Question about Panasonic PT-52LCX66 Projection Television
Sharp 28JW73H Green tint with lines across screen
When I switched my TV on this morning there was a green tint and green lines across the screen. The TV was in perfect working order last night. I am at a bit of a loss. The TV is about 5 years old and I'm not sure whether to replace or repair. I'll have a go at repair if one is possible but dont know where to start. Help!
  • 1 more comment
  • Burnybhoy Nov 16, 2007
    It is a Sharp 28JW73H TV. It has now developed a red tint as well.
    sorry for confusion
  • Burnybhoy Nov 19, 2007
    looks like i need to go for the drastic option. No change when adjusting brightness and contrast. Got the back off. Just need an idea of what the screen voltage adjust looks like.
    Thanks
Maybe crt tube broken, check tube pins with a meter look for any short circuits
Posted on May 31, 2008
    Genius:
  • 1,694 Answers
Note: unmatched Make / model info........please clarify...T.
Posted on Nov 16, 2007
  • Vista Electronics Nov 16, 2007
    Possible CRT issue = vary the brightness and contrast
    from min to max and see if the color changes---------
    A more dramatic test is = remove the back of the tv , locate
    the screen voltage adjust on the HV transformer and slightly
    turn ccw or cw and notice any change......
    let me know.................T.
  • Vista Electronics Nov 19, 2007
    Usually on the body of the HV transformer, the part with the
    lead going to the CRT................T.
How to fix my sharp 27rs50 tv color its showing green
Loose solder terminal/s at its video output circuit. This circuit can be located at the car, attached to the back of the CRT.
Gopakumar Gopalan Google
May 08, 2014 | Sharp 27R-S50 27" TV
Green vertical lines across the screen.
Green lines on LCD screens generally means physical damage. Did you drop it or bump it by chance? Physical could also include the cable that you are using. Try using a different cable, or make sure it is connected all the way.
Wasatch Techies Smartphone Tablet and Computer Repair in Utah
Mar 05, 2014 | Sharp AQUOS LC-32D44U 32 in. LCD TV
All my channels have a green tint on them.
You have not provided any details about your system. What components are in your system? How they are connected? Etc.
Have you tried resetting the TV? Have you tried switching inputs around?
Nov 22, 2009 | Sharp Aquos LC-42D62U 42 in. LCD HDTV
SONY KV-32TW67 FAINT GREEN AND RED LINES ACROSS WHOLE SCREEN
friend maybe your LCD was broken or loose. try to pull gently if it return to normal image.
Jun 30, 2009 | Sony KV-32TW67 TV
Vertical Green Lines across TV Screen with no picture
The capacitorson the FMT board have failed, which will cause that symptom. Is the menu screen clear when you hit menu?
Apr 27, 2009 | Mitsubishi WD-52525 52" Rear Projection...
Possibly needs a new control circuit board or lcd panel
Jun 20, 2008 | Sharp Aquos LC-42D62U 42 in. LCD HDTV
Sudden color/picture distortion
you have a shorted green CRT that is affecting the other crts the short is internat to the crt that leaves what is called retrace lines. if the set is more than three years old then replace all three guns.
Feb 25, 2008 | Samsung TX-R3080WH 30" TV
Screen changes from normal to green instantly
intermittent problem resolder around the color circuit.good luck.
May 17, 2007 | Sharp 27H-S60 TV
SLIGHT GREEN TINT TO PICTURE
most atimes if i adjust the screen adjuster on the voltage multiplier i always observe that the screengoes green(lg 21" television),and if i readjust the screen,the greengoes off.Rubberhead,try adjusting the sceenknob on your voltage multiplier(line transformer).
Feb 26, 2007 | Sony FD Trinitron WEGA KD-36FS130 36" TV
Green horizontal lines across screen
try adjusting the green screen control. remove the front bottom panel of the tv by removing any screws holding it in place. gently pull of the front panel, there are gromets holding it in place, you will be able to gently remove the front, just make sure you get all those screws. now reove the small wodden or plastioc panel. now you will see the screen/focus assy. check to see of the screen controls are the top 3 or bottom 3. adjusted the center screen it's the green one, the other 2 are the red & blue. it is best to adjust in a dark room where the lines will show up easier. good luck
Dec 19, 2006 | Hitachi 43FDX01B TV
Panasonic PT-52LCX66 Projection Television Logo
143 people viewed this question
Top Panasonic Televison & Video Experts
 Grubhead
Grubhead
Demonic-2011
Demonic-2011
Are you a Panasonic Televison and Video Expert? Answer questions, earn points and help others
