My power cord for the docking station is beginning to unravel with wires showing. Can it be replaced or repaired?
First, I know nothing at all about ipods. However, I am a decent electronics guy. Obviously, one end of the power cord plugs into a wall outlet; the other connects to the station. How? Does the cord simply disappear inside the station, or is there some kind of connecting plug? Which end is frayed? If it's at the wall plug end, you could simply cut the wire (unplug it first !!!) above the fray and wire in a new standard wall plug. You can do the same on the station end if the wire runs directly into the unit AND if you can get in there to reconnect the wire. If, on the other hand, the wire is attached to the station via some sort of power plug (like a printer for example), you'd better leave that puppy alone and invest in a new docking station or new power cord. You'd also better stop using the unit unless you can fix it. Bare wires spell tripped breakers and danger of injury.
