Question about Samsung HLN5065W 50" Rear Projection HDTV-Ready Television
No color perfect picture hln5065w
  • 304 Answers
Either your Color Wheel is bad or the DMD bd is bad. You will need a trained Samsung tech to look at it to determine which it is. The Color Wheel replacement is relatively inexpensive Color Wheel part# is BP96-00250A. The DMD bd is a little more but are hard to find besides you must have a trained Samsung tech to properly align a new DMD bd. Engines cost hundreds moreand are available.
Posted on Jul 16, 2009
SOURCE:
Service manual to install a color wheel,for a samsung hln5065w also if you have direction
you can get the service manual which shows color wheel replacement from the following link delivered by download link within minutes of ordering http://servicemanuals.vstore.ca/product_info.php/pName/hln5065w/cName/samsung-manuals
Oct 29, 2011 | Samsung HLN5065W 50" Rear Projection...
I just replaced the color wheel on my samsung hln5065w. Picture is great but there is a shadow on the right side of screen from top to bottom. The shadow on the top of the screen is wider across the screen...
Its a Good Possibilty that its the New Color Wheel causing this,if the colors are not complete on the color wheel then that will be why you are seeing shadow on right hand side of screen.
I know I ordered color wheel for mine and had to send it back,it did the same thing.
I compared it to the old color wheel and the new one did not have Solid colors on it.
Can you see picture behind the shadow? or is it shadow and no picture?
Mar 06, 2011 | Samsung HLN5065W 50" Rear Projection...
Noisy sounds like a fan and the picture starts to flickers multiple colors and picture is scambled.
This tv have a colors wheel.The colors wheel is dead.The colors wheel is dying,going to be dead.The tv make loud humming,noisy sounds like a loud fans or motors noises.Also the tv colors flashes black&white or multiple colors pictures and scrambled.Colors wheel replacement is difficult,never done tv repair before.Hire a tv Tech. to replaced the tv colors wheel.
Nov 16, 2010 | Samsung HLN5065W 50" Rear Projection...
Samsung HLN5065W..no picture, TV won't stay on, 3 flahsing LEDs.
Lamp Fan, make sure all fans are running if they run for alittle while and stop Fan is defective.
May 01, 2010 | Samsung HLN5065W 50" Rear Projection...
My TV Started shutting itself off. At first every
usally cold solder joint on power pcb causes this. it is time consuming to resolder but it is needed to repair it.
Jan 01, 2010 | Samsung HLN5065W 50" Rear Projection...
Samsung HLN5065W only displays black & white picture
Hello,This problem denotes a defective color wheel, I would not suggest that you attempt to change it becuse of the risk of causing more damage. I would advise that you have the Tv repaired by a qualified TV technician, due to problems I have seen when repairing sets like this due to improper reinstallation of the color wheel.I hope this helps,Thank you,Shuttle83http://www.electron-age-technologies-llc.com
Jun 06, 2009 | Samsung HLN5065W 50" Rear Projection...
Samsung HLN5065W color wheel installation
Check the wire connections one may be loose or not properly seated
May 11, 2009 | Samsung HLN5065W 50" Rear Projection...
Bad noise
Nope, sometimes you can have a perfect picture and the color wheel can still be bad squealing like a lawnmower. However if your model number is HLN5065w, then you may want to have him look around for the part. One of my suppliers has it in stock and one it is on back-order, so if he looks around he might be able to find one. You also threw a red flag up when you said that he has your tv, I prefer to never remove a tv from a home in order to do a repair and hope that most other shops do as well. Please let me know how much he is charging you so i can make sure that its a good rate and your not getting ripped off! Let me know so i can help!
Tim Nolan
Sep 13, 2008 | Samsung HLN5065W 50" Rear Projection...
COLOR WHEEL REPLACEMENT
http://www.jangro.com/a/2006/07/24/samsung-dlp-replace-color-wheel/
I replaced my color wheel on this TV using those instructions.  Took me about an hour but it worked perfectly.  Just take your time.
Aug 15, 2008 | Samsung HLN5065W 50" Rear Projection...
Samsung HLN5065W 50" Rear Projection HDTV-Ready Television Logo
166 people viewed this question
Jerry Greenberg
Jerry Greenberg
Demonic-2011
Demonic-2011
