Question about Black & Decker Cst2000 12 - Volt Cordless Grass Hog 12" Trimmer/Edger with Auto Feed Spool Afs
Need replacement handle.
Need handle P/N 243233-00 for a CTS 2000
Turn off sports mode in 2009 cadillac cts
Press the "S" button on the shifter handle to disengage the sport mode, press it again to re-engage it.
Sep 30, 2016 | 2009 Cadillac CTS
How to change front turn signal bulb in Cadillac cts
KMTANNER is correct for the 2003-2007 CTS. For the 2008+ CTS, you need to remove the bumper. The bumper comes off fairly easy, but there are a 2 hidden screws. Look for the youtube video on removing the bumper. I have a 2004 and 2009 CTS. I did both.
Sep 13, 2014 | Cadillac CTS Cars & Trucks
What is the torque on the bolt to replace camshaft sensor on 2003 cadillac cts?
there\'s \'nippidy-nip\' tight(platic cover bolts) , there\'s tight( coil bolt), there\'s tight tight( brake caliper bolt), there\'s Eff Tee tight(tight - suspension bolts), and there\'s might be beyond. Yours is just \'tight\'.
If you use a 1/4 socket set just give it 2-3 pound of torque at the end of the handle.
Jun 11, 2014 | 2003 Cadillac CTS
2006 Cadillac STS driver side door lock doesn't activate when I approach the car (as it's supposed to). Key fob also doesn't activate the lock or unlock features. All other doors and trunk operate...
It actually sounds like the micro switch in the drivers door that reads the key fob is bad, if the key works and the fob works on the other doors and the trunk. You will most likely need to have the door handle replaced, they're not very expensive by themselves but it can be a lot of work. Cadillac CTS Door Handle Repair Micro Switches Replacement 2nd Gen The video is a 2008 cts but will give you a good idea of whats wrong and whats required to fix it
Feb 03, 2014 | 2006 Cadillac STS
Photograph showing how to replace tail light on 2006 Cadillac CTS
Here is a VIDEO....
http://www.youtube.com/watch?v=E1jDzlREPNE
Apr 07, 2013 | 2006 Cadillac CTS
Need to replace a purge vent valve on 2006 cts cadillac where is it located and what does it look like
If you buy one from the dealership you will know what it looks like !
Replacing it , , , it can be located in a few locations but it is usually on the bulkhead under the hood.
Aug 26, 2012 | 2006 Cadillac CTS 3.6
I have a 2005 CTS cadallic And I cannot open the trunk with my remote or my button oin the drivers side door panel. What do I need to do?
Open the trunk manually. Pull down the back seat armrest and open the door for trunk access. There is a yellow handle that is above the door, pull the handle and the trunk will open manually.
The remedy for your problem is probably the fuse that runs the solenoid to the trunk opener, it is found under the rear seat passenger side. It has a black cover over it, remove the cover and find the corresponding fuse.
Aug 01, 2010 | 2005 Cadillac CTS
Need to replace water pump on a 03 Cadillac cts I
I do not mean to be hurtful and it will take some time to do. Maybe all day if you have no experience. If you need instructions just maybe you should have some do it for you.
Feb 08, 2010 | 2003 Cadillac CTS
1995 cadillac eldo shift handle is loose i have anew one need to replace
Remove the u clip and pull it outward. The pull up the handle to remove it. Reverse this proceedure to install
Dec 31, 2009 | 2006 Cadillac CTS
I need to remove the rear door interior panel on my 2004 cts cadillac . the window has jumped off the track.
on the inside trim, you can remove screws that are by the door handle, arm rest, under door and side of door and then gently pull back on the panel as there will also be retaining clips attached and you don't want to break them. You'll need to lift the door panel upwards in order to get it off the window ledge.pull back the weather seal and you'll be able to get to the track
Sep 12, 2009 | 2004 Cadillac CTS
Black & Decker Cst2000 12 - Volt Cordless Grass Hog 12" Trimmer/Edger with Auto Feed Spool Afs Logo
242 people viewed this question
Top Black & Decker Garden Experts
Nick Olsen
Roland W VanLue
Roland W VanLue
Tim Whalen
Are you a Black & Decker Garden Expert? Answer questions, earn points and help others
