Question about Kenmore Washing Machines
Need a diagram of Kenmore washing machine model C97841160-2
  • 1028 Answers
SOURCE: Schematics for washing machine
look under console
Posted on Jul 05, 2008
jsrock516
  • 5911 Answers
SOURCE: Washing Machine
The model number will be located under the lid along the wash tub opening. Post back with your COMPLETE model number and I can see if I can locate a manual for you.
Posted on Aug 07, 2008
jsrock516
  • 5911 Answers
SOURCE: need to replace belts
This model washer doesn't have any drive belts. It uses a motor coupling in place of a drive belt. If you need to replace the coupler, the following link explains how to do this:
http://www.fixya.com/support/r385250-replacing_motor_coupling_kenmore_top
You have to remove the entire washing machine case to access the interior. The back does not come off. Its not as intimidating as it sounds, though. The part number is included in the link I provided and can be purchased at appliancepartspros.com for about $11. Just use the "Search By Part Number" feature. If you have any questions, please let me know. I hope this helps you.
Posted on May 08, 2009
jumptrout51
  • 3361 Answers
SOURCE: I need Illustrated Parts Diagram for Kenmore
Go to repairclinic. com and put in your model number.
Posted on Nov 11, 2009
  • 1937 Answers
SOURCE: My Kenmore Elite top loading washing machine won't spin or drain
This assumes that you have a basic Kenmore / Whirlpool top load, direct drive, neutral drain (it doesn't spin until the pump removes most of the water) machine.
First, see the Sears parts site for your washer:
http://www.searspartsdirect.com/partsdirect/index.action
Enter your model number (###.#######) and you'll see a list of major sub-components with diagrams and parts.
The Kenmore / Whirlpool top load uses a reversing motor to initiate the pump for draining and the transmission to spin.
If you cannot hear the motor trying to turn the pump, (but the washer will agitate) the problem points to the Timer, or the Lid Switch.
Try to bypass the Lid Switch by removing the Console and jumping the two outermost pins on the switch.
Following is a description of how to release the console for access to the pins.
http://www.american-appliance.com/catalog/newsdesk_info.php?newsPath=16&newsdesk_id=137
This is a Whirlpool PDF on how these washers operate. It has a diagram on jumping the switch as well as a detailed section on how the transmission works.
https://secured.whirlpool.com/Service/SrvTechAdm.nsf/2cd44500d572193285256a45004fd9d6/f7e2147fa98b28cf85257122007475cb/$FILE/L-55.pdf
It also has a troubleshooting guide.
To bypass the switch, you only have to disconnect the power to the washer, tilt the console back, unplug the switch and using an short piece of insulated wire, jump the two outermost contacts on the connector coming from the console and plug the washer back in.
Following is a description of how to gain access to the console and how to remove the cabinet if necessary.
http://www.american-appliance.com/catalog/newsdesk_info.php?newsPath=16&newsdesk_id=131&osCsid=913ba652cd504fb162f87d892bcb427b
With the jumper in place, try to re-start the washer.
If it works, the Lid Switch is a relatively inexpensive part.
If the problem isn't in the switch, and the Timer continues to move, the problem is likely in the transmission.
We had the same problem:
If you lift the lid, put it down again and the washer begins to spin, the problem is likely in the transmission "Neutral Drain Assembly".
Those cams/gears etc. in that assembly keep the washer from spinning until all of the water is pumped out and then go into spin mode.
Apparently, by opening and closing the lid, torque from the motor starting throws the cams into the right gears so that the washer will spin.
After looking at the transmission parts list (available on a number of sites) and on the Whirlpool site (Whirlpool makes Kenmore) we noticed that the one of the cams in the neutral assembly which is supposed to have a small spring, didn't on ours when we tore the transmission apart again
http://shared.whirlpoolcorp.com/assets/pdfs/literature/Repair%20Part%20List%20-%20W10114743.pdf
Found the part number for a kit (Whirlpool part number 388253 Neutral Assembly) for $15.00 and replaced the cams and gears.
In order to get the transmission out, you have to remove the cabinet, the fabric dispenser and both agitators. The top agitator uses a plastic 1/2" drive bolt (a 1/2" socket extension works well).
You don't have to remove the drum.
Lay the machine down (after disconnecting power and hoses, remove the pump (two clips), the motor (two screws hold two clips on the motor), lift and set the motor aside.
Remove two 1/2 inch bolts for the motor mounting plate and three 1/2 inch bolts for the transmission.
