Question about HP LaserJet P2015dn Printer
How to remove side panel to reconnect port on hp laserjet p2015dn
My usb plug in port was "pulled out" from the printer. How do I open side/back panel to reconnect it?
Prize the gap with the usb/network card in out. this has no screews to hold this and is ment to come off like this
Posted on Jul 25, 2009
    President:
  • 3,085 Answers
Pull the exit door ALL THE WAY DOWN.
Remove 2 screws and remove back cover, there is a thumb hole on the left bottom to assist in removing. Pry off small light gray cover on left side.
Posted on Jul 13, 2009
My HP Laserjet 1020 powers on but now it's not recognized by my computer anymore. What happened & how can I get it to reconnect?
The solution to this problem is as simple as disconnecting your printer, going into CONTROL PANEL / PRINTERS AND SCANNERS, right click on the icon for your laser printer, then select "remove." Once you have removed the printer in the Control Panel, plug the printer back into your USB port, power it on, and it should plug & play from there.
Jul 20, 2014 | HP LaserJet 1020 Printer
How can i change hp laserjet p2055d usb panel?
Find out defective printer logic board which is having usb port, carefully remove & fix it to 2055 formatter board. If you are technical guy go to TV repair shop & get it done..
Sep 03, 2012 | HP LaserJet P2015dn Printer
I have been trying to connect my laserjet p2015dn printer onto dell gx270 computer but in vain. The printer is a plug and play usb connection.
You can download the HP printer drivers from their supportWEB site. Please click on this link and
select your model printer to download:- http://welcome.hp.com/country/us/en/support.html
Aug 30, 2011 | HP LaserJet P2015dn Printer
How do i remove left side cover from hp p2015 printer to remove formatter board
To open the side you need to remove the paper tray and open the front door. This side of the printer comes off from front to back. Place a flat blade screwdriver under the front of the left panel and pry forward till it clears the tap. Do the same for the bottom front. The side can then be pulled away and pulled towards the back where the other two tabs are. When replacing, just reverse this, put the panel over the back tabs first and press the panel in. At the front, use a screwdriver to gently lift the panel over the front tabs.
Mar 13, 2011 | HP LaserJet P2015dn Printer
Error 0X00000015. HP laserjet 3050 won't scan with new computer using windows 7
  1. Without turning off the product, disconnect the USB cable from the rear of the product.
    NOTE: The USB cable connects to the port on the back of the product. The port is labeled with the USB icon (c01424575.gif ). Figure 2: Example USB connection (your product might not look exactly the same as this example)c01651067.gif
  2. Remove the cartridges from the product.
  3. Wait for the 'Insert Cartridges ' message to display on the control panel.
  4. Disconnect the power cord from the back of the product.
  5. Wait 60 seconds.
  6. Reconnect the power cord. If the product does not automatically turn on, press the Power button (c01602202.gif ).
  7. Reinsert the cartridges, and then close any open doors on the product.
  8. If you receive a prompt to print a calibration page, do so.
  9. Reconnect the USB cable to the rear of the product, and then try printing again.
Solution two: Service the product If you have completed all the steps listed above and are still experiencing a problem, service the product.
If you need more help come back.Post / thumbs / testimonial are welcome!
Dec 06, 2010 | HP LaserJet 3050 All-In-One Printer
Hp laserjet printer p2015 the jam light stays on there is no paper jam. Cannot get the green status light to come on cannot print at all
Hi, first; lets’ start from scratch. Turn off your (Computer), turn off the (Printer), unplug the printer from the power outlet; do not make any changes to the computer. Disconnect (all) the printer cables from the computer; reconnect the cables to the computer, and plug in to power outlet. Turn on the computer (first), turn on the printer. Go to; Control Panel, (Hardware and Sound), click Printer; if the Printer is present; click to open, Properties, click (Drivers): Update Drivers. Restart computer. Thanks paul7of9
Jan 12, 2010 | HP LaserJet P2015dn Printer
Hp laserjet p2015dn
Turn off the printer and unplug the USB cable. Open up Device Manager. In the View menu, make sure that Show hidden devices is checked. Click on the + sign next to Printers in the right-hand pane. Uninstall any entries for Laserjet P2015. Reinstall the drivers for the printer. When instructed, plug in the USB cable and turn on the printer. It should recognize the device and allow you to print a test page.
Mar 31, 2009 | HP LaserJet P2015dn Printer
Printer prints double sided only even though set for single
This is cause duplex printing option is enabled in the driver. If you have win XP, go to control panel and then printers & faxes.
Right click on your LJ P2015 printer driver and click on properties.
Click on the tab 'Advanced' and then click Printing Defaults.
Remove the check mark for 'Print on both sides' under the 'Finishing' tab.
Click Ok and Ok again.
Nov 21, 2008 | HP LaserJet P2015dn Printer
Not printing
Try changing the USB cable then if doesn't work uninstall printer the unplug. Install drivers first then plug in the machine.
Try this hope it works for you
Thanks J
Sep 26, 2007 | HP LaserJet P2015dn Printer
HP LaserJet P2015dn Printer Logo
2,246 people viewed this question
Seeker5211
Seeker5211
