problem; when I pressed the red button to stop recording, the camera froze, and the red light remained on. I tried resetting it like this, and it seemed to work.
Jan 19, 2009 | Pure Digital Flip Video Ultra Camcorder
Canon Elura 60 won't power up
The same thing happened to mine soon after I got it. Turned out the plug I was using to plug it into the wall to charge had gone bad. The replacement was over $100 so I went with a (cheaper) wall battery charger that you conect the battery to.
Nov 09, 2008 | Canon Elura 60 Mini DV Digital Camcorder
My canonZR600 problem
no its not fried it just needs that dc port changed you would have to send it to canon though sorry
Dec 20, 2007 | Canon ZR600 Mini DV Digital Camcorder
Canon dc100 wont swich on
The camera seems to have these problems, and I think its because the power switch is on when the camers is being charged.
Sep 11, 2007 | Canon DC100 DVD Camcorder
Canon DC100 DVD Camcorder Logo
97 people viewed this question
Top Canon Video Cameras Experts
Sheryl Bahr
Sheryl Bahr
Chris Phillips
Level 1 Expert
Are you a Canon Video Camera Expert? Answer questions, earn points and help others