Pull the transmission, remove the clutch (there is a spring clip that holds the clutch on the main
agitator shaft), remove the 8 screws carefully the transmission holds 14 - 15Oz of oil, remove the clip holding the main spin gear on and check the plastic cams.
If the cam that should have a spring doesn't, or the others look damaged, or the main spin gear is damaged the washer won't go into spin mode.
If that's the problem, install a Neutral drain kit, put everything back together carefully and the problem may be solved.
As an aside, fixing ours cost less than $30 including 80-90 weight gear oil vs. $170 for a new transmission.
Posted on Dec 07, 2009
Owners manual for sears kenmore washing machine type 588-08 model number 110-21102011
Many Kenmore appliance manuals are available from the Sears Parts Direct site: http://www.searspartsdirect.com/ . The manual page for the 110.21102011 washer is http://www.searspartsdirect.com/partsdirect/user-manuals/11021102011-Kenmore-Parts-Washer-Parts-manual?searchTerm= if you want to read it in your browser. (A PDF plugin is needed.) The direct link to the manual is http://www.managemylife.com/mmh/pd_download/lis_pdf/OWNM/1009787L.pdf if you want to read the document in your PDF reader software.
The parts diagrams may be more useful for how to remove the agitator. Those are available here: http://www.searspartsdirect.com/kenmore-parts-washer-parts/model-11021102011/0582/0153200.html?searchType=modelSearch&prst=&q=11021102011&searchTerm=11021102011&shdPart= . The agitator is shown in the Basket and Tub Parts diagram: http://www.searspartsdirect.com/kenmore-washer-parts/model-11021102011/0582/0153200/K1103004/00003.html .
I hope this helps.
Jul 30, 2015 | Kenmore Washing Machines
Need a dial diagrame for a kenmore washing machine
Go to the following Sears site:
http://www.managemyhome.com/
Click on the "Manuals" tab.
Enter your model number and you should be able to get a PDF of the users manual .
Feb 12, 2011 | Kenmore Washing Machines
I need the electial diagram for my kenmore washer model 110.20702990.
See the following two documents:
The first is the Sears parts list including major component diagrams and parts / prices:
http://www.searspartsdirect.com/partsdirect/part-model/Kenmore-Parts/Washer-Parts/Model-11020702990/0582/0153200?pathTaken=
Also see the Whirlpool / Kenmore Service Manual for top load, direct drive washers:
Jan 04, 2011 | Kenmore Washing Machines
Need manual for washing machine CP2201188 Kenmore
Enter your model number (###.######) and you'll see a list of major sub-components with diagrams and parts.
You can also go to the following site, click on manuals and enter the model number for PDF versions of their manuals.
Jun 26, 2010 | Kenmore Washing Machines
I need new shocks under the laundry washing drum for a Kenmore Model 417.40142000? Need part # and manual? contact brentslogowski@yahoo.com
Your part # is AP3856711. There is a video at www.appliancehelponline.com/servicemanual.html this will walk you thru the replacement. It is different model but the procedure is the same. Enter you part # there for diagrams and illustrations also.
Mar 31, 2010 | Kenmore Washing Machines
Need schematic for kenmore lid switch top loading washing machine door .
Jan 09, 2010 | Kenmore Elite Oasis 27052 Top Load Washer
Our old Kenmore washing machine goes out of balance easily like the springs aren't tight enough. I need to make sure the springs are hooked in correctly. I need a diagram for Kenmore model # 110.82683810...
Please see the following Sears Parts site for your washer.
http://www.searspartsdirect.com/partsdirect/getModel!retrieve.pd?pop=true&modelNumber=110.82683810
Look at the "Machine Base Parts" section for a diagram.
Following is a Whirlpool / Kenmore Service Manual for these machines with better diagrams for the springs and vibration pads.
Nov 16, 2009 | Kenmore Washing Machines
I need Illustrated Parts Diagram for Kenmore Washing Machine
Nov 11, 2009 | Kenmore Washing Machines
Need a diagram for a lid switch
Hello jafarrell
What is the exact model # ?
This was the part number!!
You said, you need a diagram of the Kenmore top loading washer, model 20432 lid switch.
This is a Kenmore part # you supplied, so here is where you can get it from Kenmore.
Part # 20432 lid switch as you supplied in our communications!.
http://www.searspartsdirect.com/partsdirect/retrievePartActionHome!search.action?productGroup=N%2FA&partNumber=20432&pop=flush
Thank you for using Fixya.
Huuum
Please remember to leave a rating
Sep 18, 2008 | Kenmore 22422 Top Load Washer
Washing Machines Logo
284 people viewed this question
Sal DeAngelo
fordexpert
 Brian Main
Brian Main
