Question about Maytag MFD2560HES Bottom Freezer French Door Refrigerator
FRIDGE NOT COOLING
GONE FOR THE WEEKEND AND CAME HOME TO A WARM FRIDGE--AT LEAST 65-70 DEGREES, FREEZER WORKS FINE THOUGH. VACUUMED COILS AND CLEANED BEHIND AND UNDERNEATH BUT STILL NOTHING. DON'T WANT TO SPEND A TON OF MONEY TO FIX IT ESPECIALLY SINCE IT'S ONLY A FEW YEARS OLD!
  • 4,070 Answers
The fridge gets its cold air from the freezer through a vent(damper) between the freezer and fridge.The fan in the freezer blows air through it. There is a flap you adjust with the fridge temp. control. Make sure it's opening and closing when you adjust the fridge temp ..
Your damper and controls are on this diagram. http://www.searspartsdirect.com/partsdirect/getSubComp.pd?modelNumber=MFD2560HES&productCategoryId=0161000&brandId=3048&modelName=MAYTAG-REFRIGERATION&diagramPageId=00006&componentDescription=CONTROLS&documentId=M0412077&backToLink=Return%20to%20Sub%20Components%20list
Posted on Jul 13, 2009
Igloo refrigerator's freezer: -16 deg. Fridge: 60 deg. No evap fan & duct from freezer to fridge. Cond coil clean. Discharge line warm. T/STAT@coldest temp. Fridge gasket seals. Condensate drain clear
freezer is working fine, refrigerator won't go above 60 degrees.
www.shopyourway.com > Manage My Life > Questions
Freezer is working fine but fridge won't go about 60 degrees. Cleaned out pass through from freezer to fridge, clean vents, and cleaned coils. All to no avail.Missing: gloo
Beckly Powerful Suction Cup Handle No Tools Necessary!
www.amazon.com > ... > Bathtub Appliques
Amazon.com, Inc.
Rating: 3.6 - ‎85 reviews
Just Turn 60 Degrees and place on any Flat Smooth surface. For Bath Safety and Cabinet Doors Also Fridge Accessory. Beautiful ... No tools, no glue! No need ...
[PDF]Operate Refrigerator In Room Warmer Than 60°F
Jan 03, 2016 | Refrigerators
GE Profile Refridgerator side warm, freezer ok?
Fridge gets cold air from freezer to cool it. Your freezer is fine but not enough cold air is getting into fridge compartment. U have some dampers or louvers that direct air flow to fridge and if they are not set properly cooling will not be adequate. Check those out.
Sep 19, 2017 | GE Profile CustomStyle PCF23NGT Side by...
Have been away over weekend and returned to find that the fridge side of the unit is not working it says its at 1 degree but is considerably warmer, milk and meat have gone off. It has come up with an...
Many times a freezer and/or refrigeratordo not work right because of a dirty condenser coil...there are also many otherthings that can go wrong. If you are hearing a clicking or buzzing thencheck out the last two tips.
If your refrigerator is running but warm, then...
Check out these tips that I wrote about that... it is a great place to starttrouble shooting your unit...and something that you can do rather then callinga repair person to do a simple thing for you...
Refrigerator Condenser Coil Cleaning Refrigerator Repair
Refrigerator Troubleshooting Refrigerator Compressor
Refrigerator Compressor Start Capacitor and Start Relay
Refrigerator or Freezer not Cooling or Getting Cold
heatman101
Aug 30, 2011 | Samsung RS2630SH Side by Side Refrigerator
Hi, my admiral side by side fridge is having problems. The freezer is working fine but the fridge is not cooling. I noticed 2 days ago that the temperature indicator for fridge was bleeping at 4 degrees. I...
heatman101
Aug 28, 2011 | Admiral 26 cu. ft. Side-By-Side...
GE model GSH22SGRE - freezer not cooling properly. Ice maker not working. Drinking water works fine now (as temp in freezer has come up to about 20 degrees F). This will be the third time the freezer...
heatman101
Apr 02, 2011 | GE GSH25JFR Side by Side Refrigerator
Freezer 20 deg --fridge 55 deg fridge not cooling
Check compressor working and also with correct pressure. Keep arm in condenser coil. If you feel warm, check freezer to hear slight whistling sound. If not short of gas or gas leak. If warm and no whistling sound means, system chocked. Release all gas and flush out system. Vacuum and do gas charging. Thermostat setting must be 3 to 5 degree Centigrade.(37*F to 41*F). Thanks.
Feb 04, 2011 | Refrigerators
Fridge/Freezer - fine bottom half, warm top half
Sounds like the fan in the freezer is not working ( pt# WR60X190 ) .
Jul 30, 2009 | Refrigerators
Fridge running but not cooling
Sounds like you're low on gas...assuming that the condenser coils are clean.
Nov 20, 2008 | Kenmore 64802 Top Freezer Refrigerator
Kenmore Side by Side Refrigerator too cold
On a fridge freezer only the fridge temperature is monitored. In a cold location the fridge might not even need cooling and the freezer would get too warm but the thing won't care.
If the fridge sensor sees it as too warm then it will keep the motor running and the first thing to get really cold is the freezer.
Remember the freezing part is not temperature controlled ion a fridgefreezer.
Apr 28, 2017 | Refrigerators
Maytag MFD2560HES Bottom Freezer French Door Refrigerator Logo
470 people viewed this question
Top Maytag Refrigerators Experts
John Tripp
John Tripp
Are you a Maytag Refrigerator Expert? Answer questions, earn points and help others
